The idea before I actually buy a Rode NT-SF1 is to experiment with the plugin by importing some of the tracks that are out there on the web. So I set Logic up for surround and created a quadrophonic track and imported one of Rode's example polywav files. You can see from this picture that Logic is only showing two tracks in the file rather than 4:
And of course when I play there's only two inputs with data in the plugin:
I've tried this with several files from different sites (and even with the Surroundzone 2 plugin) and clearly I'm missing something stupid, but what? There's surprisingly little info about Logic and ambisonics on the web. Anybody got any ideas?
TIA.
PS incidentally a strange thing happens if I set the output format on the plugin to 5.1. All four inputs on the plugin are shown as receiving data but Y and Z are the same as X and Y only delayed by 2 or 3 seconds.
PPS opening the files in Audacity shows that they are indeed four track polywavs.
