I make electronic music as a hobby using synths and drum machines. I mix on analog mixers (AH MixWizard as main mixer, with a Mackie VLZ4 as a drum submixer). I sometimes read about fancy digital mixing desks (AH Qu, SQ, Behringer X32, Soundcraft Si, Presonus Studiolive etc.) but I get the impression they are no suited for what I do, because (apart from the AH Qu) they tend to only have XLR inputs which I don't quite trust.
I should add this is more about me developing my general understanding of this gear than about solving an actual need. The analog desks I have now work fine. The only advantage of digital for me personally would be to have compression and a parametric EQ per channel, which opens up some mixing/production possibilities compared to how I work now. I am aware that "use a DAW" is a more obvious way to have more EQ's etc.
Back to digital mixers with line sources. I don't have an issue with soldering XLR conncetors onto my cables, but I don't like the thought that accidentally enabling 48V phantom power is even possible. On a mixer that only has XLR inputs I feel like I'm a button press away from frying one of my synths. One can work around that with DI but in my case that would be quite expensive - if I had a 16 channel digital mixer, I would need 16 DI's or isolators to make use of its full track count.
This leads me to the conclusion that these digital mixers are fundamentally unsuitable for my use case: a mixer fully populated with line level signals. My question is, am I right? Or am I perhaps too paranoid in my distrust of XLR inputs for synths?
