I've searched and searched but cannot find much info on this.
I'm looking at picking up a Focusrite ISA One but since my current interface has no inputs that bypass the built-in preamps I am wondering what the recommended interface might be. Is there one available without built-in preamps? One that is not super expensive...
What would you do if you needed to get your signal from an ISA into your DAW, knowing that you'd be working one track at a time on solo material?
I've also considered skipping the ISA and picking up a Steinberg UR-RT2 or a Focusrite 2Pre, if you care to comment on that option.
Thank you very much for any insight you can provide.
