I/O Ping value changes randomly (Logic, RME, Focusrite)
Re: I/O Ping value changes randomly (Logic, RME, Focusrite)
Yes, well done Focusrite.
I wonder however if this is another case of the "Watchdog Effect"? You know the sort of thing, a badly served consumer battles a company for months (around 6 in this case) and then miraculously a solution is found when an organization with some public clout gets involved.
Fair play to Focusrite and I think most companies at some level want to give good service it is just that they have put in layers of "chits of girls" and "jobsworths" that defeat the common man.
Post by stormymondays »
ef37a wrote:I wonder however if this is another case of the "Watchdog Effect"? You know the sort of thing, a badly served consumer battles a company for months (around 6 in this case) and then miraculously a solution is found when an organization with some public clout gets involved.
To be honest, it took a while to get past the first line support and up to a technician that would understand the issue, and maybe SOS helped with this. In that case it's only fair, since I bought the unit on the strength of the SOS review :-)
Once that happened, everything was taken care of quite swiftly. When it took longer than expected for them to write new firmware, they sent me a replacement unit, and they even offered to send their top of the line interface instead, so no complaints on that front.
stormymondays
Posts: 103 Joined: Sat Jun 25, 2016 5:45 pm
Well ok, you know the hoops you had to jump through better than I. The genius that said "we cannot be responsible for problems with third party devices" needs sacking. ADAT (afaik) is an industry protocol, like USB (won't say Firewire!) and anything should work with anything else. In any case, ANYTHING you connect to a computer is "third party"! What if Dell & Co took the same stance?
The problem is I think the fact that "communication" has never been easier or cheaper and yet it is now often harder to contact a person in a company with any sense or authority than it was 30 years ago. Rarely is there a prominent email address and you often have to fill in a very nosy form. Orta be a law!
Post by lt668 »
Hi all, just considering buying an OctoPre, is there a way to check the firmware version, or is there a manufacturing date from which it should be fixed?
lt668
Posts: 2 Joined: Mon May 15, 2017 4:38 pm
