Tracking down a USB cable
Post by ManFromGlass »
I have been searching for a USB-B to lighting cable. It's to connect the idevices to an iConnect interface. They only include 1 of these cables with the interface.
I can order one from them that works out to over $50 Cdn. I sourced one in Canada for $50 plus taxes. Depending which "genius " you speak to at the Apple Store they either do or don't carry them, but they are out of stock - call back next week.
Any suggestions as to websale places?
I am not looking for a gold plated oxygen free high frequency down the centre core assembled by virgins custom cable, just something simple. $50 seems excessive but perhaps it's a niche cable. :?
Re: Tracking down a USB cable
The other alternative is an "iPad camera connection kit" but that's £29.... I'd always prefer a single cable though. Can't the suppliers of the iConnect supply one?
Posts: 22908 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by resistorman »
I bit the bullet and bought another specifically for the iConnect. I had tried other adapters, etc. but nothing else works, it seems. As an aside, the Audio 4+ might be the most confusing device I have ever encountered, but nothing else does what it does.
resistorman
Posts: 2987 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Post by jimjazzdad »
I'll assume that's USB to Lightning (not "Lighting"). Up here in the Great White North, I'd recommend Monoprice. Select Series Apple MFi Certified Lightning to USB Charge & Sync Cable, 3ft Black for USD$ 3.95...with postal shipping that should be well south of CDN$20.00.
jimjazzdad
Posts: 310 Joined: Sun Dec 15, 2013 12:00 am
Halifax, NS, CANADA
Damn Otto Korrekt! Yes, lightning. Thanks for the leads. (small pun intended)
The iConnect people want $41 USD plus shipping. And, yes, it can be a very confusing device in spite of its awesomeness. I almost have a handle on the routing, I've watched the youtubes over and over again and then sat down and traced the routing matrix slowly over and over again.
Why they would build a device that can give you amazing routing possibilities for two idevices and then give you only 1 cable, I don't know. I do know it's been rock solid in live performance and when I use it as an external fx unit with Logic. Off to search for the cable.
Update - Monoprice doesn't carry the Lightning to USB-b cable. So still searching. I may have to bite the bullet, cost of doing business and all that.
Yes, it would be nice if they gave you a cable package option at purchase. I suppose most people use one iPad and a computer. Having bought another lightning cable, I found that running two iPads wasn’t really all I hoped it would be... maybe as Apple continues refining iOS 11 and app makers catch up it will become more straight forward.
resistorman
