12v Adaptor Powering 18v Unit
Post by jimh76 »
Hi
I have recently bought a Samson c control unit, but the adaptor wasn't included (2nd game off eBay). The unit requires 18v A.C. at 1000ma. I already have a 12v A.C. at 1000ma adaptor and was wondering if this would work? I know it shouldn't blow it as it's less voltage, but just thought I'd ask before pluging it in.
Any thoughts?
Jim
jimh76
Posts: 102 Joined: Fri Aug 10, 2018 10:29 am
Re: 12v Adaptor Powering 18v Unit
It may work in some instances as it will be all-analogue circuits, but you'll be loosing headroom so you will get signal degradation. It may also try to draw more current than normal as it doesn't have its usual voltage, which could affect the 12v PSU. You can get a suitable PSU from eBay for around £10-£15 at most, so it's really not worth the risk or the effect on your monitor signal.
Posts: 19210 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Post by Rich Hanson »
What Wonks said!
You're highly unlikely to damage your Samson, but you do run a real risk of blowing up the PSU on account of the increased current draw (depends on the design of the PSU).
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
+1 except, it shouldn't draw more current from the PSU but less.
Posts: 22916 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
