Logic and Mac FAQ threads......
Re: Logic and Mac FAQ threads......
Post by The Dan »
Good day!
I've got one for you. I'm just starting out on a mac and DAW's in general and read in my M-Box/Pro-tools instructions that I : - 'Shouldn't save music files on system archives and a new archive should be created for music', so being a total unabashed noob a couple of questions popped into my confused little head .
1) Does this mean I should partition my drive and is 'partitioning' the same as creating a new archive? I have been a PC user for a little while so partitioning is sort of familiar to me.
2) What should I keep in the audio section of my hard drive? Just music files or Sequencers, sample libraries, plug-ins and all the other crap too?
I intend to mainly use my mac for music but I want to get into Carbon and C-sound as well. So I guess on the audio side, 200 gigs should cover it.
Thanks for your time!
The Dan
Posts: 4 Joined: Sun May 28, 2006 12:00 am
Post by bezdevil »
hey, just converted to mac and im having a few n00b troubles
1) How do i install and use other AU/Vst plugins in logic express. I installed the programs as per normal and i have .component files and a few .vst for the vsts, but i cant get them to appear in logic. The main program im trying to get working is EZ drummer DKH.
2) Similarly, i have extra inserts and fx plugins, again, in the right folders and installed but not appearing
Cheers
bezdevil
Posts: 1 Joined: Tue May 22, 2007 12:00 am
Post by monosyllabic »
VSTs don't work in Logic. Logic is an AU host only.
Audio Units (.component) need to be installed in Library/Audio/Plug-ins
If plug-ins aren't appearing you can get Logic to rescan through the preferences menu. Logic should scan new plug-ins at every startup. If it's not finding them you may need to reinstall some of the Logic librarys.
SJ.
monosyllabic
Posts: 48 Joined: Fri Apr 06, 2007 12:00 am
Post by brian c. »
hi
i'm running a dual 2ghz mac g5 (4years old) with logic 7.2.I want to link it to a windows machine so they both sync within a song within logic-running the audio through the analog inputs on my motu 828 mk 2.Is this possible with a timecode generator ? having the logic mixer recieving the windows inputs into the mix and would it be possible to record the inputs as a audio file in logic?!!!!!! :crazy:
brian c.
Posts: 1 Joined: Sat Oct 20, 2007 12:00 am
Post by EXTRAKT LIVE »
1) how to install plugins in logic pro 8?
2) how to convert vst to AU?
3) how to rewire it with live ableton?
Thank you
EXTRAKT LIVE
Posts: 1 Joined: Mon Nov 05, 2007 12:00 am
Post by Neil C »
EXTRAKT LIVE wrote:1)
Thank you
You can get vst to au converters like this:
http://www.fxpansion.com/index.php?page=5&tab=22
But they only work if you have, in the case of a mactel, a UB version of your VST - in which case there's very probably a straight AU version of it anyway.
There is no way of converting a Windows vst to an au.
Neil C
Posts: 461 Joined: Tue Apr 01, 2003 12:00 am Location: Under a PlopEgg
Post by Jüsme »
helloooo
hey has been a whiley since i last was in, but i have discovered something a bit weird going on in logic 8 and am not sure what to do about it, but its doing my head in a bit now :-Z
goes something like this;
I have created a couple of instruments for a track using the ESX24 sampler and when i open logic, the instrument looses the link to the audio files being used, even though I previously saved the instrument with settings. My audio files are located in the "audio" folder under the same host folder as my project, so Im presuming they should be found automatically.
The only way Ive found so far to resolve it, is to open the esx and re-load the instrument settings that I saved, and then re-point each part of the instrument to the corresponding audio files.
Does anyone know how I could resolve the problem or is this a possible bug?
ta in advance
Ju
02/04 Radio SugaThomp! @ www.nubreaks.com
04/04 Liquid Dragon @ Tiggars, Exeter
11/04 CLUB SugaThomp! @ The Hub, Exeter
Jüsme
Posts: 5 Joined: Fri Oct 12, 2007 12:00 am
Post by Studio Support Gnome »
they're in the wrong place..... the audio folder is intended for the audio tracks recorded..... the EXS24 instrument referencing the audio samples , and ideally the audio sample files themselves, , or a shortcut to them, should be should be in the ESX instruments sample library folder
mac HD>Library>Application Support>Logic>Sampler instruments.
is probably best....
Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help,  if not....    Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Post by Jüsme »
will try it tomoz and see how i get on.
ta
Jüsme
Post by Jüsme »
hiya max
just to let you know I re-saved my project with the esx files in the sampler instrument folder as you advised and its working fine now. thanks! :thumbup:
Ive managed to unearth another problem now though hehe...
ive hooked up my juno 106 to the mac (1/4 jack from the "phones" port to line-in), then mac mic out to amp. Am trying to nail a decent bassline out of the juno, thought I could fire up logic and play my audio Ive already got recorded, then record the audio from the keyboard at the same time, only snag is when i play a section on the juno, i hear two instances of it :-S i dont think its latency as it would only play once...??
if anyone has any ideas, they'd be very gratefully recieved
Ju
Jüsme
Post by DaleSmith »
Hey. I searched the forum and wasn't able to find help with my problem.
Picture the scene. I have Logic 8. In a session I have an acoustic guitar. 3 tracks. 2 close mic's and a room mic. all 3 are at different levels ( as you might expect ). All 3 tracks are in a group. Now as the song gets going, the acoustic needs to come down a bit, so, I draw some automation on one of the tracks, expecting the others to follow up and down by the same amount, as they are grouped, but what happens is, they all jump to the same level as the automated track. this happens as soon as I draw in the automation. Surly I don't have to un-group the tracks and write each automation separately? ( he asks hopefully!!! )
many thanks if you could help.
DaleSmith
Posts: 290 Joined: Tue Apr 29, 2008 12:00 am Location: Hull, UK
Post by muzines »
Yeah, grouping doesn't work like this. When three channels are grouped, you can write automation to all three tracks by using one fader. But each of the track tracks have independent automation - ie editing the automation in one track doesn't affect the automation in the other tracks (though automation updates with the fader will drag the others as well, and write their automation, providing they are in one of the automation write modes.)
The best way to achieve what you want is to send the three guitar channels to an aux, and then to the main outputs, and automate that aux for level changes. This also lets you put plugins on the bus to affect all the tracks that make up the guitar part if desired.
muzines
Post by DaleSmith »
Desmond. Many thanks for the reply. I won't waste any more time trying that then.. haha.. ok, here's another one.
I've just read in the Logic 8 manual that you can apply digidesign audiosuite plugins destructively in soundtrack pro2. The audio opens in Soundtrack fine, and the regular plugins are all listed, but i can't find the audiosuite plugins anywhere!! I looked on the apple discussion board but couldn't find a definitive answer. ( even tho quite a few people seem to be asking the same question )
Thanks again
Dale
DaleSmith
Post by muzines »
DaleSmith wrote:I've just read in the Logic 8 manual that you can apply digidesign audiosuite plugins destructively in soundtrack pro2. The audio opens in Soundtrack fine, and the regular plugins are all listed, but i can't find the audiosuite plugins anywhere!!
Where in the manual?
There is no mention of the word "Audiosuite" in the Soundtrack manuals, so it seems unlikely.
The only references to Audiosuite plugins in the Logic manual say that you can process audio using audiosuite plugins in the sample editor. This refers to Logic's inbuilt sample editor, *not* Soundtrack Pro, which is a completely separate application.
So it seems unlikely STP supports audiosuite plugins at all.
muzines
Post by DaleSmith »
sorry for confusion.
The reference to Audiosuite is in the Logic manual, not the STP manual. I tried the STP approach after seeing someone else on this message board say it was possible. I did originally start with Logic sample editor, but couldn't work out how to apply audiosuite, hence I started looking for other options.
How would you go about applying audiosuite in Logic sample editor? as the only mention on page 518 LP8 manual doesn't really help and i've never used audiosuite outside Pro Tools before..
Many thanks again for your time.
DaleSmith
Post by muzines »
Using AudioSuite Plug-ins
The Sample Editor allows the use of AudioSuite plug-ins. These plug-ins work destructively—the result of the editing process is written into the audio file.
Note: AudioSuite plug-ins can only be used with hardware addressed by the DAE (Digidesign Audio Engine). Any properly installed AudioSuite plug-in will be displayed in the AudioSuite menu.
Are you running Logic under DAE with Digi hardware, or are you running under Core Audio? You need to be running under DAE before any available audiosuite plugins show up.
muzines
Post by DaleSmith »
desmond wrote:Using AudioSuite Plug-ins
im running under Core Audio!! Many thanks for that. I have Pro Tools M audio on my Mac with an M-audio Fast Track Pro. I wouldn't have worked it out myself. I'll have a tinker tomorrow.
Thanks again ..
Dale
DaleSmith
Post by muzines »
DaleSmith wrote:im running under Core Audio!! Many thanks for that. I have Pro Tools M audio on my Mac with an M-audio Fast Track Pro. I wouldn't have worked it out myself. I'll have a tinker tomorrow.
Pro Tools M-Powered is not Pro Tools, it's a cut down native only version that works with regular audio interfaces. The full ProTools, powered by hardware, works under DAE. This is the mixing engine underneath Pro Tools.
You cannot use AudioSuite plugins in Logic with your version of ProTools M-Powered, as far as I'm aware (I'm not a PT user).
muzines
Post by DaleSmith »
thanks for that mate. would have still been banging my head against the screen now...
regards
Dale
DaleSmith
Post by Chris No.1 »
1). What speed of CPU is recommended as a minimum? (Duo-Core at least of course...2ghz? 2.1? 2.4?
2). Minimum Amount of RAM for using Logic (>insert other DAWS here<) as well as a dual boot with XP or Vista.
3). How do I install my VSTs on a mac?
4). If I run all my sessions etc on a external hard drive will it run smoothly or can I easily run everything off the built in one?
5). "Im a MAC noob and mine just arrived today, what essentials should I download immmediately to save me time and stress later? I will be using Logic 8 and PT"
there's 5 FAQ?
Chris No.1
Posts: 177 Joined: Fri Sep 12, 2008 12:00 am
Post by RemoHead »
Hi guys, hope this is the right place for this question!
its dumb but its been bugging me forever!
is there any way of adding my own channel strip icons to Logic Studio 8? im sick of constantly looking at the bog standard kick and snare icons and noticed a while ago in a youtube video someone had some custom icons but i can't figure out how to do it!
Hope you can help me!
Chris
RemoHead
Posts: 228 Joined: Sat Feb 07, 2009 12:00 am Location: West Midlands, UK
Studio Engineer & Session Drummer
www.thedenstudios.com
www.chris-drums.com
Post by muzines »
Yes.
Page 196 in the main Logic manual, under the heading "Creating Your Own Icons" documents the procedure.
RemoHead wrote:its dumb but its been bugging me forever!
Forever? It didn't occur to you to open the PDF manual, type "icon" in the search field, and click on the first result? Took me all of 12 seconds... considerably less than "forever"... ;)
muzines
Post by Maestro_T »
I think it's great that this FAQ has been place here, but I have a 'biased' suggestion. :blush:
I'm still not that OK with Logic, so along with the FAQ (Frequently Asked Questions), can I suggest a different FAQ? (Frequently Answered Questions) :lol:
Not trying to be awkward, but this set of good questions doesn't have any answers. :beamup:
If I'm wrong, (and I am quite often) please point me to the aswers section.....
T
Maestro_T
Posts: 82 Joined: Sun Jan 20, 2008 12:00 am
a fair point ;)
many of these have been answered in other threads.... and i have been somewhat lacking in my diligence in collating such things.... time is the enemy of many things... including sorting this lot out....
Desmond deserves a whole bunch of medals for his tireless and rapid answering of many things..... ;)
Post by ZeuZ »
Not a question, more general advise ... I've downloaded "QuicKeys" for mac, which automates universal keyboard commands on OSX, so every five minutes I've programmed it to autosave for logic to save me the hassle.
There's probably an easier way to do this?
ZeuZ
Posts: 100 Joined: Sat Sep 06, 2008 12:00 am
