Logic X EVOC vocoder bounce in place?
Any idea how I bounce a vocoder track to audio? Bounce in place doesn't work.
Re: Logic X EVOC vocoder bounce in place?
Most likely you are feeding in audio to the evoc from the sidechain from an external track or source, so when you bounce in place which *just* bounces the selected instrument to a region, the sidechain is not present and thus you get no audio.
Do a bounce+reimport in the usual way by soloing the evoc track and bouncing from the output, where the whole mixer is active, and the sidechain will be running, and then bring the bounce back in to Logic.
Thanks Desmond. Obvious now you've explained it.
