Korg Wavestation instability in Logic Pro X?
Post by Paul White »
I have had a few reports of Logic Pro X crashing (but not always) when opening a song that includes the Korg Wavesation plug-in. I've seen this myself on occasions and when it happens Logic actually puts up a message blaming the Wavestation. The Korg development team say this isn't something they've come across though I know of at least three users who have experienced the same issue. If anyone else has come across this problem or - better still - found a solution, please let me know on paul.white@soundonsound.com and I'll pass on the info to Korg. Many thanks for your help.
Paul White
Posts: 27 Joined: Thu Nov 15, 2001 12:00 am
Paul White
Re: Korg Wavestation instability in Logic Pro X?
Post by muzines »
Can't say I've ever had any noticeable problems with this, here...
is it OS dependent? (El Cap has some issues with some plugins because of security restrictions etc)
muzines
Post by JohnHop »
Yes this happens to me a lot, and for quite a long time now , to the point now where I'm reluctant to use the Wavestation plugin.
All the other plugging in the Korg suite are fine. Only Wavestation is affected..
My Mac Book Pro is on El Capitan 10.11.4
JohnHop
Posts: 36 Joined: Mon Jun 15, 2009 12:00 am Location: Merseyside UK
Post by Steve A »
It happens to me intermittently in Mainstage - which is tantamount to the same thing as Logic I guess - it prevents me loading the entire concert and leads to having to force quit Mainstage. Another Mainstage user I know is experiencing the same. It's too much to risk during a live show so I gave up using it.
Steve A
Posts: 258 Joined: Wed Aug 07, 2002 12:00 am Location: Edinburgh
Post by muzines »
Steve A wrote:It happens to me intermittently in Mainstage
On El Cap?
muzines
Post by Dave B »
I've had it happen intermittently - most recently in Logic 10.2.2 under Mavericks.
I just put it down to mis-reporting the Liquid Mix plugin failing as it's running under 32 lives. But now I'll try and generate a test project and see if I can get it to repeatably fail.
Dave B
Posts: 5935 Joined: Thu Apr 03, 2003 12:00 am Location: Maidenhead
Post by cristianstefan »
Also i experienced this problem many times, and, trying to find out what kind of buttons on the interface make it to crash the WAVESTATION, i found it:
When create new Logic Pro X project, create the WAVESTATION plug-in, and go in some performance (e.g. RAM 2, Nr. 30, Echo Hunters), go into Performance Edit, then Patch Edit, and then the oscilator (1osc) go to the List, the List window appears (WAVESEQ/WAVE LIST) and when change the ROMs in the List (move between ROMs in the list) the plug-in crash. When moving not between sounds but between ROMs in the List it crashes the WAVESTATION. It happen about 4 from 5 times for me. If not from the first time (not always from first time) but if i try some more times it crash surely (try moving between tabs and List ROM's and CARD's).
Or, when go into the WaveSeq Edit (WAVESEQ tab), choose again List, and in the WAVE LIST move between ROM and CARDs, the plug-in crash. Again it happen about 4 from 5 times for me.
Sometimes it crashes when i move between tab windows PERFORM, PATCH, WAVESEQ tabs.
So i think it is a bug from moving between tabs in the WAVESTATION, particularly in the List window that appear.
I try this on different DAW's not only in Logic Pro X and it happen the same (Ableton Live, Presonus Studio One, also Logic Pro 9)
cristianstefan
Posts: 3 Joined: Wed Jul 13, 2016 11:16 pm
Post by muzines »
I just spent a few minutes running through all the above described procedures multiple times, on the WS under El Cap, and it's perfectly stable here (as it has always been for me), no crashes, behaves fine.
What version of the WS are you running?
(Do a Get Info on the Wavestation AU component file - mine is 1.3.0, the most recent version...)
muzines
Also mine is 1.3.0. In the Korg Logo about menu is 1.7.0, and in the AU component is 1.3.0 which is the most recent and last version. I use Logic Pro X 10.2.4 under Yosemite OS.
And also now i try again and it crashes.
I just open a new Logic project, create the WS, i go to RAM 2 and performance 30 (Echo Hunters), i go into Performance Edit, then into Industrial patch name, then to Patch Edit; in 1osc is selected WSNoise, open the List and directly moving from ROM11 to ROM10 in the List, now first time no crashes. I close the list, i go to the WaveSeq Edit, open the List in the WaveSeq page, and i move from ROM to CARD4 in the List and again no crash.
I turn back into the Patch Edit area, open the List and moving from ROM11 to ROM 10 in the List it crashes.
I open again new project, open WS, go to the Echo Hunters (RAM2, No.30) performance again, select Industrial patch name, go into Patch Edit, open the List and moving from ROM11 to ROM10 in the List it crashes.
I open again new project, open WS, again Echo Hunters performance, select Industrial, go to Patch Edit area, open the List and moving From ROM11 to ROM10 in the List it crashes.
So the most crashes are happen mine is when i change between ROM's in the List in the Patch Edit area.
cristianstefan
Anywone experiencing the same problem?
In the Korg M1, the latest version of plug-in (1.7.0 stand alone and 1.3.0 AU) found some serious bug for me.
The bug is for both the stand alone and plug-in versions:
Open the M1 stand alone or plug-in, go to Multi page and, in the Master FX create an effect (any type) for example reverb or delay. The effect is loaded with default values. Change the parameters of the effect as you want, then click to select the upper top green rectangle (FX 1 or FX 2 just bellow the effect On/Off switch) and the parameters of the effect reset to default values.
If you select the bottom FX 1 or FX 2 green rectangles the parameters remain fine as you adjust, but if you select with upper rectangles, all parameters of the effect are reset to default.
On the Combi page, create a Compressor effect in the Master FX page, and adjust the Sensitivity knob. When you turn Off the effect or On it always change the Out Level knob of the compressor. Also when you select other page and then turn back the Out Level of the compressor reset to the amount of Sensitivity knob.
cristianstefan
Post by muzines »
cristianstefan wrote:And also now i try again and it crashes.
Have you tried completely removing it, all prefs and so on, restarting your computer, and doing a full clean install?
Does it still crash if you try this on a fresh, newly created user account?
cristianstefan wrote:Open the M1 stand alone or plug-in, go to Multi page and, in the Master FX create an effect (any type) for example reverb or delay. The effect is loaded with default values. Change the parameters of the effect as you want, then click to select the upper top green rectangle (FX 1 or FX 2 just bellow the effect On/Off switch) and the parameters of the effect reset to default values.
Yes, I see the same behaviour. If you click on the "On" *above* the green box, the effect is just enabled/disabled as expected, but if you click on the green box, the selected fx preset is recalled / reset to it's stored value. If you control-click on it, the effect is reset back to No Effect. I think it's probably intentional, if somewhat funky, designed behaviour, rather than a bug as such, but it could be a bug too.
cristianstefan wrote:On the Combi page, create a Compressor effect in the Master FX page, and adjust the Sensitivity knob. When you turn Off the effect or On it always change the Out Level knob of the compressor. Also when you select other page and then turn back the Out Level of the compressor reset to the amount of Sensitivity knob.
Yes. That I think is definitely a bug.
muzines
Post by JohnHop »
Okay, so I now have a two-month-old iMac i7 TB SSD 32GB RAM. I installed Korg Legacy, but as per usual Wavestation sometimes crashed Logic Pro X, regularly enough not to bother using it.
The other day I upgraded to High Sierra, only to find the Korg Legacy synths did not work at all. (pretty normal with an OS upgrade)
This morning I received an email from Korg telling me that Legacy will now work with High Sierra, well done Korg.
So full of hope I downloaded the latest versions and installed them.
Anyway, guess what happened the first time I opened Wavestation? Yup!
It crashed Logic Pro X instantly.
Aaaaagh. Oh well. :headbang:
It's such a shame because it's such a great sounding synth but pretty much unusable, for me anyway.
JohnHop
Post by muzines »
Thanks for the report, I wondered if the "stability improvements" in the new update would improve this for people...
Seems not the case :(
muzines
Post by Ricard »
Same thing happened to me... Was expecting the Wavestation plugin to work now, but it instantly crashed Logic pro x... Depressing since I really like it!!
Ricard
Posts: 1 Joined: Fri Oct 13, 2017 12:30 pm
Post by Kevin Nolan »
Just an update - I've tried to run Korg Collection Wavestation on LPX 10.4.1 and it crashes it every time.
I've logged it with Korg UK, requesting a fix. Will report back any communications from them.
Kevin Nolan
Posts: 844 Joined: Sun Jan 12, 2003 12:00 am
Post by Dave B »
I get an occasional crash with 10.4.1 and the Wavey. Mainly on re-opening projects iirc. But it's by no means every time. It's infrequent enough to be a niggle rather than a problem.
I can double check OS versions, etc if you want.
Dave B
Unfortunately, it’s crashing Logic every time for me. I’m on High Sierra, LPX 10.4.1, Korfg Collection - latest versions of all of those. All other Korg Collection plugins work perfectly, but Wavestation crashes logic, every time it’s instantiated.
Kevin Nolan
Post by fatbenelton »
Not used mine for a while so thought I'd give it a try. It seems ok but I'm I'm merely setting up a stereo instance and noodling - no recording etc but works fine. OS 10.13.6 and Logic 10.4.1......No crashes at all but not exactly deeply testing it!
fatbenelton
Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
I'm just using a stereo instance too - nothing deep on this end - just - every other of the 200 plugins I own work - but Wavestation - the moment I instantiate it - Logic - Puff!!!!
Completely unusable.
Kevin Nolan
Post by Rich Hanson »
fatbenelton wrote:Not used mine for a while so thought I'd give it a try. It seems ok but I'm I'm merely setting up a stereo instance and noodling - no recording etc but works fine. OS 10.13.6 and Logic 10.4.1......No crashes at all but not exactly deeply testing it!
Just checked mine too, doing much the same and so far no problem. (2017 iMac, 21.5" retina, if it might be relevant)
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Just got a reply from Korg UK with a solution. Probably should have tried this but it didn't occur to me:
1. Reinstall the KORG Collection software.
2. Delete the following AU plug-in cache: ~/Library/Caches/AudioUnitCache
3. Rescan the plugins using Logic's Plugin Manager.
As an aside - I find Korg UK support (which covers Ireland too) to be _absolutely_ fantastic. I've had a lot of dealings with them in the past couple of years and every time they have been incredibly friendly and hugely helpful. From buying spare parts to technical support - just brilliant every time. Just thought it worth flagging.
Kevin.
Kevin Nolan
Post by ConcertinaChap »
Good to know as the owner of some Korg kit. Off-topic but quick call out for Softube support, who are both friendly and very effective. Needed them badly recently and they delivered the goods.
Last edited by ConcertinaChap on Sat Sep 01, 2018 7:56 pm, edited 1 time in total.
ConcertinaChap
Posts: 15231 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
