A little bit about the units:
The Tree Audio has a variable switch that "Controls input impedance of input transformer, selectable between 37.5 Ohms, 150 Ohms or 600 Ohms, nominal input for line input is 150 Ohms".
The Warm Audio has a Tone switch that drops input impedance from 600 Ohm to 150 Ohm, and strangely enough the manual recommends the 150 Ohm setting for ribbon mics. There's a long explanation about what it does in the manual.
The Golden Age has a Low-z switch that drops from 1200 to 300 Ohm.
My questions:
-Aren't most of these input impedances a bit on the low side, especially for ribbons?
-What does "nominal impedance" mean for the Tree Audio? 150 is mentioned as "nominal" in the manual for all uses: line, mic, DI.
-When/why would you use the 37.5 and 600 settings on the Tree Audio then?
-Why dropping the impedance increases gain? I know it has to do with transformer windings or ratio, but I don't really understand it technically.
-And lastly, to add to the confusion, I did ask Warm Audio about these a while back, and their reply was "The true impedances of the mic pre are 10 times the transformer impedance, so the TB12 truly is 1500 and 6000 ohms, not 150 and 600." So, does that reply apply to the other pres as well?
Mostly everything sounds good on any setting, I just want to understand the science/electronics behind it!
I hope some of this can be material for a future SOS article/question...
