alexhedleymusic wrote:ok but wouldnt this then just be recording in mono?
Yes... because -- as far as I can see from the manual I've read here: https://cz.yamaha.com/files/download/other_assets/2/320522/HC4E.PDF -- it's an entirely mono organ. It only generates a monophonic sound. It's built-in speakers comprise a single 7-inch woofer and single 2-inch tweeter. So there is no stereo spread. It's not like an organ with a rotary speaker system that produces spatial sound.
So mono -- as in a single sound channel -- is all it produces, and so mono is all you can record.
im looking to record the instrument to stereo
Perhaps there's some confusion here about the terminology, and maybe you're concerned that recording via a single input of your interface means the sound will only come from, say, the left channel when replayed.
That could happen if the default configuration of the interface or DAW is set up expecting a conventional two-channel stereo input. However, to overcome that problem, all you need to do is set the recording channel's pan control in your interface and/or DAW software to the centre, and then you'll hear the mono signal from the organ on both left and right channels of your speakers and both sides of your headphones.
This format is called dual-mono because there is only a mono signal, but it appears on both channels identically. It's what you hear when the newsreaders and DJs talk on the radio! Stereo music, dual-mono speech!
... starting to think i should just go through the headphone jack... so for that id just get a mono to dual mono (red/white) connector wouldnt i?
Nope. There's a whole new can of worms to wade through if you take that route.
For starters, the headphones still only produce a dual-mono signal. You have exactly the same organ sound in both earpieces.
Secondly, the headphone output us likely to be noisier than the dedicated Aux output.
And thirdly, if you wanted to record from the headphone output you'd need to use a cable like this with a TRS quarter-inch plug at the headphone socket end, and a pair of TS plugs at the interface end:
[img]
https://d1aeri3ty3izns.cloudfront.net/m ... review.jpg[/img]
...but you'll still only have a dual-mono recording.
