Dissertation (Compression Vs Musicality)
Post by JamesCherry »
Hey all, i am currently writing my dissertation on compression vs musicality in recent years.
I am looking for mastering engineers who would be happy to take part in an interview process and answer some questions.
There is also a quick 2 minute survey which you can go too through this link. This will be a massive help.
Survey Link -
https://jamescherry.wufoo.com/forms/zwtypvi0wgl256/
For the survey you'll need to listen to two files on these links and answer a couple of questions.
https://soundcloud.com/digitalmindsofficial/track-2
https://soundcloud.com/digitalmindsofficial/track-1
Really appreciate any help thats given. Would love to hear your views and opinions around the subject. Thanks,
James
JamesCherry
Posts: 5 Joined: Mon Jun 04, 2018 10:22 am
Re: Dissertation (Compression Vs Musicality)
Hi James,
Is the survey just for mastering engineers as well or are you looking for wider contributions?
Cheers
Drew
Post by job »
JamesCherry wrote:...my dissertation on compression vs musicality in recent years.
Is that a dichotomy? I think it's an erroneous one since they aren't mutually exclusive and one can also complement the other. I also think conclusions drawn from the statistics gained from a single track having 2 different levels of processing could easily be in error.
Good luck with your thesis though :thumbup:
job
Posts: 317 Joined: Wed Aug 03, 2016 3:12 pm
Might be better to edit the tracks down a bit as I didn't really fancy spending 10 minutes listening to the tracks all the way through. I also found the questions a bit strange - one person's over compressed is another person's raw and energetic so it might be worth re-phrasing that question into something that isn't so leading. It would also be good to level match the samples unless all you are trying to prove is that people usually prefer the louder version.
"Is that a dichotomy? I think it's an erroneous one since they aren't mutually exclusive and one can also complement the other. I also think conclusions drawn from the statistics gained from a single track having 2 different levels of processing could easily be in error"
There are other tests, surveys, interviews etc which I will be developing over a few months. However it wouldn't hurt to set up another similar test as this one.
JamesCherry
blinddrew wrote:Hi James,
Cheers
Drew
Yes, open to all.
JamesCherry
James Perrett wrote:Might be better to edit the tracks down a bit as I didn't really fancy spending 10 minutes listening to the tracks all the way through. I also found the questions a bit strange - one person's over compressed is another person's raw and energetic so it might be worth re-phrasing that question into something that isn't so leading. It would also be good to level match the samples unless all you are trying to prove is that people usually prefer the louder version.
Fair points, will take these onboard. As for level matching they were both level matched its the dynamics which are playing with the ears. Will double check them though.
JamesCherry
Post by Urthlupe »
JamesCherry wrote: As for level matching they were both level matched its the dynamics which are playing with the ears. Will double check them though.
...well it depends on what you’re meaning by ‘level-matchng’ of course.... 8-)
Loopy
Urthlupe
Posts: 615 Joined: Fri Sep 20, 2002 12:00 am Location: West Midlands/Pembrokeshire UK
As a start you could try adjusting them to give the same dB Lufs value.
