Help! My new audio interface isn't picking up sig from mic!
Post by Gideon26 »
I just received my first audio interface in the mail yesterday. It is the Behringer U-Phoria UMC404HD. I was going to hook up my mic (Excelvan BM-800) and do a quick test recording today, but when I had everything ready and plugged in I never got a signal from mic and wasn't recording anything. I am new to this sorta thing so I think it's a user error :tongue: and I must have done something wrong while setting up even tho I've tried to find the problem countless times. Is there certain steps I must take for it to work? Am I connecting things right? I am using Garageband on Mac OS (Mojave). I will try to give more detail but not sure what people need to know. I am 15 and just starting out, so I would greatly appreciate any help I can get.
Gideon26
Posts: 18 Joined: Thu Nov 08, 2018 1:51 pm
Re: Help! My new audio interface isn't picking up sig from mic!
Have you switched phantom power on? It's the switch marked +48V on the back. Can you play anything back through the interface? Can you play something from Garage Band through the interface (a virtual instrument maybe)?
edit :- welcome to the forum BTW :thumbup:
Hi and welcome to the forum.
Two main point to check:
1) The microphone requires 48v 'phantom power' to work. It is a capacitor mic, which has electronics inside to amplify the signal from the diaphragm. This is done by supplying 48v dc along two of the wires inside the XLR cable to the mic, with the 0v return connected to the cable screen.
(Dynamic mics don't need phantom power but have a lower output)
There is a switch on the back of the UMC to turn on the 48v dc power. This turns on the 48v phantom power to all 4 mic channels. Turn the input gain right down, connect up the mic, then turn on the phantom power, then turn up the mic gain. Turning on (and off) the 48v always gives a loud 'pop' so have the headphone and/or monitor sound turned down as well when you do this. Always best to have the 48v turned off when connecting or disconnecting mics. There is a small LED on the front of the UMC to indicate when the 48v power is on.
2) The mic is a 'side address' mic, that is, you speak/sing into the side, not the end, of the mic (as the Excelevan picturse imply). You also have to speak.sing into the correct side of the mic, and this is normally the side with the mic name on.
Sam Spoons wrote:Have you switched phantom power on? It's the switch marked +48V on the back. Can you play anything back through the interface? Can you play something from Garage Band through the interface (a virtual instrument maybe)?
Now, I say this with the greatest respect..You have bought an XLR to XLR microphone cable?
I ask because the BM-800 (had 2) does not come with one, it comes with an XLR to 3.5mm (1/8th inch) stereo jack plug. That will not work with the Behringer interface.
You should however be able to prove the mic out by using the supplied cable on the mac. I am sorry but I am not familiar with the mac's sound setup but many here will be.
Also, what cable are you using to connect the mic to the UMC? The mic seems to come with a (basically useless) XLR to TRS 3.5mm jack cable.
You'll need a male to female XLR cable to get the mic to work with the interface. Something similar to one of these: https://www.amazon.co.uk/C2G-Pro-Audio- ... LR+5m+-DMX
If you've tried using the supplied cable with a 3.5mm to 1/4" adapter (often supplied with headphones) plugged into a 'combi' input (combined XLR and jack socket), then it won't work because 48v power is only provided to the XLR connections in the connector. The jack is meant for instruments or line level inputs, and they really don't like being given 48v, so the connections for the jack input part don't have 48v on regardless of switch position.
Post by G-Doubleyou »
Have you selected your interface in System Preferences/ Sound preference pane?
G-Doubleyou
Posts: 972 Joined: Fri Feb 10, 2006 12:00 am
2.3 GHz quad-core i7 Mini
Post by Gideon26 »
Yes. I had it on, but before I connected the mic.
I wasn't able to playback anything. I had my headphones plugged into the interface and could hear things from my computer but when I switched it to monitor sound from mic, it was just some static (not loud).
I don't have an instrument to play through it . I'm using it for recording audio dramas, doing voice overs, etc. So I only will be using mics.
Gideon26
Post by Gideon26 »
Wonks wrote:Hi and welcome to the forum.
I had phantom power on, but I was very random in setting up my mic... meaning i had 48v on before connecting my mic, and the gain was probably up too :headbang:
My interface isn't even getting a signal from the mic, so whichever direction i speak into the mic, i will get nothing.
Last edited by Martin Walker on Fri Nov 09, 2018 12:09 am, edited 2 times in total.
Gideon26
Post by Gideon26 »
Yes. I have an XLR female to XLR male. (from my mic to the input on the interface.) I also have on on my mic boom arm (whatever you call it :P )
I used the mic (with a small power box that came with the set, I have the excelvan BM-800 kareoke set.) a week or two ago and it was fine, but it seems to have trouble with the UMC404.
Gideon26
Post by Gideon26 »
Wonks wrote:Also, what cable are you using to connect the mic to the UMC? The mic seems to come with a (basically useless) XLR to TRS 3.5mm jack cable.
I'm using a male to female XLR cable. I didn't even think about connecting it with the TRS lol
Gideon26
Post by Gideon26 »
G-Doubleyou wrote:Have you selected your interface in System Preferences/ Sound preference pane?
Yes. I've set it up on both input and output.
Gideon26
Hi Gideon26, and welcome to the SOS Forums! 8-)
Your image above didn't originally make it successfully into the SOS Forums, because you inserted an imgur link between our two Img tags, so I edited your post for you so it appeared properly.
What you need to do in future is right-click on your desired image, choose the 'Copy image address' option, and then paste that between our two Img tags.
Last edited by Martin Walker on Fri Nov 09, 2018 12:14 am, edited 1 time in total.
Post by Gideon26 »
Martin Walker wrote:Hi Gideon26, and welcome to the SOS Forums! 8-)
Oh ok will do. :thumbup:
Gideon26
I cannot find any information on that kareoke set but I suspect it uses the computer's low voltage supply for the microphone, possibly via USB?
If that is the case that leaves three other possibilities. The UMC is not putting out 48V. Unlikely even for a Behringer! The XLR-XLR cable is faulty or the phantom power circuit in the mic is faulty and of the three I would say the last is the most likely.
The BM-800 and related mics ARE remarkable value and quite well made. My two also work well, not as sensitve as my Sontronics LDC but some 10dB hotter than an SM57. They also work ok on 48V or via a laptop jack (and I think are a better bet than many USB mics)
However, the forum pages were rife with other people having problems with the mics. Low levels, no level, noise. The QC it seems is not at all good and so it is very likely IMO that yours is faulty.
Do you own a digital multimeter? If not I strongly urge you to get one. Something around £20/$20 is easily good enough. Thus equipped you can test the cable for continuity and for the presence of 48V.
Or, the BM-800s are SO cheap you could just order another one (just the mic) and use that to test the system and proceed from the results obtained?
Do you have access to (via a friend or in an old box somewhere) another mic and cable you can use to test?
At the moment the problem could be in the mic, the cable, or the interface. The earlier you can shorten that list the quicker you solve your problem. :)
Post by Gideon26 »
blinddrew wrote:Do you have access to (via a friend or in an old box somewhere) another mic and cable you can use to test?
I have another cable (brand new blucoil), which I have already tried but got the same results (or lack of results :tongue: )
I have a power box that came with my BM-800 so I will test that soon.
Not sure about testing another mic... I think one of my friends has a mic, I'll have to ask him about it.
Gideon26
"Not sure about testing another mic... I think one of my friends has a mic, I'll have to ask him about it."
Ask if he has a test meter as well! Does not HAVE to be digital. An old Avo 8 or a Simpson would do famously.
Post by Gideon26 »
ef37a wrote:"Not sure about testing another mic... I think one of my friends has a mic, I'll have to ask him about it."
:thumbup: I'll be sure to ask. Thanks
Gideon26
Post by Rich Hanson »
I might be off base as I am unfamiliar with this mic, but if it comes with an XLR to TRS lead, does that suggest it would be using the computer's 5V supply? If so, could connecting it to 48V phantom power might have done something unfortunate to it?
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Rich Hanson wrote:I might be off base as I am unfamiliar with this mic, but if it comes with an XLR to TRS lead, does that suggest it would be using the computer's 5V supply? If so, could connecting it to 48V phantom power might have done something unfortunate to it?
No, the microphone uses an "Electret" capsule, a pemantly charged capacitor cell (like a magnet but electricakle) and so the only power the mic needs is for the impedance converter amplifier. This can be derived from the 5V at most laptop mic jacks or indeed from 48V spook juice.
Post by Gideon26 »
I tested the BM-800 with the power box that came with it, and it works. So I don't think the mic is the problem.
Gideon26
If you are using the same male to female XLR lead between the mic and the phantom power module, where are you plugging in the cable from the phantom power module to? Into the PC's own soundcard with the 3.5mm jack lead, or into the UMC with another male to female XLR lead?
We have to keep guessing here as you aren't telling us all the connection details. We need to know the full signal chain of what works and what doesn't work.
Photos would help. You'll have to host the photos elsewhere then link to them here.
Post by Gideon26 »
Here is my setup. Hope this helps.
Gideon26
Gideon26 wrote:Image
No!
Dave. Ah! If I right clk on the red "im" I get it (pics are all a bit of a trial these days?) but it STILL does not tell us what we need to know!
You say "the mic works directly into the mac" How? Is that via the 3.5mm jack and if so I suspect the problem is in the BM-800 and the 48V to 5V reducing circuitry.
Post by John Willett »
Here is the picture that would not display above:-
John Willett
