BEL BDE 2500S sampler info
Post by Sparrows78 »
Hi all!
I'm trying to find some information about this odd piece from the 80s that a friend of mine acquired.
There is virtually no information about this particular sampler on the internet, no manual or documentation whatsoever.
I have found some info on the BDE 2400 and BDE 3200, but the 2500S seems to be a different beast with its stereo operation, 1U format and different button layout. It has the same look and feel as the much more famous BEL BD-80s digital delay.
Have any of you gear-experts seen or used this oddball before? Any information is greatly appreciated!
Sparrows78
Posts: 26 Joined: Tue Aug 07, 2018 1:12 pm
Re: BEL BDE 2500S sampler info
Have a feeling Paul White reviewed it for Home Studio Recording magazine back in the ‘80s. Samplers back then were developments of digital delays and used mainly for one-shot triggering.
Have a search on the Mu:zines archive website?
Only the BD-80 /80S and BD240 models showing on the Mu:zine site at present.
I tried to attach a picture in my first post but it failed, here it is again
Joseph Addison biography
Sparrows78
Post by phil kirby »
I'd get in touch with Bel. http://www.beldigital.com
I emailed Bel last year as I wanted a BD80 manual, which they kindly sent me. Phil
phil kirby
Posts: 7 Joined: Thu Mar 31, 2005 12:00 am Location: Earth
Post by muzines »
I’ll have a look through my scans when I get home to see if it was reviewed in any issues I haven’t got to yet...
muzines
Cool! thanks for the shown interest and fast replies!
I will try to get in touch with Bel Digital. I emailed them once about a service manual for the Bel BD-80S, they never replied, but maybe better luck this time.
Sparrows78
I don't think I have any info on the 2500 but I found an information sheet for the 3000 which looks very similar...
Posts: 16989 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by muzines »
I looked through the H&SR issues from 1986 (when the earlier model Bel sampler/delays were available) through to 1994, without finding any obvious articles (that's not to say there isn't references in the mags, but as they are not databased yet there's no simple way to search for this stuff yet...)
muzines
But well done for making the effort.
Posts: 13295 Joined: Thu Dec 05, 2002 12:00 am Location: Devon
James Perrett wrote:I don't think I have any info on the 2500 but I found an information sheet for the 3000 which looks very similar...
That actually looks spot on except for the name, you guys are really helpful :)
Sparrows78
Post by muzines »
I was reading on muffwiggler about a guy with an Bel BDE 1600-S, which he thinks might have been a prototype as various features don't work properly.
Just conjecture, but maybe your 2500 is a similar unreleased prototype of what eventually became the 3000..?
The Bel BDE 1600-S is a weird unit... At first glance it's a stereo version of the BDE 2400 / 3200, which were identical mono units except the 3200's memory was clocked at a lower rate to extend the delay time (at the expense of frequency response).
There's very little information regarding the 1600-S on-line; since acquiring it I've realised it's really more like a BD80-S (I used to own one that had apparently belonged to Vince Clarke), except that it has longer delay time (around 12 seconds vs. 6.5, but somewhat less than the 16 you might expect!) and it has the more advanced sample triggering and front/back sample editing features of the other BDE units.
My conclusion is that the 1600-S was released prematurely, or else mine is actually a prototype, as it has a number of bugs and unimplemented features. For instance, the mono/stereo button doesn't do anything, and the de-glitch button causes the machine to lock up. It also occasionally locks up at random, which I suspect is to do with the power supply.
It also has an intriguing ribbon connector on the back panel apparently for connecting an external (floppy?) disk-drive and storing the samples in memory; I've never felt masochistic enough to try getting this to work.
It's a true stereo unit, so you can't set different delay times for left and right channels, but overall I like it; it sounds great (basically identical to the BD80-S) and the triggering is fun to play with e.g. a modular sequencer.
muzines
