Can I run UAD plug-ins on Satellite without UA interface?
[Couldn't fit my full question into the topic title...]
Silly Question 101: Can I run UAD plug-ins if I own a Satellite but do not use an Apollo audio interface?
I've scoured the UA site and re-read the SOS reviews, but every internet review/blog/video I could find is using the UAD plugs with their Apollo interface. It's never made clear whether you could buy a Satellite, install the UAD 'control' software and plug-ins, and enjoy the results with a non-Universal Audio interface (like my PreSonus Studio 192).
Anyone doing this or know it can be achieved?
- Forum Admin
Posts: 4767 Joined: Mon Jul 21, 2003 11:00 pm
Re: Can I run UAD plug-ins on Satellite without UA interface?
I'm pretty sure you can.
I have a couple of the old UAD PCI cards and run the plug-ins using a Audient ID22.
As you probably know, the PCI cards have no I/O, just like the Satellite.
https://davylamb.bandcamp.com/
Thanks Kwack... my friends who use non-UA audio interfaces all have the UAD PCI card in their old Mac Pro towers -- but I've never actually read about or met or heard of anyone doing it just with a Satellite.
All the Satellite owners I know are Apollo users. Or if you read about mix engineers in 'Inside Track' articles, they're typically using Pro Tools rigs off a Mac Pro tower, with a UAD PCI card in one of the slots.
- Forum Admin
I'm not sure if this clears anything up for you.
http://tinyurl.com/yavle7kg
My logic (which may be very flawed!) is that the Satellite existed before the Apollo interfaces, and therefore could run only with third party I/O interfaces. Whether it has enough "power" for some of the newer UAD plug-ins is another thing to consider.
But, hopefully someone with proper evidence will respond soon!
Good luck.
Good luck.
Kwackman wrote:I'm not sure if this clears anything up for you.
Sadly it does not. Thanks for searching.
As I said earlier, I've never seen it explained with certainty that you can do what I potentially wish to do. UAD obviously would like everyone who wants to use their plug-ins to do so with an Apollo, but I would have thought the overall market for non-UAD audio interface owners being interested in a Satellite would be larger.
- Forum Admin
The Apollo has only been around a few years, but UAD DSP has been around a couple of decades...
As far as the host goes, you load a UAD plugin. The plugin will communicate with the UAD driver software, which will see the UAD DSP available (across multiple cards), and allocate it so the plugin will pass audio to the DSP process and back again.
It shouldn't matter where the UAD DSP is coming from, as long as you have some DSP resource available. The driver should unify whatever DSP you have on your system, and it's the same software whatever UAD device the DSP comes from.
The DSP part of the UAD system is separate from the audio interface part.
So, if you have a Satellite running, your UAD driver will show you that you have UAD DSP, and any UA plugins you load will run.
Note - you need to have both the Apollo card, and the Satellite card, registered and authorised in your account to be able to use the plugins you have purchased.
Note: I've been using a UAD card since long before there was UAD audio interfaces, and still do. I currently have a little UAD2 Solo for my MBP to access my UAD plugins. All a Satellite is is UAD2 DSP with a computer interface + power in a box - it's essentially an external UAD2 PCI card system - no real difference to an internal UAD PCI card. And an Apollo is an audio interface, with a Satellite built in (and a bit of internal routing so you can route audio to UAD plugins without round tripping through the computer, for better latency.)
Thanks desmond.
Your mention of needing an Apollo card is confusing to me.
Like everyone else I know, you've been using a UA card in your computer.
I'd still love to hear from a confirmed user of a Satellite box and a non-UA audio interface.
I think I get it.... you're saying YES then, right?
- Forum Admin
Forum Admin wrote:Your mention of needing an Apollo card is confusing to me.
Sorry, I thought you already had the Apollo, but wanted to also/instead use a Satellite. All I meant was that your plugins will only run on UAD cards that are in your account and authorised for those plugins - whether it's PCI, Satellite, or Apollo DSP. The DSP is all the same, regardless of which box & interface it's using.
Forum Admin wrote:Like everyone else I know, you've been using a UA card in your computer.
No, it's a Solo/Laptop card, in a thunderbolt adaptor, plugged in to my MBP via thunderbolt. It's esentially the same thing as a little Satellite, just with an uglier footprint
Before this, I had a UAD Xpander, which was essentially a UAD1 "Satellite" (USD DSP in a box with an interface that you could use with a laptop) and before that it was a conventional UAD PCI card in a tower computer.
Forum Admin wrote:I think I get it.... you're saying YES then, right?
Yes. You can run UAD plugins with only a Satellite. That's it's sole purpose. If you couldn't run UAD plugins on it - then it's kinda a useless product, eh?
You do not need an Apollo to run UAD plugins - you just need UAD DSP, whether it's in an Apollo box, or a Satellite box, or in an external or internal card. As long as you have some UAD DSP, authorised for your plugins, your UAD plugins will run fine, regardless of which device you use for audio I/O.
Desmond was saying that ALL UAD hardware components in a system need to be registered for everything to work.
What you probably can’t do, and I can’t test it as I only have an Apollo, is use the control software with non-UAD interfaces.
Best contact UAD support for definitive answers.
- Bob Bickerton
Longtime Poster -
Posts: 5641 Joined: Fri Dec 20, 2002 12:00 am
Thanks guys.
- Forum Admin
Doh, I always understood that what you mention is the sole purpose of the Satellite - to run UAD plugins via few/usb even if you don’t own or use their interface.
Bob Bickerton wrote:Desmond was saying that ALL UAD hardware components in a system need to be registered for everything to work.
Correct.
Bob Bickerton wrote:What you probably can’t do, and I can’t test it as I only have an Apollo, is use the control software with non-UAD interfaces.
Correct. The control/mixer software talks to the audio interface part of the Apollo, which won't work without an Apollo, but has nothing to do with using UAD plugins in your DAW.
CS70 wrote:Doh, I always understood that what you mention is the sole purpose of the Satellite - to run UAD plugins via few/usb even if you don’t own or use their interface.
Exactly. And these came way before the Apollo even existed.
All the Apollo is is an audio interface, and a Satellite, in one box. You can use either part independently, or together, (almost) exactly as you could if you had a Satellite, and a different audio interface.
The answer is yes.
It doesn't matter to the UAD software where the physical DSP lives -- whether on a PCIe card, a Satellite, or an Apollo interface (or a combination of them) -- the DSP just needs to exist, be recognised by the UAD controller, and be of sufficient capability to host the plugins you want to run. Obviously, the newer, larger platforms can do more than the older smaller ones.
Thanks everyone.
Told you it was a silly question. Now I know it can be done.
- Forum Admin
desmond wrote:The Apollo has only been around a few years, but UAD DSP has been around a couple of decades...
Well, since late 2001, so still 3 and a bit years to go for two decades.
Forum Admin wrote:Thanks everyone.
Just to make things more fun - it works also the other way: my main interface is an RME but I use UAD plugins, so I got myself an Apollo Twin Duo for that. I really wanted a Satellite but the Duo was a far less expensive proposition. So you can use also a regular interface simply as a DSP-running platform.
Wonks wrote:desmond wrote:The Apollo has only been around a few years, but UAD DSP has been around a couple of decades...
Hence the "around" bit...
desmond wrote:Wonks wrote:desmond wrote:The Apollo has only been around a few years, but UAD DSP has been around a couple of decades...
Then there should really have been two arounds for around to mean around rather than around.
CS70 wrote:
Just to make things more fun - it works also the other way:...
If I am hearing you correctly, you mean that it works only for you during recording, but not mixdown? I understand that all that's needed is the DSP to be anywhere, but the Apollo interface uses UAD DSP to process and then converts to analog-only out, correct?
I hope I'm wrong!
Thanks.
- solidwalnut
- Posts: 1 Joined: Fri Jan 24, 2020 4:01 pm
Life's too short to think you're all that.
Just to confirm what Hugh said I had a satellite as well as an Apollo back when they were giving satellites away free if you bought an Apollo. I had both on my iMac but as an experiment tried running the satellite alone on my Macbook Air. Plugins worked fine in Logic, no issues at all.
Last edited by ConcertinaChap on Sat Jan 25, 2020 1:23 pm, edited 1 time in total.
- ConcertinaChap
Jedi Poster -
Posts: 15240 Joined: Wed Jul 20, 2005 12:00 am
Making music: Eagle Alley
I am asking a similar question. I run Pro Tools 12 with an Apogee Element 24 I/O Interface. All works perfectly. I just bought the UAD-2 Accelerator to run more and better plugins.
My issue is, I just bought the UA Friedman Guitar Plug-in and it only seems to want to run within the UA Console App. You can't run it in real-time directly in Pro Tools, it has to be used in the UA Console App.
The problem is, I can't figure out how to get the UA Console App to find the Apogee 24 I/O as an input. So, my question is... do you HAVE to own a UA Apollo or similar UA brand I/O?
If this is true, then UA need to state that you CANNOT run this Plug-in unless you have their own I/O Interface.
I just emailed UA and they haven't gotten back to me.
Anybody have any info to help me confirm this?
Thx
Thx
- santellavision
- Posts: 2 Joined: Sun Feb 23, 2020 7:05 pm
santellavision wrote:My issue is, I just bought the UA Friedman Guitar Plug-in and it only seems to want to run within the UA Console App. You can't run it in real-time directly in Pro Tools, it has to be used in the UA Console App.
Are you saying it's not available as a regular plugin to put on an audio track? That's unusual, as I would have thought all UA plugins can be used as conventional track plugins. I just checked here and in Logic I can pull up any of the Friedman plugins and they behave just as regular plugins.
santellavision wrote:The problem is, I can't figure out how to get the UA Console App to find the Apogee 24 I/O as an input.
The Console app is for Apollo audio interfaces only. It's effectively the audio interface's mixer front end. You can't use it without an Apollo.
santellavision wrote:So, my question is... do you HAVE to own a UA Apollo or similar UA brand I/O?
No, the Friedman plugin is stated as requiring *either* an Apollo or UAD-2 DSP card.
santellavision wrote:If this is true, then UA need to state that you CANNOT run this Plug-in unless you have their own I/O Interface.
Well, I don't have an Apollo, and I can run it fine.
Note though, that this is only practical when inserting the plugin on playback. You can't really *record* through *any* UAD plugin because of the inherent latency in a DSP based system, which is much higher than regular plugins because of the DSP roundtrip to shuffle the audio to the card, get it processed, and then returned to the host.
This is a big reason why the Console app was developed, as with Apollo interfaces, they have a custom low latency system to get the audio processed via plugins with Console *before* being sent to the host, which minimises the latency and makes realtime tracking through these plugins workable. Without an Apollo, UAD plugins should be really regarded as mix-only plugins, because of the high latency.
- Watchmaker
Frequent Poster - Posts: 1319 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
