Mic pre 1 Hz to 200kHz - why bother?
Re: Mic pre 1 Hz to 200kHz - why bother?
Post by Goddard »
The delay depends upon the digital filter employed (and for FIR filters generally, the number of 'taps') and is characterized by the 'group delay' (specified as the number of samples (or number of sampling periods)). FIR filters exhibiting linear phase delay all frequencies by the same amount (constant group delay).
Filters may exhibit pre- and post-echo, as well as pre- and post-ringing (with 'pre-' signifying an onset before the main impulse).
Btw, analogue filters also impose delay (with 'time constants' equating to their 'corner' frequencies), but such delay is typically so very much shorter (by an order of magnitude) compared with digital filters (micro-seconds as compared with milli-seconds) that it is not noticeable although the alteration in frequency and phase response is.
Goddard
Posts: 993 Joined: Wed Apr 04, 2012 12:00 am
Goddard wrote:FIR filters exhibiting linear phase delay all frequencies by the same amount (constant group delay).
Surely, all linear-phase filters delay all frequencies by the same amount. That's what the phrase means and a primary raison d'etre.
Post by Goddard »
Yes, but although linear-phase filters will invariably be FIR filters, not all FIR filters are necessarily linear-phase (symmetric/freq-invariant) filters! ;)
Goddard
Post by grab »
Goddard wrote:although linear-phase filters will invariably be FIR filters
Not necessarily. Bessel filters...
grab
Posts: 2420 Joined: Sun Jul 08, 2007 12:00 am Location: Cambridge, UK
Bessel describes the characteristics. FIR describes the construction! ;)
Post by Goddard »
Yes, but a Bessel doesn't really transform to digital form.
Goddard
Mixedup wrote:... there's an error (missing non-standard character) in the online version where it discusses Dave Blackmer's thinking behind 200kHz being the required upper limit. Hint, it doesn't mean 5 seconds!
I've inserted the missing micro character where I spotted it was missing. Let me know if there are others (I'll ask for the web article auto-translate script to be updated so that it correctly includes such characters henceforth).
Ian
Post by Tomás Mulcahy »
Alba wrote:Its been handy for me while making my new album 'music for elephants a long way away and for some whales too who are always a long way away'
As Spock said There are other species on earth. Only human arrogance would assume the signal must be meant for mankind.
As a bat I resent that statement.
Tomás Mulcahy
Post by Mixedup »
Forum Admin wrote:I've inserted the missing micro character where I spotted it was missing. Let me know if there are others (I'll ask for the web article auto-translate script to be updated so that it correctly includes such characters henceforth).
Thanks. Looks good to me. I can see this and other greek/mathematical symbols cropping up quite frequently when discussing outboard gear, so it would be good if the script could handle them all!
Mixedup
Posts: 4557 Joined: Wed Sep 03, 2003 12:00 am Location: Cambridgeshire, UK
Post by grab »
Yes, it really does. Not very long ago, I spent a couple of weeks crunching numbers to replace 4th-order IIR Butterworth notch filters with 4th-order IIR Bessel notch filters, because we thought it would improve our controller's step response. So I can testify first-hand that it does transform into digital, because I've done it. ;)
(And yes, it did reduce the initial overshoot on steps when we really caned it. We decided not to use it for various other reasons, but hey, that's R&D for you.)
We did consider an FIR equivalent, but we don't have enough DSP grunt left to do a good enough job in FIR.
grab
