I currently have PMC TB2+ with the passive XB1 sub, powered by Flying Mole DAD-M100 amps. (I also have some Rega Kytes as secondary speakers for checking translation on systems with little low end, but very rarely use them.) I gather the 310s ought to be quite a step up (else I won't bother!).
So, a few questions:
1. Are the 310s likely to render the PMCs totally redundant? Seems it might be useful to hold on to them because: (a) I’ve had TB2s in my life for over a decade, and have them in my kitchen hi-fi and living room (TV/hifi) setups, so am well familiar; and/or (b) low end extension available with the XB1 sub (down to about 25hz – albeit that’s probably overkill for a room of my size – see pic – although it is extensively acoustically treated). Oh, and I’m notoriously bad at decluttering (need to Marie Condo my life!). But I guess there are upsides of losing the TB2s and the sub: their second hand value; creating space (the sub is huge); being able to keep the Regas (or I could have Dynaudio BM5s in their place); and not having the acoustic interference of the mounting options (see 2).
2. Space is limited, so if I keep both, positioning is likely to be tricky. See embedded pics below. What’s the best approach?
a. Mount the PMCs horizontally (rather than vertically - on their existing stands (tweeters outermost) and sit the 310s horizontally (as they are intended to be) on top. That should just about fit. This will put the PMC tweeters below ear level, which is sub optimal but their dispersion pattern is reasonably wide and they’d only be there as secondary speakers, I suspect seeing little use. I don’t know whether/how much horizontal mounting of this PMC two-way speaker is an issue. I’m guessing in this scenario it might be useful to put blue tac (or mouse mats or MoPads or something else?) between 310s and the PMCs (and between the PMCs and the stands, as I do currently).
b. Leave PMCs where they are and replace Regas with 310s, mounted horizontally. To get them to fit (they’re much bigger than the Rega’s – basically the same size as the PMCs but a 5cm wider), I’d need to bring the stands forward to create space for them and toe them in a fair bit. . They’d be quite widely spaced, but with rockwool to their immediate sides, so the sweet spot would be further back. That’s not really too much of a problem as I have a 42” screen and can sit further back, and the 310s are kinda between near- and mid-fields. Albeit you hear more room in the mix the further back you are…
c. Third option would be to mount the 310s vertically on the stands the PMCs are currently on (I’ve not seen the 310s mounted vertically… is that an issue?). And I might just be able to squeeze the PMCs mounted horizontally onto the stands the Regas are on (again, bringing the stands forward a little).
Wide angle lens view (apologies for the mess!)
http://tinypic.com/r/2d8ggsj/9Close (right)
http://tinypic.com/r/29p6h00/9Close (left - showing stands)
http://tinypic.com/r/mmardv/9Normal full view
http://tinypic.com/r/9gk7s5/93. Is there anything else I should be giving serious consideration too / anything in the up to £3k bracket worth considering instead? The 310s appeal as their active, 3 way and sealed, so quite different to the TB2s, and seem to have amazing reviews.
FYI, the PMCs are currently mounted as per the diagram below – supposedly technically the “correct” place for this room (2’11” from side walls, 3’3” from the rear wall, measure to the front edge of the cabinets; optimal listening position is purportedly 6’11” from the half wall in front. (Ignore the couch - there is no couch!)
/ http://tinypic.com/r/ws0f8z/9The room dimensions:
/ http://tinypic.com/r/5w00gw/9Many thanks in advance!
Dan
