Guitar Harness Strap?
Does anyone have experience of a harness strap system that distributes the load over both shoulders? Any recommendations or cautions? Thoughts please.
Thanks, Jathon.
Thanks, Jathon.
- Jathon Delsy
Regular -
Posts: 205 Joined: Fri Dec 05, 2014 12:00 am
Re: Guitar Harness Strap?
similarly curious about this...... I suffer from nerve pressure issues when playing my heavier guitars , i have largely had to move to Ibanez S Series derivatives for the lighter body weight, but i would really like to be able to play my Jem "live" again....
- Studio Support Gnome
Frequent Poster - Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help, if not.... Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
I used to get a sore shoulder and even back strain due to playing guitar with the conventional strap that fastens to the top of the body.
But then I had a revelation! I was watching how Wes Montgomery wore his strap with that big L5 guitar of his. He did it old school style where you tie the strap (using a shoe lace) to the head.
https://www.youtube.com/watch?v=HmUUi6wGwRA
This is WAY more comfortable for me. So I redid all my guitars this way and never had a problem since. I used to get fatigued after an hour or so, but with the strap on the head I don't get any shoulder or back fatigue even after long sessions.
Worth a shot if you have not tried it.
I also much prefer the position that the guitar is in this way too. It is much more natural position for me either standing or sitting.
Hey and if it was good for Wes...
- DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am
Jon Gomm (the body slapping, fret-tapping, mid-note-tuning chap) uses a strap that goes from the end block and then splits to go over both shoulders. I suspect he makes them himself but nowadays he may have them made, in which case just drop him a line on a social media network of your choice, he's very responsive (as well as being a generally good bloke).
Designed for bass but will work with a guitar: http://www.bassgear.co.uk/product/sling ... ess-strap/
Though this one may move a guitar back a bit, bringing the headstock a bit nearer and make picking and palm muting etc. less comfortable
More difficult to make it adjustable enough in leather. Could probably be done in a soft suede, but then they'd probably charge double for it and have very few buyers.
Looks like Slinger also make more alternative straps. Not sure I'd want to modify an expensive instrument with a strap button on the lower horn though.
https://www.slingerstraps.com/hip-strap-guitar-strap.html
This one looks a bit better and takes some of the load on the hips. https://www.slingerstraps.com/sling-str ... strap.html
Or you could stand under a metal frame, hang the guitar from the frame, and have no stress on your back at all, even with the heaviest Les Paul or SG2000 you can find.
If you have several guitars, get a bigger frame and have them arranged like a Newton's Cradle.
Nice idea, but it'll cost a fair bit to put the hinges / spindles in for you to go 'waaaahhhhhhh' ...
Wonks wrote:Designed for bass but will work with a guitar: http://www.bassgear.co.uk/product/sling ... ess-strap/
This would have the added bonus of holding my belly in as well!
