I'm about to move in to a new flat where the living area is a half attic space (diagram below) of about 137 m^3 or 4838 ft^3, which will also be home to my project studio.
In the past I have largely created and mixed my own or other's projects just for fun, but more recently I have been getting paid work, mixing some music, live recordings, sound for video, art installations, etc. This has been done in my previous home set-up which was treated with temporary, moveable bits and bobs.
In this case, I have complete control over the space and can do what I like, and since it's the largest space I've had so far, and on first clap when empty it seems to sound pretty good already, I'm considering the options, and whether and how to step up the professionalism of the set-up. I will largely be mixing rather than recording in the space, but there may be the odd time where I need to record acoustic instruments and voice.
So to cut to the chase, I suppose the usual advice which I have been reading up on works here too, but the space is a little awkward and I wondered if there were any comments on:
- best mix position (the right hand cuboids are the kitchen fittings and worktop)
- what to do about the skylights, both isolation- and acoustics-wise
- any call for diffusion/absorption suspended at height
- whether adding a sub to my Focal CMS40 (missing bottom octave) is feasible in this space and the minimum bass-trapping requirements if so, or whether continuing to judge the low end with headphones is still the best idea
- any other advice based on the diagram
cheers
P
