Pitbull guitar kits
Re: Pitbull guitar kits
Post by Jumpeyspyder »
Wow - looking good - are the scatch plate and truss rod cover wood ? - they look nice !
Shame that P90 looks a bit dog-eared ;) - sorry couldn't resist! :headbang:
Will there be a bridge pickup ?
Jumpeyspyder
Posts: 1359 Joined: Fri Jan 20, 2006 12:00 am Location: Yorkshire
Yep, plate, cover and knobs all wood. No bridge pick up though.
Posts: 28856 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by adrian_k »
Coming along nicely :thumbup:
How many coats of oil do you put on?
adrian_k
Posts: 3583 Joined: Thu Jan 30, 2003 12:00 am Location: Gloucestershire
Life energy is limited. The mind is insatiable. (Chuang Tzu)
Normally around 30, with the last 15 or so using Tru-Oil thinned with turps. Each coat is very thin, and with a light sanding every 4-5 coats, you don't end up with a thick finish.
Posts: 18714 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
About another 10 coats for the neck and bits, another 15 for the body, will take me up to 3000 grit. Then i guess a few more coats for luck and think about gluing it together.
Which will be the nerve-wracking bit...
That's the fun bit!
Post by garrettendi »
Looking good so far! :thumbup:
garrettendi
Posts: 3497 Joined: Sat Dec 10, 2005 12:00 am
"The blues isn't about feeling better. It's about making other people feel WORSE, and making a few bucks while you're at it." - Bleeding Gums Murphy
Post by SecretSam »
How do mass-produced natural-finish guitars get their surfaces done ? Even using illegal child slave labour, I can't imagine getting dozens of sandings and re-oilings done on a 300 dollar guitar. And that cabinet scraper thingy looks like it needs a lot of skill and practice.
Do they have something like a big electric wheel covered in sheepskin, and hold the wood against that ?
SecretSam
Posts: 2968 Joined: Tue Oct 29, 2002 12:00 am Location: Officially, I do not exist.
Normally a sprayed poly finish, sanded flat once then buffed to a shine on a buffing wheel. It's the finish that takes the most time on making a guitar, and contributes most to the price.
Satin finishes are a lot cheaper as the final sanding and buffing stages aren't required.
Post by adrian_k »
Wonks wrote:It's the finish that takes the most time on making a guitar, and contributes most to the price.
Probably true for mass produced instruments and custom electrics, but hand-made acoustics? Certainly lots of time spraying and sanding through the grades but probably not more than 50% of the build effort would you think?
It's definitely something most people underestimate.
adrian_k
I was thinking more about mass-produced electrics. I should have been broader in my scope.
I have to click on the image to view and it takes me to a page asking me to sign into Google accounts.
Posts: 13125 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
Is it about a bicycle?
Grrr, One day I will get images working on this site. But plainly not today. Sorry about that.
Post by Logarhythm »
blinddrew wrote:Grrr, One day I will get images working on this site. But plainly not today. Sorry about that.
Mostly visit this thread to lurk and watch your guitar take shape, but since I know you're an instagram user you can host pics there and link here. I've used this with other sites and tested as a "preview" post to verify that it works for SOS, but don't have anything even remotely topical to demonstrate the principle in a real post. It's a bit of a faff, but basic process is (from PC - no idea if/how possible from mobile/tablet):
Go to the "view post" option for the pic you want to link.
Use developer view (F12 key in most browsers I think).
That'll open a little area/window showing the code for the page. It should hopefully also open a little "find" box - use that to look for ".jpg" - basically takes you to the picture file components without having to read through the code for the entire page.
One or two of them will be stuff like your avatar, but the actual picture will be prefaced by some stuff with alt=" (text from your post)", followed by the hastags from the post, and then src=https://(some long address ending with the jpg extension you're looking for). This should be the link for the picture, so just copy that address. Can then paste into the address bar to verify it's the right image.
You can then just paste this into the img brackets from the SOS insert image thing.
After doing it once it'll make sense, and isn't as convoluted as it sounds ;)
Edit: Apologies if the how-to is a bit patronising. Just occurred to me that the average SOS poster is probably significantly more IT literate than me, so doesn't need the same level of handholding as my colleagues at work :D
Logarhythm
Posts: 1093 Joined: Fri Mar 30, 2012 12:00 am Location: On an intergalactic voyage to collect fresh electrons
Nope, you were right first time, handholding is very much required.
But all other things being equal it might just be easier to sign up to imgur!
Just a bit frustrating as on the pitbull forum I have no (well, almost no) problems posting photos from the google account.
It wasn't a very exciting photo anyway.
Next weekend will be approaching gluing the neck time though! :o
Trying the Logarhythm method (pun intended), does this work:
It does for me.
Excellent. Told you it was a boring picture... ;)
I've seen worse.
Prevaricating to avoid doing difficult things about gluing and drilling
[EDIT] OK, imgur links don't appear to work for me either. Here's a link to the gallery: https://imgur.com/gallery/Kn3ywSP
Last edited by Drew Stephenson on Sat Jun 30, 2018 11:28 am, edited 1 time in total.
That's because you are linking to the imgur page and not the image. In windows, right click and 'view image'. Then copy the web address. Unless it says .jpg at the end, the link isn't an image link.
So simple that even a wabbit can do it!
Doh! I naively assumed that the copy link function on the image would copy the image link.
How foolish of me!
Thanks Wonks. :)
I don't use Imgur, but it looks like it does have an image link function. But if it doesn't have a .jpg or .png or any of the other common image types at the end, it's probably wrong.
Post by adrian_k »
Drew that’s looking great! :thumbup:
Re images, I use imgur. I think I just click on the image in the gallery then use the ‘copy link’ button for ‘direct link’. On a phone at the moment so can’t check exactly.
adrian_k
