Yet another soldering question, desoldering.
Evening all,
I need to remove and reattach an Aux socket from our Yamaha mixer after a cheap jack plug broke while in there, leaving the tip loose between socket and the circuit board. It's proved impossible to get it out through the socket, so I have had to disassemble the mixer and remove the relevant board.
The offending tip is rattling between the board and the barrel of the connector, trapped by the pins. If I take off the socket then the tip can be removed in about 2s, and the socket soldered back. Plus an hour to then reassemble the desk of course.
Photographs of the socket with the tip inside, and the back side of the pcb are here:
https://m.imgur.com/a/OU0D1Cz
The question is, is there anything untoward I should be wary of before I desolder and resolder the connector? Other than being vary careful around those little surface-mount components?
As ever, many thanks for all the fantastic advice on this forum,
Rich
Rich
My ambition: To one day have enough experience to answer technical questions on the SOS forums, as well as asking them
Re: Yet another soldering question, desoldering.
Just remember that it will be lead-free solder that's used on the board, so you really need to use that to solder a new socket on. It's almost impossible to get all traces of the previous solder off, and lead and lead-free solder don't work together. And lead-free solder melts at a higher temperature than leaded solder, so the joint needs to get warmer for the solder to work.
I'm by no means an expert solderer,... but I'll clip on a heat sink if I'm anywhere near sensitive components. And I've found the desoldering tape to work fairly well.
Here are some Unfinished Sounds.
I would strongly suggest you first get a replacement jack, they look pretty stock items.
Then, with some big pliers crunch the existing one until you are left with the pins in the PCB then heat those up individually and remove gently with tweezers.
I say this because I am pretty sure that is double sided print and it is very hard to desolder completely from one side in one go and you then run the risk of lifted print. Can all be fixed but messy.
Thanks everyone, that's exactly the sort of advice that makes SoS so helpful.
Dave, I have the service manual and parts list for the mixer, so I can get a replacement socket it needs to be the right height as the board is held in place both by screws on the board at the back and the nut on the front. I might be able to cut the socket rather than mangling it, will have a look.
Wonks - how do you know it's lead-free without knowing the model? I'm not doubting you, just amazed.
I've never used desoldering tape, only solder suckers, but I've usually done OK with them.
Scw- Never even heard of Kapton tape, but a quick google says it's a sort of insulating tape. Do you just make over the things you want to protect? And how do you use a clip-on heat sink?
So the plan is to source lead-free solder, kapton tape, the replacement socket, and if it all arrives by the weekend then I'll so the job then.
Anything sold in the UK /EU since Aug 2004 has to use lead-free solder, and there was obviously kit before that date with it. So unless it's vintage kit, it's almost certainly going to use lead-free solder.
If it's got an RoHS logo on it, it's definitely lead-free.
Wonks wrote:Anything sold in the UK /EU since Aug 2004 has to use lead-free solder, and there was obviously kit before that date with it. So unless it's vintage kit, it's almost certainly going to use lead-free solder.
It's a Yamaha EMX 5016cf, which I think started in about 2007 and still seems to be made. So definitely lead free.
Yes, just use the kapton tape like masking tape and mask over everything you want to protect. It's study on one side but doesn't leave a residue. It comes in various widths so buy one wide enough for your job.
A heat sink specifically clips onto any component that you don't want to overheat. It draws the best from the iron away and dissipates it.
One other thing I'd recommend getting is rosin flux. It's inexpensive and makes soldering much cleaner and easier IMO.
Stewart
Stewart
Dr R, I do not like suckers! they can lift print. The de soldering braid is slower (don't be mean with it!) but you stand far less chance of damaging anything. Some cocktail sticks are handy for cleaning holes. Do NOT be tempted to use copper wire.
Cannot see where you will need a heat shunt. I use one yonks ago for Germanium transistors, never since. Yes, tape down those SMT components! You will scream if they drop off but not as much as you will trying to put them back!
Feel free to read the regulation which has some exceptions.
try a bit of sticky tape on the end of a forceps or something first
Desperate perhaps, but I'd try pushing out the side or extracting it through the barrel for awhile before heating up the gun
- Watchmaker
Frequent Poster - Posts: 1319 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
The answer is to learn (and become adept with) as many different methods of solder/component removal as possible. There is no 'one size fits all'
- Folderol
Forum Aficionado -
Posts: 20880 Joined: Sat Nov 15, 2008 12:00 am
Watchmaker wrote:try a bit of sticky tape on the end of a forceps or something first
Yep, tried all that
I think I'll order the bits, inc desoldering braid, then have another concerted go at removing the thing mechanically this weekend. Hopefully the law of sod will work in my favour and I will have bought a bunch of stuff I didn't need, but won't have damaged anything. This week is a bit mad with paid employment, but I'll post any updates.
Many thanks all, as ever!
Rich
I like the idea of trying to turn sod's law to your advantage, good luck!
Two quick questions, are you able to move the tip around at all within the socket? Is it a tip with a hole where it was initially mounted or a stud?
This happened to me once, the bugger is that I can't remember if or how I solved it, I can however remember that getting it out through the plug was impossible as, unless the tip was exactly aligned, nothing would induce it to pass through. It was a tip with a hole though, one with a stud would almost certainly have been possible to remove with the right size forceps.
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
it's a dilly alright. a real skill builder. let us know the outcome
- Watchmaker
I've fixed this problem quite a few times, more often than not without any soldering or damage to the equipment involved.
I usually manage to grip the broken off end bit with a drill bit twisted into the centre of it
- by hand - get the correct sized bit and it will grip surprisingly well. Occasionally, I've had to use a drop of superglue too, though the drill bit is then junk.
Yours appears to have turned sidewise too, which may prevent this, but if you can get it the correct way up again, this is worth a try.
Folderol wrote:The answer is to learn (and become adept with) as many different methods of solder/component removal as possible. There is no 'one size fits all'
Yep, that hits the spot Folderol - I've used a solder sucker, cutting component leads first before desoldering (easier to pull the remaining piece of wire out of its circuit board hole when there's nothing else attached to it).
I even have a supply of (bluntish) syringe needles for poking a hole in a circuit board where a component used to be, but which the solder sucker refuses to evacuate - place soldering iron on appropriate position, push the needle through when solder has melted, and then (because it's stainless steel) the needle can be easily pulled out again, leaving a neat hole ready to accept the replacement component's 'leg'
Posts: 22577 Joined: Wed Jan 13, 2010 8:44 am
MarkPAman wrote: Occasionally, I've had to use a drop of superglue too, though the drill bit is then junk.
That'll wash off with acetone
- Watchmaker
Hi All,
So FINALLY I got to actually do this job on Sunday afternoon. (Working for a living pays the bills, but it sure gets in the way of the fun stuff)
I wasn't able to find a socket I was sure was a direct pin-for-pin replacement for the one there, and none with a metal screw ring at all, so as the board is actually single-sided, so I decided that I would carefully remove the socket, rather than trashing it. The kapton tape was a very good idea. Covering the tiny surface mount components and all the adjacent components provided reassurance that there was no chance of collateral damage from drips of solder or wandering irons. Not that there was either but it was good to have, and made it very easy to identify just the four pins I wanted. I couldn't get on with the desoldering braid at all - it just leached heat away from the joint - so I reverted to the solder sucker. I'm sure there's a knack to using the braid, or maybe my iron is borderline on output, but I gave up.
The socket came out very cleanly, and out dropped both the tip of the jack plug, and the black insulating ring. I hadn't realised the ring was in there as well, but it was probably another reason I couldn't get the tip out through the socket.
Resoldering was straightforward, and then it was just a matter of putting the whole lot back together again and testing everything. Much to my relief it all works
So another win for the SoS forums and all the helpful people here. As ever, many thanks to everyone who replied to the thread.
Rich
Rich
Hooray - we all like a happy ending Dr R!
