Sound diffusers - worth the money?
I'm currently planning acoustic treatment for my home studio, which I'll be using for tracking, mixing and mastering. I already have around 10 acoustic panels that I built from an SOS design (foam fronted wooden frames with rockwool lining), but I don't want to deaden the room too much, as I'll be recording acoustic instruments.
Any advice on using diffusers would be greatly appreciated. I have a large bookcase that's filled with flight cases / books etc., which I'm guessing will provide some diffusion, and I also have a large wooden board that I'm considering placing on the floor when I want to record acoustic guitar, to liven the recording up. Will diffusers also liven up the recording? Or do they serve a different purpose?
I've been looking at diffuser prices, which seem to vary quite a lot, and found these on Ebay from Ukraine, which are much cheaper. Any thoughts on whether these are any good? Cheers!
https://www.ebay.co.uk/itm/4pcs-50-50-5 ... 3030852051
- paulsmusic
Regular - Posts: 178 Joined: Mon Jul 11, 2016 9:05 am
Re: Sound diffusers - worth the money?
They don't look to me like they'll do much diffusing (apart from being set off the wall) and you could achieve the same effect by facing your absorbers with something like this :-
https://www.diy.com/departments/screening-panel-board-th-6mm-w-610mm-l-1830mm/1696222_BQ.prd
I would say diffusers, to be effective, need to have a pseudo random surface, a bit like your bookcases (which will do the job).
Sam Spoons wrote:They don't look to me like they'll do much diffusing (apart from being set off the wall) and you could achieve the same effect by facing your absorbers with something like this :-
Thanks Sam! Will probably just start with the bookcase and see how it goes!
- paulsmusic
Those panels are similar to the Vicoustic Wavewood design:
https://www.vicoustic.com/product/wavewood
The slotted MDF panel is indeed intended to act as a high-frequency 1D diffuser, supplementing the broadband absorption of the underlying material.
It is easy to over-damp the room at mid and high frequencies with. Road and absorber panels, so that Wavewood panel helps to restore some HF brilliance. We've achieved a similar effect in some Studio SOS visits by gluing old CDs to the from of some foam panels!
A more versatile alternative might be to acquire some MDF sheets and place them on the floor or propped on stands around the guitar area to give a bit more zing to the recording, while leaving the room relatively dead for vocals etc.
Thanks for the tips Hugh! I do have the top from a large table that I'd thought about putting on the floor to liven up acoustic guitar recordings. I guess it would be better to place it a few feet from the guitarist so that their feet aren't on it, and also place the mic stands on the carpet so they don't pick up vibrations? (apart from good vibrations!)
- paulsmusic
paulsmusic wrote:Thanks for the tips Hugh! I do have the top from a large table that I'd thought about putting on the floor to liven up acoustic guitar recordings. I guess it would be better to place it a few feet from the guitarist so that their feet aren't on it, and also place the mic stands on the carpet so they don't pick up vibrations? (apart from good vibrations!)
Yes, foot-tapping on a wooden surface -- while sometimes appropriate -- is usually not required!
But placing (wooden) reflective surfaces under and around an acoustic guitar performance can really add something helpful to the sound picked up by the mics.
If you have the DIY skills and space, you could upgrade your table top by mounting it on a frame with wheels, and fixing 2-inch (or better still, 4-inch) thick foam or mineral wool on one side (covered if necessary) to form a mobile broadband absorber.
You then have a useful studio acoustic screen which gives you options for altering the acoustics -- hard and reflective surface for guitars etc, and dead and non-reflective for placing behind a vocalist or as a gobo for screening spill from guitar amps etc.
That's a great idea - thanks Hugh!
- paulsmusic
There's lots you could do. Here are a couple of naff pics of the kind of things I had in mind. In both examples you can see that the panels have an absorptive side, and a hard reflective side:
You could also add strips or blocks of wood in different thicknesses to the front of the table to provide some diffusion.
The most important thing, though, is to make sure the stand is totally stable. No one wants a 6-foot gobo toppling on them, or crushing their irreplaceable guitar, just because someone brushed against the gobo as they walked past!!
Last edited by Hugh Robjohns on Thu Jan 24, 2019 11:52 am, edited 1 time in total.
They look amazing! I could probably adapt some of the panels that I built from one of your SOS designs!
- paulsmusic
That'll be because you don't know about diffusion .
you can make flat diffusors no problem
For example Binary Absorption Diffusors
(See RPG's research, deriving their BAD panels, )
they can by Hybridised as well into curved assemblies, but that's not the point.
Actually providing useful , "nice" diffusion is a mathematical threading of the needle from 1000 miles away/.
Last edited by Studio Support Gnome on Sun Jan 27, 2019 4:47 pm, edited 1 time in total.
- Studio Support Gnome
Frequent Poster - Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help, if not.... Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Fair enough SSG
To be fair, mention 'diffusor' to most people and they will automatically think of 'skyline' quadratic diffusers -- square arrays of different size blocks:
... or finned diffusers with different size vertical slats.
Few would ever think of flat/slotted diffusers, even though they are quite widely employed.
(These all happen to be Gik products, but similar things are available from many other suppliers, or as DIY solutions)
Last edited by Hugh Robjohns on Mon Jan 28, 2019 11:39 am, edited 1 time in total.
Is there much published on the design of slot diffusors?
I have found material on skyline and quadratics but nothing much on slots. A quick peruse of ebay showed some designs with even slot spacing and a couple with a more varied pattern.
Having a small cnc machine in the garage I'm finding making some a very interesting idea . . .
- Random Guitarist
Frequent Poster - Posts: 1207 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Also this looks interesting. https://www.theengineer.co.uk/ultra-thin-diffuser-gives-clarity-to-sound/
If I'm understanding the basic premise correctly the new approach could have a 10cm thick panel (effective 9cm trap dpth) with diffusion effective to 200 Hz?
Or do I have that wrong?
Thanks, Grant.
Thanks, Grant.
- Random Guitarist
You're correct, though remember that diffusion is not absorption. It's spreading the reflected sound out so it goes in a wide spread of directions, rather than mainly reflecting off in one direction. So it's effectively trying to turn a flutter echo into a smoother, more reverb-like spread of smaller echos.
And in the example given in the article of 75Hz, the panel would still have to be at least 20cm deep, so not that practical for a small studio, where you'd be better off concentrating on bass trapping.
Yep understood.
I only have a small room but have a cloud over my head and treated reflection points, plus a fair bit of bass trapping. I like the idea of panelling some of the walls and if it can be acoustically useful so much the better.
I also like the look of some of these panels a lot, I am shallow.
Thanks, Grant.
Thanks, Grant.
- Random Guitarist
Random Guitarist wrote:I only have a small room but have a cloud over my head
Same here, but sometimes it goes away and I feel creative
Posts: 22581 Joined: Wed Jan 13, 2010 8:44 am
