Interface for the Focusrite ISA One
Post by Normonster »
Hello Gents,
I've searched and searched but cannot find much info on this.
I'm looking at picking up a Focusrite ISA One but since my current interface has no inputs that bypass the built-in preamps I am wondering what the recommended interface might be. Is there one available without built-in preamps? One that is not super expensive... :headbang:
What would you do if you needed to get your signal from an ISA into your DAW, knowing that you'd be working one track at a time on solo material?
I've also considered skipping the ISA and picking up a Steinberg UR-RT2 or a Focusrite 2Pre, if you care to comment on that option.
Thank you very much for any insight you can provide.
Normonster
Posts: 27 Joined: Tue Nov 22, 2016 8:58 pm
Re: Interface for the Focusrite ISA One
Post by Sam Inglis »
Well, it's not the end of the world if your signal goes through another preamp stage. If you want to get any 'colour' out of the ISA you'll need something with an input pad, otherwise it'll sound very clean.
The ESI Maya 44 has line-level inputs only and is affordable.
Sam Inglis
Posts: 3229 Joined: Fri Dec 15, 2000 12:00 am
Fit the ISA digital output card and use an S/PDIF input on your interface... if present?
Posts: 43704 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by CS70 »
Well I feel with the OP, the Isa One digital card costs an arm and a leg! :D
I concur, so long your interface is half decent, I wouldn't worry about using a signal path with another preamp - especially if you want color.. which is usually distortion anyways.
Thank you Sam. That is an affordable interface.
Hugh, no, unfortunately I bought a A&H Zedi 10FX which has no digital input.
CS70 I fear my interface is perhaps less than half decent. I can get a good sound live, through studio monitors or my PA speakers, but I'm not so sure of the converters and what have you. Distortion in my signal chain is actually not what I am after...I'm doing a kind of singer songwriter type style with just vocals and acoustic guitar...and hoping maybe the ISA can help me be better than I am. :)
Normonster
Post by Humble Bee »
Audient id22 and id44 have direct to ADC Inputs and are good interfaces in general... :thumbup:
Humble Bee
Posts: 395 Joined: Mon Jan 08, 2007 12:00 am Location: Cloughton Newlands
Normonster wrote:Thank you Sam. That is an affordable interface.
I have a 10fx and find the pre amps very good. The ISA is of course a superb pre amp but I doubt you will notice any difference. The 24 bit converters should also be AS good as most AIs in a similar price bracket.
Pete Kane (Scan) has said the 2in 2 out Zoom AI is about the best he has tried in the sub £200 range but the Native Instruments KA6 comes close, about the same money and has more connectivity.
But yes, running a line stage through an attenuated mic pre amp has virtually no issues unless the mic amp is pretty grotty to start with!
Post by CS70 »
The ISA is a good clean preamp - I have one and like how the variable Z can change the sound of the mic. However, when clean, practically all preamps sound pretty much the same-ish. It's only when you overdrive the circuit that then good ones distort, but in a pleasant way (which is called "color") which adds something nice to the track. The ISA is hard to overdrive but when you do it sounds cool (especially on electric bass, for me)..
What a high end preamp will not do, however, is to help you being better than you are :) The better the preamp, the more it will record you exactly as you are :D (or rather, as the mic thinks you are)
If you're looking for changing the timbre, and assuming your recording room is up to scratch acopustically and you know how to record guitar and vocals, much better value is to spend money on a nicer mic (or one that suits your better) rather than a different preamp; and/or reach for the EQ knobs- they're there for a reason. Now a good hardware EQ is way expensive but we're blessed with uncountable EQ plugins that get excellent tone-shaping results for very little money, so don't be shy with the (virtual) knobs.
I've never even seen a Steinberg UR-RT2 in the flesh, but a look at the block diagram for it a few weeks ago showed that there was no attenuation control between the transformer and the pre-amp, so any attempt to drive it hard for saturation was likely to end up with clipping at the A/D. Otherwise expect to hear only a very mild sound difference (just found this review which confirms it https://www.musictech.net/reviews/steinberg-ur-rt2-review/ ) . Remember that the unit contains two transformers specified by Rupert Neve, not a Rupert Neve designed interface on the cheap. They could have been better utilised IMO. It is a very good interface, but then so is the UR 242 at just over half the price, only missing those transformers.
Posts: 19210 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Well call me stumped I guess.
@Humble Bee - That is a highly rated piece of equipment from what I read. It also has to built in pres, the digital ins and the line ins. A flexible piece no doubt. Thank you for pointing it out.
@Wonks - Yes, I think I found the thread where you describe having reviewed the diagram. I see your point, unfortunate as the indication may be.
@CS70 - Damn it man. The truth hurts. haha. I am actually planning to pick up, in addition to my NT1A, a SM7B. Or I was at least. Also planning to upgrade my Cubase from Elements to Artist which has many more plug-ins (and that cool vocal comping tool).
@ef37z - I supposed the truth could be that I just don't really know what a good preamp set should sound like. I do know that it takes about 3/4 of the gain to get a good solid signal even from my SM58 though, so I was assuming they're at the least, underpowered and probably not appropriate for the 7B which I read needs a lot of power.
The plan was to get a SM7B (along with my NT1A and SM58) and pair it with a ISA One and have a high quality single channel studio, but now I'm not so sure what I should do. I recorded once in a nice homestudio and the equipment there did indeed bring out the very best in what I had to offer.
Normonster
Post by CS70 »
NT1A?
That explains everything!
:-D
The SM7b's output is about 3dB down on an SM58, so it does work best with good clean pres with a lot of gain available, ideally 70dB but at least 60dB, so you don't have to push the preamp too hard and into its noisy zone.
It has been mentioned but how is you recording/mixing space? If the 'nice home studio' you recorded in is a nicely treated good sounding room and your's is an untreated bedroom (forgive me if you room is also well treated but you have yet to say) that is more likely to account for the difference you hear than equipment.
If OTOH your room is equally well treated you might benefit from a high quality preamp but even there you would probably benefit more from better mics, the NT1A, for all it is good for the price is still, relatively speaking, a budget mic. The SM7B would be good, (add a Cloudlifter or FetHead and you don't need to worry about lack of preamp gain) and the money you save not buying the ISA would get you a better LDC.
You don't say what your interface is either, but if you haven't read these articles you should before spending on an exotic preamp or interface :-
https://www.soundonsound.com/reviews/pick-preamp
https://www.soundonsound.com/reviews/preamp-post-mortem
Posts: 22916 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Aston mics are coming out with a model called "Stealth" pretty much now and it looks to be a direct assault on the SM7B. I would hold any SM7B purchases and see what that mic is in the real. It looks to have a few different filter options as well as a built in cloud lifter type circuit which makes it quite a bit cheaper than a SM7B/Cloudlifter combo...
And i like my Aston Spirit quite a bit so I'm all ears on any new stuff they bring...
Humble Bee
...And i would probably go for a solid quality audio interface and a few good quality mics before dwelling on buying any fancy preamps. Not saying the Focusrite is bad. It's a very fine preamp indeed. Better mics will undoubtedly give you more sound quality bang for your buck and a well designed AI is going to make your work much more trouble free and efficient. Preamps have less impact on the recorded sound than microphone choice and technique most of the time.
Humble Bee
Normonster wrote:I recorded once in a nice homestudio and the equipment there did indeed bring out the very best in what I had to offer.
That studio probably had decent acoustics, a decent mic and someone who knew what they were doing and how to put the performer at ease. These are all far more important than the choice of preamp and interface.
Allen and Heath know how to make good preamps - I use the ones built into my Sabre mixing desk for most of the things that I do and I have no complaints and I'd be surprised if the ones in your mixer are very different.
I'd be looking at improving your studio acoustics and investing in one or two decent microphones rather than going for an expensive preamp which won't make very much difference.
Posts: 16993 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Normonster wrote:Well call me stumped I guess.
If you are referring to the pre amps in the Z10 then I would say they would be fine. How far you have to advance a gain pot to achieve a desired level is no indication of the "power" or any other quality of a pre amp other than the law of the potentiometer (just because they paint an "11" on a guitar amp's VC does NOT make it any louder!) .
My NI KA6 AI needs the gain advanced to maximum for acoustic guitar with a '57 (yes, I know but son preferred it to a capacitor!) but even then the noise floor was around -70dB and much of that was the room.
Try it. Do not forget, on a mixer the mic pre might only have 60dB of gain but there is usually another 10dB or so on hand further through the circuits.
Last edited by Hugh Robjohns on Sat Feb 16, 2019 10:06 am, edited 1 time in total.
CS70 wrote:NT1A?
:-D
Oah no, really? I thought they were supposed to be decent mics. Not the same class as the SM7B then, I suppose.
Normonster
Wonks wrote:The SM7b's output is about 3dB down on an SM58, so it does work best with good clean pres with a lot of gain available, ideally 70dB but at least 60dB, so you don't have to push the preamp too hard and into its noisy zone.
The 10FX datasheet says is supplies up to 60dB, so I guess it'd work.
Normonster
Thank you Sir, I will review those articles. The honest truth is no, I don't have good room treatment. I do need to work on that. On the other hand, no, that other guy's studio wasn't treated (at least where I recorded vocals) but his equipment was top notch.
Normonster
OK, thank you James. Seems to be consensus on this. In that case, I could go up from the SM7B in cost and stay within budget.
Normonster
@Sam Spoons
Oah wow, I didn't realized you guys were actually pros. I appreciate you and everyone else's input very much.
That is a compelling article. I suppose I'll try one upgrade at a time then, and save the preamp upgrade for a later date. Also see about some DYI treatment.
Thanks again all. I'll try to chime back in here if I manage to uncover a significant difference in quality after I go through the painstaking process of microphone selection. Something tells me you've all discussed it before. :)
Cheers!
Normonster
Normonster wrote: OK, thank you James. Seems to be consensus on this. In that case, I could go up from the SM7B in cost and stay within budget.
Personally I'd go sideways - get yourself a couple of Line Audio CM3's for the acoustic guitar (they sound much more expensive than they are) and then go to a dealer and try a few different large diaphragm condenser mics to find one that suits your voice. It is also well worth spending a bit on acoustic treatment because it makes a huge difference.
Once you've spent the money take a bit of time to experiment with mic positioning. Acoustic guitars are very directional and just moving the mic slightly can change the sound dramatically.
"Oah wow, I didn't realized you guys were actually pros. I appreciate you and everyone else's input very much."
Not me Norm' I am just an old valve amp tech!
Nor me :blush: certainly not WRT studio work (I've been involved in live sound since my teens and it generated 50%+of my income for a fair few years before I retired).
I have built my own home/project studio though and I like to think it qualifies me to give useful advice to those starting to do the same. The studio build taught me that the difference acoustic treatment makes way more than the difference between a budget and exotic preamp.
