Your Recommended FireWire Adaptor Cards
Re: Your Recommended FireWire Adaptor Cards
Excellent - always good to hear of a combo that actually works! 8-)
Posts: 22534 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by studer58 »
Without any proof or even knowing the devices involved I'm wondering whether these adapter boxes: Village Instruments and
Aquitek
enclosing one of these: SIIG Firewire card might not be a good solution for those laptops still sporting an Express card slot ?
studer58
Posts: 74 Joined: Fri Nov 28, 2003 12:00 am
Post by John Reid »
[quote="Dramatic Hammer"]Good news! This startech.com PCIe card seems to be working perfectly so far http://www.amazon.co.uk/dp/B00IAABHFE />
Same problem here with Z170 and a TI XIO2200A chip; bizarrely though, that Startech card seems to have a VIA chipset, which were long regarded as poison for audio. Can you confirm the chipset please?
John Reid
Posts: 121 Joined: Wed Sep 11, 2002 12:00 am Location: Craggy Island
Post by Pete Kaine »
Yes, the TI XIO2200A found on the cheaper 2 X FW400 port cards, that have been the go to solutions for years, no longer function properly on X99 or Z170
Cards based around the TI XIO2213B most often found on cards with three outputs (normally 2 X FW 800 + 1 X FW 400), which even TI themselves stress is the replacement for the now legacy XIO2200A seems to work fine in everything that we tested it with.
The VIA's were always hit or miss, depending on the interface being plugged into it, great if and when they work however.
Pete Kaine
Posts: 3217 Joined: Thu Jul 10, 2003 12:00 am Location: Manchester
Post by John Reid »
Thanks guys, for saving me a second day of head-scratching! Now to find such a card ... a sense of deja vu sets in ... retailers sure don't make it easy, previously it was a case of hunting for the TI logo, which could often be spotted by zooming in on the pic, but now we need to look for the exact chip. Firewire itself seems to been consigned to the scrapheap, but I'm not ready to give up on a perfectly good interface yet!
So far, I've found a Delock 89153 and this Digitus which seems to have the desired chip, but I'll need an adapter FW800->FW400 which I am assuming will not cause problems.
John Reid
Post by Exalted Wombat »
Your previous reply was from a retailer who can sell you a suitable card. Check Peter's sig.
Exalted Wombat
Posts: 5846 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Aye, can't 100% confirm on the brand your looking at as I've not physically handled one, but given the info they provide and looking at the card layout I suspect you'd be absolutely fine.
They look to have mounted the FW400 port internally in that design however (along with the two external FW800), which if it was outwards facing would save you from the convertor. FW 400 - FW800 cables also exist, which might prove better than hanging the plastic off the port.
FWIW the validated card we use over here is the Lycom PE 107, as that's what we import. Plenty of other brands exist based around the same design however.
Pete Kaine
I've been running a Sonnet Allegro 3 x FW 800 PCIe card in my music PC for over a year now with no problems whatsoever; under both Win 8.1 and then Win 10.
It's got a Ti chipset, with the added benefit that each of the three outputs is on its own FW bus, not a single shared bus like on a lot of FW400 cards with three FW connectors. Quite a few audio interfaces don't like sharing a bus with other devices, so if you have multiple interfaces or other FW peripherals, this makes things a lot easier.
I'm using it with a FW 800 to 400 cable to connect to my MOTU traveller. I chose it because I wanted it to connect to my Liquid Mix as well (and hence the bonus of separate buses, as I had to use two FW400 cards on my previous music PC), but found out after buying it that Focusrite had stopped supporting the Win 8.1 (+ Win 10) Firewire drivers, so that went off to someone still on Win 7. :frown:
I haven't got any FW800 devices, so can't comment on its performance at that speed, but it's been rock solid with the MOTU running at around a 3ms latency.
At around £60, it's not the cheapest FW card out there, but if you would benefit from separate FW buses, then it's a much neater solution than multiple cards.
Posts: 19177 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by Dramatic Hammer »
Via - VT6315N according to this: https://www.startech.com/uk/Cards-Adapters/FireWire/2-Port-1394a-PCI-Express-FireWire-Card~PEX1394A2V
Looks like you've already solved your problem though!
Dramatic Hammer
Posts: 123 Joined: Fri Oct 30, 2015 12:00 am
The Sonnet Allegro is based around the TI XIO2213A chip, rather than the TI XIO2213B solution. I've had feedback that the "A" revision is running fine, but I can't verify first hand.
(A number of other resellers & manufacturers give me positive feedback, so fairly certain)
Just to clarify Wonks, what chipset is your system running? The issues being discussed only applies to X99/Z170 rigs at the moment, although I don't expect that to change on newer chipsets moving forward.
Pete Kaine
It's an older Asus Z87 MOBO with an i7 4770K processor.
Post by John Reid »
I've pushed the button on this Digitus card and shall report back anon.
Apart from the fact that it has the TI XIO2213B chip, I chose this one because of the internal port, which I will use for the existing front panel FW400 connector. For the audio interface I'll use a 9-pin to 6-pin cable.
Just to reiterate, this is all about motherboard chipset compatibility with my Z170 board.
John Reid
Post by John Reid »
OK I'm back ... long story short, after an issue with one retailer I gave up on the Digitus and went with a Delock card instead (looks identical to the Digitus, right? Wrong!!!) popped it in and found it had an LSI chip instead. Nevertheless this is now working perfectly with my Z170 motherboard and has given my MOTU a new lease of life!
So, I can recommend the IOI FWB-PCIE1X20 with LSI FW643 chip, rebadged as Delock 61557
This card has 3 independent FW800 ports and I have tested with all three active, connected to my MOTU as well as 2 FW400 external harddisks using FW800->FW400 cables. So far, this is the best card I've come accross (and I have measured and compared the disk transfer rates) and it does all of this with the stock Firewire driver in Windows 10 (no need to load the "legacy" driver).
The "TI only" dogma might no longer hold true for modern motherboards.
John Reid
Post by IvanSC »
John - did you actually buy it from that german site? How much did you wind up paying including shipping, please?
IvanSC
Posts: 3041 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime,  please!
Post by Guest271017 »
Just went through a build with a Z 270 A and ended up with this card working. $28 USD/ free shipping.
Syba Low Profile PCI-Express 1394b/1394a (2B1A) Card, TI Chipset, Extra Regular Bracket SD-PEX30009
This one did not work, even though it's TI.
Ableconn PEX-FW101 1394a 2-Port PCI Express (PCIe) Low Profile FirwWire Host Adapter Card - TI XIO2200 Chipset
All TI chips are not created equal, or so it appears.
Guest271017
Posts: 1104 Joined: Wed Jul 20, 2016 12:42 am
mashedmitten wrote: This one did not work, even though it's TI.
The XIO2200 itself was delisted by TI almost a decade ago, although chips are still in circulation. Support has been dropped by everyone else over the last few generations.
Pete Kaine
Post by Dr R »
Hi all,
A friend offered me a "control surface" to have a play with. Turns out to be a Tascam FW-1884. Very nice, but I don't have firewire on my pc.
It's a 2009 Dell Inspiron souped up with a pair of ssds, and although I have the service tag (BVN6K4J) the motherboard details aren't on the dell support site.
Any suggestions for a cheap card? The thing is probably too big for what I want, but it would be interesting to see what pc mixing with faders is like.
As ever, many thanks,
Rich
Dr R
Posts: 280 Joined: Mon Jun 21, 2010 12:00 am Location: Solihull, West Midlands, UK
My ambition: To one day have enough experience to answer technical questions on the SOS forums, as well as asking them
Post by maggotspawn »
I just purchased a Siig PCIe FireWire card. It has a Texas Instruments chipset, though I'm unsure of which one. Working great with my i7 7700k build running Windows 10.
maggotspawn
Posts: 43 Joined: Sat Feb 18, 2006 12:00 am Location: Los Angeles, California
Post by jahjahjah »
can someone confirm that the following firewire controllers works on motherboards z170 and over (i have msi z370 a pro)
DeLock PCI Express Card 89153 (its an IT chipset but i cant find which one exacly)
PCIe Dawicontrol DC-FW800 (i thing its an IT too)
and also the VIA-VT6315N chipset that is included in many firewirecontrollers
jahjahjah
Posts: 1 Joined: Fri Jan 12, 2018 10:09 pm
Post by BillPhillips »
maggotspawn wrote:I just purchased a Siig PCIe FireWire card. It has a Texas Instruments chipset, though I'm unsure of which one. Working great with my i7 7700k build running Windows 10.
I have the SIIG DP FireWire 2-Port PCIe. It's compliant with Compliant with the IEEE 1394-1995, 1394a-2000 and OHCI 1.1 Standards. Doesn't work at even the highest ASIO buffer size with my old MOTU 828mkII.
Not sure the FireWire card is the problem but looking for another FireWire card anyway. Any suggestions?
My system specs:
CPU: Intel i7-6850K @ 3.60 GHz
Motherboard: ASUS X99-DELUXE II
RAM: Corsair Vengenance LPX 32 GB (4x8GB) 288-Pin DDR4 SDRAM
SSD:
• System Drive: MyDigitalSSD 240GB (256GB) BP5e 80mm SATA III 6G M.2 2280 NGFF SSD
• Alt Boot Drive: MyDigitalSSD 240GB (256GB) BP5e 80mm SATA III 6G M.2 2280 NGFF SSD
• Projects Drive: Samsung SSD 850 EVO 1TB
• Resource Drive: Samsung SSD 850 EVO 250 GB
GPU: ASUS R7250-2GD5 (AMD Radeon R7 250)
PSU: Corsair RM1000i
Chassis: Fractal Define R5
OS: Windows 10 Pro (x64) v1809
FireWire: SIIG DP FireWire 2-Port PCIe
BillPhillips
Posts: 81 Joined: Thu Nov 04, 2004 12:00 am Location: FL, USA
Slow but sloppy.
Post by innerchord »
Have you checked that the interface is working correctly?
After doing that, I'd suggest trying StarTech or Syba cards, with TI or VIA chipsets.
I don't use MOTU interfaces myself, so don't know which chipsets they like...
innerchord
Posts: 212 Joined: Wed May 11, 2016 12:00 am
Pete Kaine wrote:The Sonnet Allegro is based around the TI XIO2213A chip, rather than the TI XIO2213B solution. I've had feedback that the "A" revision is running fine, but I can't verify first hand.
Is the TI XIO2213B still the best choice for X99? Thanks.
BillPhillips
Slow but sloppy.
I purchased the Syba SY-PEX30016 https://www.amazon.com/gp/product/B006DQ0KD2/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 on amazon for US$ 26. I'm only using the Firewire 400 port. It installed automatically and seems to work flawlessly.
Features include:
  • TI XIO2213B
    Simultaneous operation of multiple high-performance devices
    Supports hot-swapping and Plug-n-Play connection of peripheral devices
    Works with various types of FireWire 800 (1394b) and 1394A devices including portable Hard Disk, DV camcorder, digital Camera, CD-RW/DVD-ROM Drive and other Audio/video devices
    Support Provisions of IEEE P1394b Revision 1.33+. Compliant with IEEE 1394 OpenHCI specifications V1.0 and V1.1
    Fully Interoperable with FireWire, I Link, and SB1394 Implementation of IEEE 1394 standard
    Form Factor: Plug-in Card
    Fully Interoperable with FireWire, iLink, and SB1394 Implementation of IEEE 1394 Standard
BillPhillips
Slow but sloppy.
I just received this https://www.studio1productions.com/Arti ... wire-1.htm link from SYBA tech support in response to frequent/intermittent startup blue screens on Windows 10 21H1build 19043.1348 support request.
Many of you with Firewire interfaces have probably found it long ago. But for those who haven't, you might find it useful. I used it to manually re-install the legacy driver I was already using. So it's not likely to solve my problem. Time will tell.
BillPhillips
Slow but sloppy.
Post by johnny h »
Firewire has not been supported since Windows 10 came out in 2015 and the last post here was 2 years ago. Time to let this topic sink into the abyss?
johnny h
Posts: 4388 Joined: Mon Jul 24, 2006 12:00 am
