Can anyone recommend any free reverb impulse responses?
I use Freeverb3 as an IR loader, so they would need to be wav files compatible with that...
I've found the Wave's IR Convolution Reverb Library, but while I haven't downloaded it yet, it appears it's only compatible with their own IR convolver products...
Anyone have any recommendations?
- garrettendi
Frequent Poster - Posts: 3584 Joined: Sat Dec 10, 2005 12:00 am
Re: Can anyone recommend any free reverb impulse responses?
I had a shufti a while back for some lexicon ones but couldn't find any in wav format, but I did find some bricasti ones. Haven't used them yet. Next time I'm on the other machine I'll see if I can find them again but it might have been from a link in one of these threads. Worth a search.
Thanks Drew! Do you mean the Samplicity Bricasti IRs? I found them, not sure they're exactly what I'm looking for.
I'm more looking for reverbs created by actual say, concert halls etc!
- garrettendi
Ah right, as you were then. I just tend to use True-verb when I'm looking for something real-sounding.
Thanks Drew!
I'm wondering if I can actually use the Waves library with Freeverb. Does anyone have any experience with that library?
- garrettendi
Commercial IR reverb producers are highly unlikely to be happy with you using their IRs in anyone else's processor, so I doubt that you're going to enjoy any success in that direction.
Time to exercise your web searching skills I'd say.
Yeah forget what I said about Waves then!
I've found the OpenAirLib. That looks good.
- garrettendi
Wonks wrote:Or open your wallet!
All joking aside, that is a good point, but I have other more important things to buy for the studio once the wedding is done...!
- garrettendi
It's not quite AIR Lyndhurst, but this one is fun:
http://www.balancemastering.com/blog/fr ... nvolution/
They're IRs taken through a Funktion One rig in an empty nightclub! I gave them a listen a while back and they do exactly what they say on the tin. I haven't used them in anger yet, but if I ever want to add a bit of liveliness to a live recording that's lacking ambience/audience mics, they'll be the first thing I turn to...
Hi garrettendi,
Here are a couple of links with Impulse Responses of real-life acoustic spaces to be going on with:
https://www.voxengo.com/impulses/
http://legacy.spa.aalto.fi/projects/poririrs/
Posts: 22580 Joined: Wed Jan 13, 2010 8:44 am
Thanks guys! I'll check those out!
- garrettendi
Would have another listen to the Briscati if you can.
I have them in Logic's Space Designer and they are truly excellent - lots of real halls , beautiful plates and very realistic small spaces ; never heard a real Briscati myself but believe they are really rather good by comparison.
If you need realism on a budget then you owe it to yourself to have a play around and see what happens in the mix , might be just the ticket.
Thanks wdsteele! I'll give the Bricasti IRs another chance!
- garrettendi
