M-Audio Oxygen & Cubase
Post by portthames »
Hi!
I've noticed that unless I have the M-Audio Oxygen switched when starting up, Cubase remember it so I have often loaded big projects/songs that take an age, and realised too late and had to start again.
Apart from obviously remembering to turn the thing on at start is there any way to force Cubase (6.5) to see the Oxygen 61 after Cubase has started?
ps does anyone notice the 'odd' midi velocity sensitivity of the Oxygen range too? Basically it feels like there is a lack of velocity sensitivity.
portthames
Posts: 39 Joined: Sat May 19, 2007 12:00 am
Re: M-Audio Oxygen & Cubase
Evans Forster wrote:ps does anyone notice the 'odd' midi velocity sensitivity of the Oxygen range too? Basically it feels like there is a lack of velocity sensitivity.
Have you tried the various velocity curve options on the Oxygen keyboards Evans?
I seem to remember that here re about half a dozen on offer - hopefully one of them ought to give you more the sort of response that you're after!
Martin Walker wrote: Have you tried the various velocity curve options on the Oxygen keyboards Evans?
Thanks Martin! Yes I did, I'll try again.
Anyone any thoughts on that start up 'issue' pls?
portthames
Post by Guest271017 »
Evans Forster wrote:Hi!
No way around it on PC, unit must be powered before opening Cubase. On Mac, you can hit refresh and it will appear afterwards.
Guest271017
Posts: 1104 Joined: Wed Jul 20, 2016 12:42 am
Bummer.
Thanks mate,
portthames
