Using Dual Monitors (older PC)
Post by Elephone »
Hello. My PC is about 8 years old. I don't remember requesting dual monitor support when I ordered it from PC Specialist, but I'd like to use my spare monitor for the (Reaper) mixer and/or effects.
The PC has two VGA ports, but in different locations. I've occasionally plugged my monitor into the upper port and the monitor showed 'No Signal', but works in the lower port. I presume the upper port is on the motherboard and the lower one is for the video card.
Would I be able to use the motherboard port to support the second monitor? If not, will I have to install a second/different video card?
Thanks in advance.
Elephone
Posts: 1114 Joined: Wed Feb 11, 2009 12:00 am
Re: Using Dual Monitors (older PC)
Post by Agharta »
I don't think you can mix and match between onboard and discrete video outputs so you will need to buy a new Graphics card unless anyone knows different?
If you can say what system or motherboard you have and what version of Windows you are rung that might be useful for those offering advice.
Agharta
Posts: 4350 Joined: Sat Oct 30, 2004 12:00 am
Post by Elephone »
Agharta wrote:I don't think you can mix and match between onboard and discrete video outputs so you will need to buy a new Graphics card unless anyone knows different?
I'm running Windows 7. The motherboard is Acer (Intel i5) but I don't have the full details with me. I could probably get a dual video card for it for peanuts now anyway. Cheers
Elephone
Post by Pete Kaine »
Acer make motherboards? :o
That aside, check the onboard is enabled in the BIOS.
What chip is it? Does it have a GPU on it?
You can mix and match onboard and add-in cards to some degree, although it does tend to end up coming down to the individual boards level of support for it.
Pete Kaine
Posts: 3217 Joined: Thu Jul 10, 2003 12:00 am Location: Manchester
Post by Elephone »
My PC:
Motherboard: ASUS® P7H55D-M EVO: DDR3, 2 x USB 3.0, 1 x PCI, 2 x PCI-Ex 2.0
Intel® Core™i5 Processor i5-750 (2.66GHz) 8MB Cache
Memory (RAM): 8GB CORSAIR DDR3 DUAL-DDR3 1333MHz - LIFETIME WARRANTY!
Graphics Card: 512MB NVIDIA GEFORCE 210 PCI EXPRESS
2nd Graphics Card: NONE
I might want to do video editing stuff soon, but I'd be looking for the cheapest card to enable dual monitors.
I found an "MSI GeForce GT 1030 2GH LP OC Low Profile Graphics Card - 2 GB GDDR5 - 64-bit - 1265 MHz" selling for £24.39.
There's also the "ASUS GeForce GT710-SL-1GD5 Graphics Card - 1 GB GDDR5 - 32-bit - 954 MHz" for £25.99.
Thanks
Elephone
Post by Elephone »
Oh! I just looked and apparently my card supports multiple monitors:
https://www.geforce.com/hardware/deskto ... ifications
I presume I just use the DVI (or HDMI) port for one screen and the VGA port for the other.
Elephone
Post by Agharta »
Elephone wrote:Oh! I just looked and apparently my card supports multiple monitors:
The chip does but it is up to the manufacturers to support all the features which they don't for all cards especially for the low end OEM market.
If the card has two physical outputs then you should be fine.
Do check the maximum resolution supported per output type which was stated in the link you gave.
Agharta
That's what I do. DVI defaults to monitor 1 with VGA going to 2.
Ah! My video card has 2x VGA with HDMI in the middle, could I use all three? (Asus M5A97 LE R2.0)
I would expect so. Plug in and see what happens. :)
ef37a wrote: Ah! My video card has 2x VGA with HDMI in the middle, could I use all three? (Asus M5A97 LE R2.0)
Are you sure?
From what I can recall, most of those 210's had 1x VGA, 1X DVI, 1X HDMI with the DVI and HDMI sharing the same digital clocking. That meant you could only use one or the other along with the VGA, meaning 2 outputs out of 3 running concurrently.
Pete Kaine
Are you sure?
You are right Pete! I had not looked at the connector in years and assumed it was VGA, 'tisn't it IS DVI.
But! How did you know? That MOBO does not have on board graphics, a fact that hissed me off greatly when it arrived and proved it not quite such a bargain! I had to rush to Maplins and splash 30 quid on a passively cooled card.
Still, two out of three ain't bad, I am looking for a 22" ish TV because the monitor is not wide screen and Samplitude ProX 3 is a bit cramped. Never run two screens before, will be such fun!
ef37a wrote:But! How did you know?
Long answer: It was the last entry-level passive for a few generations and it stuck in my mind for being one of the last to share the digital clock, forcing you to make a port choice with the connections.
Short answer: Seen too many of the damn things.
Pete Kaine
Heh! Ok Pete, point taken, I shall take my ***t out of your life (grabs coat).
:lol:
Well, it was also cheap and capable, and I've probably personally sold a few thousand of them by this point. I have 2 on the test bench, a couple at home in the old parts box and 1 still active in my media server too... I think I've just hit the exposer saturation point.
Pete Kaine
