Intermittent Neutrik Female plug?
Post by MarkOne »
Had a weird one today...
Had an SM58 going intermittent on one of our singers. It was quite easy to get the mic to cut out by wiggling the (Neutrik) female plug in the end of the mic. Replaced the cable and all was well, completely solid. Checked the cable on a cable tester and it shows three lights. wiggling the cable vigorously doesn't cause an intermittent warning on the tester, had the plug apart and examined the joints. Again fine. I'm now suspecting the pins in the shell are somehow not gripping tightly enough on the pins in the SM58, but are on the socket in the cable tester.
Any one else come across something like this? Guessing I should just replace the female plug and have done with it.
I'm a bit annoyed as I went to the effort of getting cables with Neutriks and paying the extra. and these are less than a year old (and don't get hammered - only used once a week)
MarkOne
My Music on Apple Music
My Music on Spotify
Re: Intermittent Neutrik Female plug?
Assuming the connectors really are Neutrik's (there are some very convincing fakes out there!), it could be an issue with the male plug on the mic being slightly out of spec. I've also had problems occasionally where the female connector hasn't latched properly, allowing unwanted movement. Sometimes removing or adjusting the sealing o-ring helps.
Posts: 43704 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
I too have had problems with certain XLR connectors.
Some Maplin male 3 pin plugs would jam in an old RS "Cannon" socket. Very well! Gas pliers job to remove.
I also found the plastic pin matrix would melt under normal Lead soldering! I had to use a second plug/socket to keep the pins aligned.
As Hugh said, lot of bad copies about and I guess a lot of out of specc' tooling?
Posts: 19149 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
