Techniques to economise on RAM
Post by garrettendi »
As some of you already know, I got given a free older PC from work for my studio, which is great because with my recent marriage and future plans (like buying a house), I can't really afford to buy a new PC.
It currently has 6GB of RAM, which I know is going to be really pushing things, but I'm not sure I even can upgrade the RAM on this, let alone afford the cost. So I need to make do with what I have.
I can't remember the full specs to my memory but as a rough idea, it's a 3.something GHz dual core x64 AMD CPU, 6 GB of RAM, a 1 GB Dedicated AMD Radeon GPU and Windows 7. The model is the HP Z400 but it appears it was upgraded at some point as the specs on the web are much lower.
With this in mind, what techniques do people suggest to try and make the most of my less-than-optimal RAM when recording, mixing or composing? Just to tide me over til I can do something better?
As an idea of what I'm doing, I use Harrison Mixbus 4, a Behinger UMC204HD, and I normally have about 4 tracks at most, sometimes the drum VST is output to 8 tracks though, although only one track has the VSTi. I use pretty much only Melda effects (I love 'em), MDrummer or MT Power Drumkit 2 for drums, Spitfire Labs VSTis, and a small handful of guitar amp sims and impulses.
I'm thinking one way would be to imprint VSTIs to a track then unassign the VSTI track once I'm happy with it.
Finally, I do plan to do some video recording of the mixing screen in OBS for YouTube videos etc, but that's not really something I'm hugely fussed over.
Cheers chaps!
EDIT: I also use softsynths, specifically Air Vacuum Pro and u-he Beatzille
garrettendi
Posts: 3584 Joined: Sat Dec 10, 2005 12:00 am
Re: Techniques to economise on RAM
By chance I actually checked the specs on my machine the other night and it turns out I'm only running 6GB of RAM as well. I'm running Reaper and don't generally start hitting any issues until I'm hitting about 60-odd channels. At which point I unplug the internet cable switch on quiet hours and that seems to give me a little more headroom.
Any issues beyond that I start freezing tracks. Not sure how Mixbus handles this but on Reaper it's very easy and instantly reversible. The performance meter on Reaper gives you a track-by-track count so you can see what's eating CPU (which tends to be my problem, rather than memory), again, not sure if Mixbus does the same?
DISCLAIMER: The below might read like sarcasm, but it isn't!
That's really helpful Drew thanks! I'm glad I know of at least one person with the same or similar specs to mine and find it actually works.
I've recorded a two track song (the awful Emeli Sande cover last month) and I had no issues at all, and I've played around with drum VSTIs also without issue. It was only when I turned on the OBS video software while mixing that I got the little bubble in the lower right "Switching to basic Windows 7 theme" (or something like that) and my Aero interface went to the opaque look to save on resources. This got me wondering whether I have a pitifully poor PC. Google suggested I need 16 GB!
After reading your reply, I wonder if it's more an issue for recording the screen in OBS that is the issue. I've done some hefty Youtubing during my lunch break and found a video that like you, suggests most DAWs can handly 60, 80, or more tracks and only use about 4 gigs of RAM.
As for freezing tracks, I've never needed to do it on my laptop (that has 12 GB of RAM but it's knackered to the point of teetering on dying and actually runs slower than my 6 GB desktop). in the past, but I know it can be done in Mixbus. Not sure it's "reversible" in the same way as Reaper, but I hear it's pretty much the same but in a different workflow so to speak.
TL:DR - Thanks for the reply, I'm glad I'm not the only one who works on that level of hardware!
P.S. Someone could say (and rightly so), "Why don't you just go back to the laptop?". But I really cannot stress how completely useless the laptop is now. It really is inches away from going to the great PC World in the sky....
garrettendi
Are you sure you can't upgrade the memory? There's a short PDF on the memory specs of the HP Z400 series here:
http://h20331.www2.hp.com/Hpsub/downloa ... zation.pdf
The HP Z400 Workstation supports Unbuffered 1-GB single-rank and 2-GB and 4-GB dual-rank PC3-10600E 1333 MHZ ECC DIMMs
With 6 slots in the motherboard, that should mean a maximum of 24Gb - and indeed the chart on that PDF includes that configuration. With 6Gb installed, I'm guessing you have 3 x 2Gb or 6 x 1Gb in it already, so if you can source the correct DIMMs then it should be a simple upgrade.
If you have 3 x 2Gb you could double it to 12Gb by adding another 3 x 2Gb, and if you have 6 x 1Gb then you could replace some or all of them with higher capacity DIMMS, just bear in mind the recommendation about memory configuration:
Since the memory controller is based on a three-channel design, the following rules should be used for best performance:
• Configure memory in sets of three.
• Configuring the memory using the smallest
DIMM size will sometimes optimize memory performance, if it prevents single-channel configurations. As an example, for a 2 GB configuration, buy two 1 GB DIMMS, not one 2 GB DIMM.
Posts: 9977 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
That may well be true, and it's something I can look into, but it'll be months if not longer before I can justify it as an expense. We're moving home this year, and on top of that, furnishing our house now my wife has moved in is taking top priority.
As a bachelor I lived with minimal furnishings and spent my money on guitars and other studio gear.
Yeah, it's a shock to the system having to push that drive down somewhat!
EDIT: I'm not disregarding your suggestion, and I have researched the costs of RAM and paying someone to stick it in, but money is being used for more essential stuff for the next few months.
garrettendi
Post by CS70 »
Anything video is far more resource intensive than audio manipulation. It's simply a matter of size of the data that need to be handled in real time. I wouldn't dream of running any video software while mixing :)
CS70 wrote:Anything video is far more resource intensive than audio manipulation. It's simply a matter of size of the data that need to be handled in real time. I wouldn't dream of running any video software while mixing :)
Nerts. So I guess I might have to knock the whole YouTube series about Deaf studio work on the head :?
As an aside, it's not just the cost of the RAM, but I know nothing about installing it, and the cost of having someone insert it is probably going to be more than buying three sticks of 4GB!
Maybe I should think this over a little.
garrettendi
Post by Mike Stranks »
Yup! :thumbup:
My Scan machine which is now 6 years old and is on Win 10 has 8 gigs of RAM and still zips along when multitrack mixing. OTOH editing videos longer than about 10 mins can cause it to come over all unnecessary very easily.
Mike Stranks
Well.... crap! I guess I really need to rethink the video thing.
Thankfully I still haven't bought that 1080p webcam yet!
I was all excited to make videos about being a Deaf musician too!
garrettendi
garrettendi wrote:
CS70 wrote: As an aside, it's not just the cost of the RAM, but I know nothing about installing it, and the cost of having someone insert it is probably going to be more than buying three sticks of 4GB!
Changing the RAM in a PC is usually trivial, just take the old sticks out (if replacing any) and plug the new ones in. The sockets sometimes have a couple of little plastic or metal clips which you need to factor into the process depending on the motherboard but it's nothing to be afraid of and usually work in obvious ways.
Hardest part is finding that screwdriver (the one you have no idea where it is) to open the case :)
Never underestimate my ability to make a total hash of simple electronics tasks. An Electrical Engineer I know once talked me out of buying a multimeter when he found out how I planned to use it (turns out I would have blown the fuse box and possibly killed myself).
No, I'm not exaggerating!
garrettendi
Post by MOF »
Installing ram isn’t difficult, it can only go into the slot one way, make sure the computer is switched off and when handling the memory discharge any static on yourself through CH copper piping for instance or buy an earth wrist band.
MOF
Ah yes, sorry, I'd missed the video bit of your requirements. Funnily enough my machine also runs as a complete dog for anything more than the most basic of video manipulation. Fortunately I current have *ahem* access to another machine for my video tweakery.
I think you should keep the idea for video podcast as it's a novel and intriguing viewpoint, but you may have delay the implementation until you can spring for a few sticks of RAM.
As has been mentioned, fitting it is very straightforward (there are youtube videos aplenty) so I'm sure you'd be fine.
Just remember the bit about unplugging it first. :D
blinddrew wrote:Just remember the bit about unplugging it first. :D
I'm happy to state that while I am useless at all things electronic, I do at least know this :headbang:
garrettendi
Post by wireman »
One thing you could do to get some information is to run the Resource Monitor (type resource into the start menu search to find it) and you will get a display showing how much memory you are using.
Note however that memory requirements can change faster than you can see them.
Installing RAM is not too difficult but you can get caught out by not knowing the pairing rules, having a cramped PC, missing the clip(s), not expecting how hard to press or being aware of anti-static precautions.
wireman
Posts: 804 Joined: Fri Dec 17, 2004 12:00 am
Post by The Bunk »
garrettendi wrote:Well.... crap! I guess I really need to rethink the video thing.
I'm not sure what your intentions were or are as regards the video thing so this may be utterly useless as a suggestion, but...I also make "tongue-in-cheek" type videos to put on Youtube. Almost self-deprecating. And one of my angles is that I haven't got the best technology available - just a basic Handycam type thing (and an even crappier webcam), and some several-versions-old-now video software (Adobe elements). So I don't attempt to hide or disguise that, in fact it's more like I exaggerate it to make the point. But you can still see what's going on. Depends what your objective is ultimately but for me it's a case of doing the best (or worst!) with what you've got and not trying to cover it up any differently. So maybe rethink (or, er..."get creative") that way you want to do the video?
That may be of absolutely no use to you at all.
The Bunk
Posts: 1345 Joined: Sat Dec 29, 2007 12:00 am Location: SW London
The Bunk wrote:I also make "tongue-in-cheek" type videos to put on Youtube. Almost self-deprecating. And one of my angles is that I haven't got the best technology available - just a basic Handycam type thing
A random temporary diversion from the thread topic, but I very much like your videos, love the little funny gags and props and always good for raising the mood (great sounds too!) :thumbup:
I agree, The Bunk's videos and music are both great.
Post by CS70 »
Eddy Deegan wrote:
Hei, I didn't write that! :D:D:D
Post by CS70 »
You still can - use your phone as a camera.. the quality is actually not too bad at all, and like in music, performance, lighting and framing does far more than the equipment. Then for example if you have an iPhone, with iMovie you can actually do some decent editing, bit limited in merge-fades last time I checked but it may well be that I haven't found how to do them.
You can cut documentary-like videos with very little kid nowadays, totally up to youtube standards. Creativity and skills beat expensive kit any time of the day.
Now if all you have is a Nokia 3310 on the other side you're out of luck. :)
My wife does her own Facebook streams using a DSLR (?) camera and her MacBook. I could borrow that to video me and use OBS to record my screen then tack the two together!
garrettendi
If your video editing needs are basic then give Reaper a try - it has a deserved reputation for frugal system requirements for audio though I've not really tried doing video on a low powered machine but the 4GB studio computer works fine for video in Reaper.
Posts: 16989 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by scw »
Upgrading the RAM is cheap and simple but it probably won't make any difference to your video editing efforts.
Graphics card, CPU and the type of video files (SD/HD/4K codecs etc) will all impact much more on your efforts.
My advice would be to reduce the video resolution and see if it makes a difference before spending any money.
scw
Posts: 197 Joined: Wed May 22, 2002 12:00 am Location: Scotland
scw wrote:Upgrading the RAM is cheap and simple but it probably won't make any difference to your video editing efforts.
Actually, it may well - at least up to a point. Not so much due to the nature of the work being done but more from the availability of very fast working space. Video editing gulps memory and CPU power. On 64-bit operating systems especially the availability of larger RAM will reduce the amount of file I/O.
This doesn't scale performance-wise indefinitely for video but I would be surprised if increasing from 6Gb RAM to, say, 12Gb doesn't make some difference. This is a 'diminishing returns' thing, but every little helps, especially on a system with modest specs.
SSD storage would almost certainly make a difference too, but I think that's outside the available budget in this case.
scw wrote: Graphics card, CPU and the type of video files (SD/HD/4K codecs etc) will all impact much more on your efforts.
Some (most, these days?) video editing software will take advantage of the processing power in the graphics card where possible for certain things but CPU is really the 'meat and potatoes' of the process.
A dual core CPU (as cited by Garrettendi) is going to be a bottleneck, but with a clock speed of 3.xGhz it is hardly unusable and should be up to the task for the necessary basics when it comes to editing, albeit with limited capability for previewing effects in realtime. Rendering may take a while but that's what kettles are for ;-)
scw wrote: My advice would be to reduce the video resolution and see if it makes a difference before spending any money.
This is good advice, as long as the resulting video meets the required standards for whatever the project is. Many people equate resolution with quality and while there is much truth in that, a good camera with decent optics and capable firmware can produce better quality output at lower resolutions than some people might think.
Last edited by Eddy Deegan on Fri Jan 25, 2019 12:51 am, edited 13 times in total.
Eddy Deegan wrote: SSD storage would almost certainly make a difference too, but I think that's outside the available budget in this case.
Seems that SSD prices (and other flash memory prices) have come down quite a bit in the last few weeks so it might be worth looking at.
