DP sees them both, I get audio input levels but only one track can record at a time.
They are connected by lightpipe and I want the motu to slave to the apogee, so I set the out in apogee and in on the motu, yes?
Is there a way to arm multiple tracks?
TIA
hooking up an apogee ensemble and a motu 828 usb to work with DP
Re: hooking up an apogee ensemble and a motu 828 usb to work with DP
In the audio MIDI setup utility you can create an aggregate device.
Mileage will vary depending on the quality of the drivers.
Some companies make drivers that support multiple devices, like MOTU, UA, ect.
- G-Doubleyou
Posts: 972 Joined: Fri Feb 10, 2006 12:00 am
2.3 GHz quad-core i7 Mini
