How do you all track your vocals?
What do you use in your vocal tracking chain?
Preamp + Compressor
5
20%
Preamp + EQ
0
No votes
Preamp + Compressor + EQ
0
No votes
None - Just preamp directly into interface
20
80%
Total votes: 25
Post by dickiefunk »
Thought I’d post this as I’m curious to know how people track their vocals? Does anyone still use external compressors and or eq’s I’m their tracking chain or just go preamp directly into interface?
Is there still and place for using external compressors / eqs etc for the tracking stage?
dickiefunk
Posts: 2099 Joined: Fri Jun 17, 2005 12:00 am Location: Cornwall, UK
Re: How do you all track your vocals?
Post by Matt Houghton »
For my own voice just gentle compression. For others maybe EQ too but I'd usually try swapping the mic before that.
Yes 24-bit recording means you don't *have* to compress, but pretty much all vocals need some compression. Applying some on the way in means I start the mix with a better sound, it leaves me with less to do later, and it often makes setting up a good foldback mix easier too.
Matt Houghton
Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Post by Dave B »
You are missing an option - straight into the interface's mic pre. I don't bother with external pres these days. I do have one which is wired over sp/dif, but the psu went a few years ago and I can't be bothered to sort it out. My interface has Liquid pre-amps if I want colour. As for eq/compression ... nah ... again ... can't be bothered ...
Dave B
Posts: 5935 Joined: Thu Apr 03, 2003 12:00 am Location: Maidenhead
Post by Jack Ruston »
It depends
I almost never eq.
I typically aim not to compress either, because I often want to ride the vocal into the compressor, and while thats perfectly possible with a consistent singer, it's easy to do odd things to performance that is less predictable. I also find that people tend to sing better if they're hearing something that's as close as possible to what they're doing...but
If there's a compressor available to me that's going to impart something really special, that I can't achieve later, then I will try that. A good example would be something like an EAR, that is just beautiful, but also unlikely to do harm.
If it's a full on rock thing, where the compression is very much part of the sonic signature, I will usually do a lot of Distressor, or perhaps 1176.
If I do compress, it's rarely set and forget.
J
Jack Ruston
Posts: 3847 Joined: Wed Dec 21, 2005 12:00 am
Post by CS70 »
Depends on what and how, but either I use the LA2A section of the 610, or directly the interface preamps, so I voted for both :)
Mostly just straight into the interface, but occasionally, if i know i'm going to want to add some colour, I'll run a second mic through a little tube pre-amp.
Posts: 29722 Joined: Sun Jul 05, 2015 12:00 am Location: York
Post by ConcertinaChap »
I've never done anything to the signal when tracking, just recorded it. This is mostly because I don't think I'm clever enough to do it right first time. I'd rather EQ/compress/whatever after the event where everything can be undone. This is despite the temptations of a UAD interface which make this sort of think very easy with its unison preamps and whatnot. Wish I was cleverer ...
ConcertinaChap
Posts: 15246 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Post by muzines »
ConcertinaChap wrote:This is despite the temptations of a UAD interface which make this sort of think very easy with its unison preamps and whatnot.
You could always do some testing (or on a project) by recording two tracks at once, one completely dry, and one with a little bit of appropriate "colour" (project dependent of course), and see whether the benefits of running the signal through some processing on the way in is useful or not. Then you've always got the dry signal as a fallback and to compare with...
muzines
Post by John Egan »
dickiefunk wrote:Hi,
I've usually gone direct into the AI with no EQ or compression. However I recently bought a New Age preamp and have begun to use this. Still in the evaluation stage, though.
Regards, John
John Egan
Posts: 476 Joined: Wed Nov 27, 2002 12:00 am Location: Staffordshire, England
desmond wrote:You could always do some testing (or on a project) by recording two tracks at once, one completely dry, and one with a little bit of appropriate "colour" (project dependent of course), and see whether the benefits of running the signal through some processing on the way in is useful or not. Then you've always got the dry signal as a fallback and to compare with...
A good thought, though as I don't have two mics the same (not counting the SDCs) I wouldn't be able to completely eliminate that point of variation. Still, I'll probably try it. What's to lose?
Cheers,
ConcertinaChap
Post by muzines »
ConcertinaChap wrote:A good thought, though as I don't have two mics the same (not counting the SDCs) I wouldn't be able to completely eliminate that point of variation. Still, I'll probably try it. What's to lose?
No, I mean record the same signal on two tracks, but one copy going through the UAD processing on the way, the other dry. I would have thought you could set this up in the UAD control panel, but you'd have to investigate...
muzines
Oh, I see what you mean. I'll have a look but I suspect not because the way the console app works is you insert the Preamp emulation at the very start of the "strip", as it were, before you can direct the signal anywhere else because sends come after preamps. I could maybe send a signal off to one of the virtual channels and put a preamp emulation on that, but then I might as well do that in Logic.
PS happy as ever to take correction for anyone who knows better than me.
Last edited by ConcertinaChap on Tue Sep 11, 2018 8:06 pm, edited 1 time in total.
ConcertinaChap
If I'm recording digitally I'll usually keep things flat - although I may use a high pass filter if I think there's too much unnecessary low end. If I'm recording on tape I'll use a compressor on fairly gentle settings and eq as I think necessary but nothing too drastic.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by Watchmaker »
I go straight through my pres, but they're UAD and I have tons of DSP so I'm usually putting them through the Neve1073 plug in and then in my DAW I have Console 1 across all inputs and can do whatever needs doing using the native SSL emulations. I usually record dry after the 1073 though.
Watchmaker
Posts: 1319 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
Post by ore_terra »
Watchmaker wrote:I go straight through my pres, but they're UAD and I have tons of DSP so I'm usually putting them through the Neve1073 plug in and then in my DAW I have Console 1 across all inputs and can do whatever needs doing using the native SSL emulations. I usually record dry after the 1073 though.
Do you track through the console 1 emulations?
ore_terra
Posts: 1090 Joined: Fri Dec 02, 2016 12:56 pm Location: Seville - Spain
casmoestudio.com
Console 1 can control the UAD console app and as such can exercise some control over the UAD plugins when they're instantiated in the console app. However, so far as I'm aware the SSL emulation is native and can't be used when tracking. (Console 1 plus UAD make a very nice combination, BTW).
ConcertinaChap
Post by ore_terra »
I know... that’s why I’m asking ;)
ore_terra
casmoestudio.com
Post by Bob Bickerton »
I never use EQ or compression on the way in.
I record straight in using Audient or UAD pres and process in the mix.
Bob Bickerton
Posts: 5642 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
ore_terra wrote:I know... that’s why I’m asking ;)
True, but you're not the only one reading ( ;) back ... :) )
ConcertinaChap
Post by CS70 »
ConcertinaChap wrote:I've never done anything to the signal when tracking, just recorded it. This is mostly because I don't think I'm clever enough to do it right first time. I'd rather EQ/compress/whatever after the event where everything can be undone. This is despite the temptations of a UAD interface which make this sort of think very easy with its unison preamps and whatnot. Wish I was cleverer ...
I’m all for recording flat but since I got the 610 and experimented a bit, I found that on my own vocals a little compression on the way in saves me time at mixing time. The thing is that by now I know pretty well how the ‘base’ sound should be and the compressor to gently work on the way I gets me there already. The LA2A is optical and sounds good almost no matter what tough. But when I record others, it’s flat all the way! :)
Ore terra,
I do have several UAD plugins I can swap out on the Console 1 and I can put the Console 1 in either the input channel of my DAW or the track insert.
The way Studio 1 works is, if you have the plug in on the input, it'll record wet, if you have it instantiated on the channel, it's not recorded to the track though it is audible. So you can record the native emulations wet, depending on where you instantiate it.
It's a feature I like when trying to create ambience while tracking, yet leaving the flexibility to change my mind later, which happens often enough. I can commit by exporting a stem which also frees up the DSP resources for additional tracking.
Watchmaker
Post by sifer2407 »
If I track vocals with l22, no unison, sphere and daw. Lately mic, external pre, external compressor, (light compression) Apollo to daw.
sifer2407
Posts: 1 Joined: Thu Aug 17, 2023 3:58 am
Post by jaminem »
Depends on who im recording.
If they have god mic technique it'll be a test of which of my mics sound better into a Neve'ish preamp - I use an Avedis Audio MA5, but occasionally if I want aggressive its an API-a-like, straight in.
If they are a bit dynamic then I will subtlety compress - no more than 2db on the peaks using my Tubetech CL1-b
Very rarely eq on the way in, except this one guy I record who always has a harshness around 4K on his voice, so I'll duck that a little on the way in.
If I've never recorded someone before it's MA5>Tubetech just in case I get a great take that we want to use but they are dynamic/inconsistent in level.
jaminem
Posts: 1541 Joined: Mon Mar 19, 2001 12:00 am
My MOTU 828es interface has pre converter sends which allows me to both record dry and with a compressor simultaneously into my DAW. I love having this feature. I pretty much always prefer the take with compression but it’s great to have the original dry take aswell.
The compressor I use is a modded Klark Teknik KT-2a (Kenetek T4b optocell, Harma Retro tubes and Alpha pots). I don’t use a lot of compression but like the way the KT-2a shapes the tone.
dickiefunk
Post by jaminem »
Yeah I do a similar thing except I do it with a Slate VMS mic, so the singer is actually singing into 2 mics. the Slate goes straight into my RME interface. Then I have 2 options JIC
jaminem
