Transferring 78rpm records
Afternoon all,
I've got a bunch of old Welsh language 78s here that I'd like to transfer digitally. I've fitted a suitable stylus to my Pro-Ject turntable, and did a test recording of the first out of the box. Here we are:
https://soundcloud.com/sbrigynymborth/g ... ve/s-xiUlu
Clearly, the noise and crackle are quite extreme. Is this part and parcel of transferring such old shellac records, or are there great improvements to be had by cleaning the records some way or other? Could it be that the turntable/tonearm/cartridge is not setup correctly?
The recordings are mono, but the cartridge outputs stereo. Naturally, there is only noise/crackle present in the sides signal, so removing that has made a fair bit of difference, but as you can hear it is still very present!
I'm not expecting miracles, I'd just like to know what's realistically feasible with these things before resorting to software processing.
Aled
Aled
- Aled Hughes
Posts: 2136 Joined: Tue Oct 24, 2006 12:00 am
Re: Transferring 78rpm records
It doesn't sound too bad (for a 78) to me. Much of that noise is above the useful frequency range of a 78 so a simple low pass filter would help if you don't have any decent software processing. However, I seem to remember that you have a copy of Audition and, if so, it should be able to remove most of those crackles for you.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am
James Perrett wrote:It doesn't sound too bad (for a 78) to me. Much of that noise is above the useful frequency range of a 78 so a simple low pass filter would help if you don't have any decent software processing. However, I seem to remember that you have a copy of Audition and, if so, it should be able to remove most of those crackles for you.
Thanks James. A low-pass set around 8kHz does indeed improve things, without getting in the way of the wanted audio too much.
I don't have Audition, but I'll have a look at what Reaper has beyond what I normally use.
Aled
- Aled Hughes
Ramirez wrote: I don't have Audition, but I'll have a look at what Reaper has beyond what I normally use.
I don't think that Reaper has anything that would help. RX Elements is probably the cheapest way to get decent de-click software at the moment (I think they're doing a $99 offer at the moment although it goes even cheaper sometimes).
Ramirez wrote: Could it be that the turntable/tonearm/cartridge is not setup correctly?
You could play them back using the correct EQ. Search for Decca EQ turnover values.
I'm All Ears.
Thank you gents. I'm reasonably happy as is, and I'm not doing anything destructive to the original transfers, so I can always go back.
I'm enjopying listening to them anyway - here's a series of 3 records of Welsh folk: https://soundcloud.com/sbrigynymborth/s ... ry/s-bC13X
Aled
Aled
- Aled Hughes
Try to imagine it's the crackling sound of a welcoming Welsh fireside hearth & it ceases to be annoying. Unless you've been visited by Meibion Glyndŵr...
I'd leave it as is personally, there's plently on the Vocalion label in this condition, but also some restored versions that have had the life 'restored' out of them. Now where's that Pennies from Heaven DVD boxed set?
- Dynamic Mike
Longtime Poster - Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
If the Samplitude Pro X3 Bargain Bundle is still on offer there is some stonking cleanup software in that.
Had a harken and a bit of a play with Sam's de-crackler but I don't have the experience not to alter the original sound . To be honest the noises did not bother me so much as the distortion on peaks? Might be a tracking error but IIRC 78s were pretty hot! Maybe the pre amp front end is overloading? Job for a Quad valve jobbie?
ef37a wrote:If the Samplitude Pro X3 Bargain Bundle is still on offer there is some stonking cleanup software in that.
Yes, it's still on offer - I got another e-mail from them yesterday.
- John Willett
Longtime Poster -
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am
I agree the basic transfer sounds fine. Declicking really helps though. It's the basic "restoration" tool for 78's and these days can be bought for very little. Declick first before any low pass filtering. Maybe try a couple of demo Declickers.
- Tim Gillett
Frequent Poster - Posts: 2707 Joined: Wed Jan 30, 2013 12:00 am Location: Perth, Western Australia
I recently cleaned up some old cassette tapes that sounded very hissy and crackly quite well using RX Elements plugins, it's pretty effective for the price. You could always download and use it in trial mode for free:
But I agree that you've done very well so far and there's some lovely music there, thanks for the link.
For the first 10 days after installation, an unauthorized plug-in can run in Trial mode, which offers full functionality with no restrictions*. After 10 days, the plug-in will continue to run in Demo mode. In Demo mode, the plug-in's output will mute briefly every 40 seconds. Aside from this periodic silence, there are no other limitations in Demo mode, and both Trial and Demo mode offer the same feature set as the authorized plug-in.
*Saving and Exporting will be disabled for standalone applications, such as RX 6 and Ozone 7, in Trial and Demo mode.
- ConcertinaChap
Jedi Poster -
Posts: 15248 Joined: Wed Jul 20, 2005 12:00 am
Making music: Eagle Alley
I think this is my favourite so far! https://soundcloud.com/sbrigynymborth/s ... es/s-WzPuw
They're all tunes I remember from my childhood... to hear them played by the LSO is quite something! Magic.
I wonder how much hassle it would be to get them re-released on my own little label...
Thanks for the further comments - I think iZotope RX Elements could be a worthwhile investment.
Aled
Aled
- Aled Hughes
If you want to dabble in Reaper, try the ReaFir plug in. Use the "Subtract" mode and grab a sample of the record noise by itself (lead-in or lead-out grooves). Subtractive EQ, used judiciously, can be quite effective. There are several YouTube videos about ReaFir. The best free click removal tool I have found is in Audacity. You could process the crackle in Reaper and then master in Audacity for pop/click removal and final normalization. I do this quite a bit when digitizing records for broadcast on my community radio station. Best of luck!
- jimjazzdad
Regular - Posts: 310 Joined: Sun Dec 15, 2013 12:00 am
Halifax, NS, CANADA
Andrew Rose has been transferring 78's and selling the digital version for a few years now. There's even an SOS article about him at
https://www.soundonsound.com/techniques ... recordings
Ramirez wrote:I think this is my favourite so far! https://soundcloud.com/sbrigynymborth/s ... es/s-WzPuw
If you like the piece there's quite a good vinyl version of the Williams on a record from MFP in 1969 by the NYOW with Arthur Davison. And another by Royal Ballet Sinfonia conducted by Andrew Penny on Marco Polo from about 1999/2000ish.
The LSO/Mansell Thomas version is public domain and available all over the place but there's also a 1974 LSO version with Charles Groves which was on HMV but might be easier to find on a 1995 Lyrita CD re-issue.
The Beeb also had a good version available from a live concert at St David's Hall a couple of years ago with the BBCNoW under Tecwyn Evans. They also did a rather good performance of her Trumpet Concerto and and not so great performance of the Missa Cambrensis.
Not that I'm a bit of a Grace Williams fan or anything.
Last edited by forumuser840717 on Thu Apr 26, 2018 11:08 pm, edited 1 time in total.
- forumuser840717
Regular - Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
