USB 3.0 Hubs for general and DAW usage. What are the issues?
Re: USB 3.0 Hubs for general and DAW usage. What are the issues?
Post by Agharta »
I have a workaround as I decided to change PC and the new one uses the same Dell dock but has two ports on the tablet part of the 2-in-1 whereas the old one has none so I am two ports up. Yay. :)
Thanks for all the replies as it may become an issue when working without the dock.
Agharta
Posts: 4350 Joined: Sat Oct 30, 2004 12:00 am
Post by IvanSC »
Agharta wrote:
Rich Hanson wrote:It appears to be this one: https://www.amazon.com/Koutech-13-Port- ... B0015BR7KO
Some mixed reviews there, but it's worked for me for over five years now.
Thanks, but I need USB 3.0 as I am connecting an SSD.
Not necessary. I regularly connect a USB3 external drive via my USB2 powered hub.
Blew one of my 3 port completely and the second one is a bit iffy - mostly through my failing to allow for just how much power two external drives would pull, especially if one of them had an "optional" 5volt input socket! - so I am reduced to 1.5 working USB 2 sockets.
At the last count I had the 2 external drives, a Babyface, a wireless mouse and a couple of dongles running happily off a USB2 powered hub
IvanSC
Posts: 3041 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime,  please!
Post by Agharta »
Not necessary.
It is if you want to utilise the speed of the drive which I do otherwise I'd use a HDD.
Agharta
Post by Scoox »
damoore wrote:I use a powered USB 3 hub in my live setup with two keyboards, a pedal to (USB) midi convertor and my USB interface all attached and have seen/heard no problems at 128 sample buffer size (the interface won't go any faster even directly connected)
I was expecting the interface to not like being driven via the hub but it seems just fine. Of course, I am only running two channels of audio.
We'd love to know what hub you are using!
Scoox
Posts: 11 Joined: Tue Apr 17, 2018 12:17 pm
I use an Orico 12-input USB3 hub for all my studio synths. No problems here so far.
I wouldn't connect an AI via a hub - that always gets a dedicated input.
The Orico devices were recommended to me, and so far I'm happy with them For some reason the 12-input model seems to have disappeared from outlets.
I've just bought a 10-input Orico hub for live playing, since many laptops now feature only 1 or 2 USB ports. When I've run it in anger I'll report back.
