Double Track Guitar
Double Track Guitar
Post by JRocker »
Hope I'm in right forum was not sure if I should post here in mixing or recording forum...
Have recorded a double track rhythm guitar part. Problem is the second part is not the best so I have tried re-recording numerous times but cannot capture the "essence" and "spirit" of the first take, I always like double tracking as I like to pan my rhythm guitars left and right in stereo spectrum...but is there any way to copy the first part and paste it and make it work like a double tracked part? I remember reading somewhere once that it is possible to do this by adding a slight delay to the second part or just by moving the audio event slight forward...advise please.
JRocker
Posts: 141 Joined: Fri Jan 05, 2018 8:42 am
Re: Double Track Guitar
The most common method for adding a fake double is to add a short delay to the original audio. The original and the delayed parts are then often panned at opposite sides of the mix to enhance the illusion and to add width to the mix.
You can simply copy the original and delay the copy by moving it in your DAW, or you can use a delay processor (hardware, or plug-in). I would begin with a delay of 10ms and adjust it to taste - much more than 25ms and you will begin the hear the 'double' as a slap echo.
You can further enhance the technique by applying a slight pitch shift, or modulation to the copy. There are plug-ins (e.g. Waves' 'Doubler', or Boz Labs' 'Imperial Delay') that allow for all of this in the one package.
Post by CS70 »
Yes, you can delay the part a few ms (or nudge it forward, it’s exactly the same) and add a pitch shifter tuned to a few cents of difference. An auto-tuning pass also works. It gets you a chorusy feel. Whether or not it sounds how you want depends on the track but there’s no harm in trying.
Post by Sam Inglis »
What I generally do in this situation is create a fake double by duplicating the original track and then re-ordering it, for instance by swapping the guitar from verse 1 and verse 2, chorus 1 and chorus 2, and so on. As long as they're recorded to a click, most songs have enough repetition to make this possible with a bit of imagination! To my ears this sounds a lot more natural than any ADT or doubling effect.
Sam Inglis
Posts: 3229 Joined: Fri Dec 15, 2000 12:00 am
Post by Guest »
Sam Inglis wrote:What I generally do in this situation is create a fake double by duplicating the original track and then re-ordering it, for instance by swapping the guitar from verse 1 and verse 2, chorus 1 and chorus 2, and so on. As long as they're recorded to a click, most songs have enough repetition to make this possible with a bit of imagination! To my ears this sounds a lot more natural than any ADT or doubling effect.
I have used the delayed track option often, or used Logic's Sample Delay for the same purpose. However, beware - this effect needs a percussive element (essentially a guitar strum) to make the brain think it is hearing two distinct events. On sustained guitar parts, you'll hear the two signals drift back together. Try it and see (hear) for yourself. Sam's suggestion will eliminate this, because running a reordered guitar track alongside the original track features genuine events happening at different points in time and with subtly different tonality.
It is worth establishing a couple of fake double track techniques which work for you. As the OP mentions, sometimes a mono guitar track is just too damn good to repeat with precision. In fact, it's probably the lack the precision which makes it good in the first place!
Guest
Post by andrushkiwt »
Playing it again is your best option, though you can certainly do the above methods regarding playing with delay and time. If it's a chord-heavy rhythm section, try playing it slightly different - move up the neck or detune and play the chords transposed. It gives a nice change in tone while staying cohesive.
andrushkiwt
Posts: 1 Joined: Thu Jul 12, 2018 8:07 pm
Post by Terrible.dee »
Dude...listen to your ears!
DON'T DOUBLE IT
Today people feel obliged to "double this" "Triple that" "Layer these"
NO! YOU DON'T NEED TO DO ANY OF THAT!
If it sounds "right" with one guitar then your ears are telling you "That's it! We're good!"
LISTEN to them
Terrible.dee
Posts: 126 Joined: Tue Apr 18, 2017 9:12 pm
Post by JRocker »
Thank you all for the advice and replies, much appreciated and very helpful. Cheers.
JRocker
Terrible.dee wrote:Dude...listen to your ears!
DON'T DOUBLE IT
LISTEN to them
I LIKE that advice a lot Terrible.dee - I suspect you should change your moniker to Helpful.dee :clap:
Post by mick.n »
Would Sound toys micro shift be a good tool for this?
mick.n
Posts: 1017 Joined: Wed Sep 01, 2004 12:00 am Location: It's grim up north.
Post by 24Fretz »
I agree with this.
And doubling with delay never sounds good to my ears. You just get a phasey sounding version because of the comb filter effect, which makes it less punchy. Probably the opposite of what you want.
24Fretz
Posts: 3 Joined: Wed Jul 25, 2018 9:37 pm
Post by CS70 »
Not necessarily! Agree that there’s better ways nowadays using a DAW cut&paste capabilities (such as Sam's) but doubling is a tried and tested technique which usually involves also a delay on one of the tracks with a few cents of pitch shifting.
By varying the delay time with a knob and listening you can most often find a sweet spot where the filtering that occurs is actually pleasant.
Post by Humble Bee »
It's two different things really.
Fake doubling with a delay or nudging a copy a bit is very clean and more of a chorus effect. For this I like the UAD Cooper Timecube when mixing. Live I use the Strymon deco.
Laying down a second guitar track gives a more realistic sound of two separate guitarists playing the same part. It's more lively and fat (think Hellacopters f.ex) good for up tempo harder rock... and it doesn't have to be spot on. It actually sounds more groovy if the two are not 100% tight... and don't pan all the way apart to keep it more in your face up the middle.
Humble Bee
Posts: 395 Joined: Mon Jan 08, 2007 12:00 am Location: Cloughton Newlands
