I’m just arranging some synths/mixer/fx in a corner of my studio and wondering how to keep maximum sonic flexibility. Some of my hardware FX boxes are described in their manuals or other blurb as ‘true stereo’ (e.g Lexicon MPX110/500, Alesis Microverb, Digitech DL-8, SP-7, CR-7). I presume that means that the L/R Inputs are not internally summed to mono before being processed, and that the processing (say reverb or delay) responds to the stereo input signal in generating its output. It was a good while ago, but I am pretty sure I heard my Digitech Hardwire DL-8 delay repeats following the stereo input of a panned synth. Beyond that, I haven’t really played with my hardware FX to see what difference a mono/stereo input makes to certain types of processing. I like stereo panning on (some) synth patches, but also stereo chorus and phasing, so am curious about the likely interaction between these. An obviously stereo effect like ping-pong delay would do what it does irrespective of mono/stereo input, but others, like reverb, might respond differently.
The question also relates to whether to use something like a Lexicon on an aux send from a mixer (Mackie 1202). Advantage: all inputs have access to 2 Aux sends > FX units; disadvantage: the sends are mono. I have enough FX to stick something directly on the stereo output of each synth that doesn’t have FX - or decent FX, e.g. SQ80 (none), KingKorg (nice Mod FX but crap reverb), V50 (early digital FX much surpassed by even a Lexicon MPX110). So if I had a synth sound which panned L/R by envelope or LFO, would say reverb be likely to sound different if fed by either a mono (Aux send) or a stereo (direct from synth) signal.
Perhaps the answer is suck it and see, but I thought it would be helpful to ask the vast experience that is SOS what ‘true stereo’ means for hardware FX, and whether using an Aux send as a mono input might limit the potential of the FX.
Then there is the whole other question of whether the FX allows the dry signal to be fully killed, preferably with a simple wet/dry mix knob. The rack units generally do, the pedals generally don’t (I don’t have any Strymons!) Some Mod FX obviously need the dry signal killed (vibrato - others?) but I’m not sure about Chorus and Phasing - can the dry signal always be part of the FX mix, or are there some FX, such as stereo chorus/flange/phase, where only the ‘wet’ sound is heard, with no dry component? In which case, does any stereo (panning) element of the synth sound get lost? Or does that depend what ‘true stereo’ means for different devices?
Sorry for the rambling questions. It would be so much easier if I did everything in the box, but I like my chunks of metal
