I still have my DA-20 in it's box too...
If you could only have one compressor plugin to use for everything, what would it be?
Re: If you could only have one compressor plugin to use for everything, what would it be?
Ah nice!
Eddy Deegan wrote:but more usually to the Fostex D2424 which is hidden behind the desk in the pic above.
Ah, I started (after playing around with a cassette multi tracker) with Fostex D Series machines, D90 then a D160. I really liked them, very straightforward, well thought out machines. Still quite miss them.
- ConcertinaChap
Jedi Poster -
Posts: 15235 Joined: Wed Jul 20, 2005 12:00 am
Making music: Eagle Alley
Akai DR8 and 16 for me, brilliant machines and I still have one or two of the silver Berry Composers. They got the job done. My DA20 is in the studio rack next to the Mackie SDR24 (both rarely switched on these days).
Forum Aficionado - Posts: 22907 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Luxury! When I were a lad I used a National portable cassette deck, and prior to that we used to scrape wax off old cardboard boxes found in t’ middle of the road and used sparrow beaks to carve out wax cylinders....... tut, the youth of today........
- Bob Bickerton
Longtime Poster -
Posts: 5639 Joined: Fri Dec 20, 2002 12:00 am
As to compression........ we just held the sparrow tightly........
- Bob Bickerton
Longtime Poster -
Cheep-skate!
- ConcertinaChap
Jedi Poster -
Bob Bickerton wrote:As to compression........ we just held the sparrow tightly........
Unconventional, but I suppose anything that allows a raise in the average signal level counts
Posts: 9977 Joined: Wed Sep 01, 2004 12:00 am
Aye.... you could also use sparrows to apply expansion...... but forum rules wouldn’t allow me to explain how that’s done.......
- Bob Bickerton
Longtime Poster -
I've been using an ART Pro VLAii for a while, for mono and stereo sources, and it's always produced pleasing results without much fuss. But one channel has keeled over and I've yet to fix it, so in the meantime I'm using (Harrison) MIxbus' stock channel and bus compressors. Control is pretty limited (no pun intended) but they are handy and you can side-chain the buses, which is more than my ART can.
I notice Gramotech have just launched their new Pompeii multiband compressor (a touch under 30 quid at the time of writing). I've yet to put that through its paces, but if it's anything like their Babylon EQ it should be pretty decent.
- nathanscribe
Posts: 1566 Joined: Fri Jan 19, 2007 12:00 am
Hard to pick a single compressor as I try to pick and use things that fulfil a specific role in my workflow i.e. a fast compressor for transient control, a slow compressor for levelling, a transparent compressor for sneakily compressing things, etc. Also, features like external sidechain or a gain reduction trace are important yet it's surprising how few plug-ins support these things.
DC8C3 - Best all-around
bx_console N – Good general purpose
Summit Grand Channel - Slow, also saturation
TB BusCompressor 3 - Clean
TDR Kotelnikov GE - Clean RMS but not Peak
Cheers,
Chris
Cheers,
Chris
I have two BSS DPR402's, a couple of old Yamaha GC2020's, and a Behringer Composer.
They are sitting in my basement, never used. I don't like compression, the only times I've ever used it was when we used to record our band at home, it's a tool to keep things under control, a utility device AFAIC.
I have used Summit and Avalon compressors in one off situations, recording female vocals, I really like those things, you can hear straight away that they are a cut above, but not only for compression, just putting a signal through them does nice things, but it's not worth my while investing, they'd hardly ever get used.
So how do you manage your levels issues, do you ride the fader while recording or automate on mixing? Or use clip gain etc?
Last edited by Dr Huge Longjohns on Sun May 19, 2019 7:46 pm, edited 1 time in total.
- Dr Huge Longjohns
Posts: 3953 Joined: Thu Apr 10, 2003 12:00 am
The problem with threads like this is that, if you've only tried two compressors, for instance, your experience is limited to those two. I'd rather have the opinion of someone who's used loads.
It's the same with monitors - Most people have not used enough types of monitor (I've been using the same pair for ten years) to give a useful insight - once you've bought a pair, you really have to live with them (unless you want to send them back).
The far more interesting question is probably where to use compression...
The DAW I use has a master bus compressor but I don't ever user that as that's really where a mastering engineer comes in.
A lot of people like to compress entire drum tracks, but again, that's not my bag, personally. I use compressors only in three areas:
- Bass (if it's a bit flapping / wavering, it can level out those levels)
- Kick Drums (to make them kick harder)
- Sidechain compression for that often-used ducking effect, on pads, using a parallel kick drum channel as the input. It's an effect that's been rinsed to death in electronic music but you're almost obliged to do it now in that style of music, and it's quite easy to set up.
Hope that helps.
Hope that helps.
kingmoot wrote:The DAW I use has a master bus compressor but I don't ever user that as that's really where a mastering engineer comes in.
Well, you're only thinking of one use case here - a mastering engineer optimising loudness for the final product. There are other use cases - for example, it's very common to mix into a buss compressor for mix "glue", just helping the mix to gel together better. This is not about maximising volume, or level control, but simply to make a more pleasing mix.
And there are other ways to use compressors than just general leveling or gain control. You can, for instance, soften or harden initial transients - eg, to soften a hihat sound, or to make a kick harder, and you can use parallel compression to add weight, or even multiband compression (or across mults) to help a part "speak" better. And other techniques too.
So it really depends on your tastes, aesthetic and needs which tools you use, and what you use them for...
Yes, if you're not experimenting with a compressor on your mix you're missing a huge amount of potential sonic goodness. I like to use the compressor here to help the mix work rhythmically, for example.
- Dr Huge Longjohns
kingmoot wrote:I'd rather have the opinion of someone who's used loads.
This isn't actually what I mean at all. Scrub that. What I think is more useful for the OP is to gain insight from those who feel they really understand the concepts and use-cases of compression.
There's so many factors in whether the end result will sound good outside of the specific compressor, that it's foolish to blame your shoddy mix the compressor itself. What you are compressing, why you are compressing and how you are doing it are far more interesting questions to ask, which is why I listed my main (current) uses.
For the record, I'm by no means claiming to be an expert - I'll happily admit a lot of my earlier pieces of music never involved any compression at all.
desmond wrote:kingmoot wrote:The DAW I use has a master bus compressor but I don't ever user that as that's really where a mastering engineer comes in.
Dr Huge Longjohns wrote:Yes, if you're not experimenting with a compressor on your mix you're missing a huge amount of potential sonic goodness.
I guess the point I was trying to make is that the mastering engineer that I've used definitely does more than that. Given that he's working entirely from the bounced master audio track, and has a huge amount of outboard / eq / compression options at his disposal, I prefer to use his expertise to apply the appropriate master bus processing.
Whatever works for you, obviously - but I just found that his approach was worth paying for, and sounds way better than what I could achieve with my very limited (and entirely software-based) options / abilities.
I suppose I'm just not that interested in it as a "thing" - the writing, producing and mixing is hard enough!!
kingmoot wrote:I guess the point I was trying to make is that the mastering engineer that I've used definitely does more than that. Given that he's working entirely from the bounced master audio track, and has a huge amount of outboard / eq / compression options at his disposal, I prefer to use his expertise to apply the appropriate master bus processing.
Sure - and no one's saying a good ME isn't worth paying for, and won't do a good job.
But there *is* a difference between *mixing into* a compressor on the master buss, versus not.
In either case, the ME can still add whatever magic he feels is worthwhile, and as you say, if someone doesn't know how to really use the appropriate tool, well, appropriately, then best not use it at all...
