Komplete is Blacklisted after upgrade to Cubase10
I have just been jumping about with glee after having successfully upgraded to Cubase10 and then I find out my Komplete10 won't work as Cubase10 "No Longer supports 32-bit plugins" so does that means I have now several £100's of software that is rendered useless, that's apart from all the projects that are locked into Komplete?
Well thanks Steinberg, thanks for nothing
Does Reaper supports 32 bit because I sometimes lose patience with Cubase, I am seriously thinking of making the jump, it'll be a big one of course but to sell software without telling the prospective buyer that most if not of their projects won't work any more and considerable investment in software all down the cludgy is not on, bang out of order
Re: Komplete is Blacklisted after upgrade to Cubase10 - oops, wrong again
OneWorld wrote:I have just been jumping about with glee after having successfully upgraded to Cubase10 and then I find out my Komplete10 won't work as Cubase10 "No Longer supports 32-bit plugins" so does that means I have now several £100's of software that is rendered useless, that's apart from all the projects that are locked into Komplete?
I have now found much of my software is both 32bit and 64bit
However having a major problem - I use a 4K monitor, but for some reason Cubase10 is not showing any text in any of the menus, I click on the Menu header, which does have text, but the drop down lost has nothing but black white spaces
Reaper will support 32bit plug-ins, doesn't sit quite as neatly in the plug-in window but they do work.
Reaper supports 32 bit plug-ins and also seems happy to exchange projects between 32 and 64 bit versions of the program.
Cakewalk does it pretty seamlessly, the only difference is that with 32 bit you have to manually click out of the plug GUI to use the DAW keyboard controls.
To be fair, the dropping of 32-bit in Cubase was way back in 2016, and there was a lot of fuss made over it back then and since. We've had plenty of time to find 64-bit alternatives by now.
If it really bother you, you could use jBridge, but if you're going to stick with Cubase(?), then I'd suggest weaning yourself off 32-bit.
The Elf wrote:To be fair, the dropping of 32-bit in Cubase was way back in 2016, and there was a lot of fuss made over it back then and since. We've had plenty of time to find 64-bit alternatives by now.
It's not always an option, unfortunately. The wonderful VoS plugings are 32 bit and will stay that way (unless Herbert gets again interested, but I've been there myself and usually it doesn't happen). I would not give them up - and luckily I don't have to with Cakewalk
There are a few 32-bit plugs that I still sorely miss, as I also very much miss the ability to create feedback loops that Steinberg took away from me.
But you sigh, take a breath, and move on...
Though I haven’t tried it yet, Vienna Ensemble Pro claims to be able to load both 32 and 64 bit plugs.
My main DAW is Digital Performer. I believe it was version 8 where you either had to launch as 32 or 64 bit. In version 10 also nor supported. At this point all my plugins are 64 bit so Its not an issue.
I’m still grumbling about the money I spent on TDM plugins...
Here are some Unfinished Sounds.
The Elf wrote:There are a few 32-bit plugs that I still sorely miss, as I also very much miss the ability to create feedback loops that Steinberg took away from me.
I have a much more serious problem now - when I click on a menu, the File Menu for example, the 'list' drops down but it isn't populated, it is as though there is white text on a white background. This problem is mentioned on the Steinberg forums by a lot of people, and amongst the 'fixes' suggested by Steinberg - use another monitor, yeah sure, when I have just laid out several £100's for a new 4K monitor.
I have tried having HiDPI both on an off, making sure the Win10 default system fonts are being used. It is the case now I want to go back to Cubase 8.5 but my 8.5 license on the dongle has been replaced by the Cubase 10 license, although the Cubase 6 licence remains.
Also the installation updated GrooveAgentSE and several VSTi and they too suffer from the menu problem, nothing displays so I have some projects that use GrooveAgentSE (I actually have the full version of GrooveAgent but prefer the SE version) is there any way I could roll back to the original version of GrooveAgentSE and the other updated VSTi's ?
If I could at least get my VSTl's back I could live with the Cubase10 problem, till they come up with a fix, but without the original VSTl's I am stuffed.
Is it possible to get a refund on software that is not fit for purpose, I paid using PayPal, I fear maybe not because how would I get my Cubase 8.5 licence back? I made an image of the PC before I did the Cubase10 upgrade but as I mentioned, the 8.5 licence has gone off my dongle
All is not lost, your Cubase 10 license should allow you to run 8.5.
- Rich Hanson
Frequent Poster - Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Make sure you've updated your graphics drivers.
Also try trashing your Cubase preference files (there are notes on how to do this in Windows somewhere). The fact that you've done a big upgrade from an old [not -1] version might have broken something when it's tried to copy your settings from old to new.
Beyond that... try Cubase 9.5? Your 10 license will let you run any version you prefer.
These things are always fixable - just don't panic!
Rich Hanson wrote:All is not lost, your Cubase 10 license should allow you to run 8.5.
It does but as I mentioned GrooveAgentSE, Retrologue etc have also been updated and they are suffering from the same problem - no text on the menus, even when running in Cubase 8.5 and I have looked over my system and sure enough, the older versions have gone
The Elf wrote:Make sure you've updated your graphics drivers.
Trash the Cubase Preference files - how do I do that?
Yes I have updated all drivers, although I am beginning to suspect the graphics card although on the Steinberg site and Gearslutz that Cubase doesn't like NVIDIA cards, so sometime ago I swapped my graphics card out for Radeon/AMD a few years ago and had no problems till now.
On the Steinberg site it suggests turning off/on HiDPI, try a different monitor, try different resolutions, ensure the graphics are not an Intel(whatever) it isn't I have tried all those fixes and more - no fix
Are you suggesting I go out and buy Cubase 9.5 as well - sorry, I don't think so! or is it the case I can go to the Steinberg site and download 9.5?
The Elf wrote:Just download 9.5. With your C10 license you can run all previous versions.
I might try that later, so I'll have Cubase 8.5, Cubase 9 and Cubase 10 all on the same computer! I'm fed up with it now, am going for a cuppa and sod it
Mind you, if I download Cubase8 and re-install it, it might well just put the older GrooveAgentSE etc back, I can live with C10 not working, a fix will come along one day, but I really need the VSTi's back, but seeing as I made an image of the PC before installing WIn10, I could revert to that image and the C10 will cover 8.5? worth a try
OneWorld wrote:Trash the Cubase Preference files - how do I do that?
As I mentioned, there are details somewhere on the web. I've done it myself long in the past. Try scouring the Steinberg forums, perhaps.
https://steinberg.help/cubase_pro_artist/v9/en/cubase_nuendo/topics/customizing/the_preferences_disabling_t.html
https://steinberg.help/cubase_pro_artist/v9/en/cubase_nuendo/topics/customizing/where_are_the_settings_stored_c.html
The Elf wrote:OneWorld wrote:Trash the Cubase Preference files - how do I do that?
Right yep, yes I already tried that - starting in safe mode etc
Nobody seems to have mentioned that, as you have a full licence for Komplete, you should be able to just download the 64 bit versions of everything from NI with no charge....
Cant help you with the rest of the problems but FWIW Reaper has (since version 1.xx for me) been the most stable and forgiving DAW I have ever used & I have (and still do) used a fair few.
- IvanSC
Frequent Poster - Posts: 3041 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime, please!
IvanSC wrote:Nobody seems to have mentioned that, as you have a full licence for Komplete, you should be able to just download the 64 bit versions of everything from NI with no charge....
I had examined the blacklist and for whatever reason when I installed Komplete is installed both 32bit and 64bit, when I refreshed things, the 64bit stuff came back into view, the 32bit remaining blacklisted, no matter I didn't want 32bit anyway.
However I have a much more perplexing problem now. When I installed Cubase 10, none of the drop down menus were populated, just a blank white space. So I made sure my copy of Win10 was up to date, it wasn't so I updated it, wow, menus were as normal, problem fixed, or was it...............my ICON QCON stopped working, it fires up the faders all go back to zero but that's all that happens, I could see the activity lights for MIDI in/out working.
Also the pads on my Novation Launchpad work but do not light any more.
I had a reply from ICON and they pointed me to download some Korg software that strips out any semblance of any MIDI, but I have my MOXF, VirusTI, U-Control (which I have customised to control plugins) UAD, Liquid56, XV5050, XL1, Beatstep and I do not relish the thought of re-installing that lot, though I guess I'll have to seeing as my control surfaces don't work any more. But thanks anyway
Does the Launchpad use Automap?
Even if you're up to date with the latest version on the Novation site (4.12) it currently only supports as far as Cubase 9.5 - I took the opportunity of the sale to upgrade to Cubase 10 and my Remote SL Mk II doesn't have complete normal functionality, as Automap doesn't recognise the new version of Cubase.
It still works for all of the normal MIDI functions, but I assume that Automap is responsible for more of the communication from the PC to the device in terms of the features that aren't included in the normal MIDI standard, as I too am finding that not all of the bits are illuminating themselves in the normal fashion.
Ho-hum, I'm sure I'll have got accustomed to it just in time for a new version of Automap
- Logarhythm
Frequent Poster - Posts: 1093 Joined: Fri Mar 30, 2012 12:00 am Location: On an intergalactic voyage to collect fresh electrons
Logarhythm wrote:Does the Launchpad use Automap?
Thanks but last time I used Automap it almost brought my PC to a halt as it had trouble coexisting with other controllers, Automap didn't seem 'intelligent' enough t leave other things alone, and anyway I am using Launchpad in a custom setup that does things I don't want Automap to do. I painstakingly set it up using the Cubase Learn feature, and it was working an absolute treat till the Win10 April update came along.
I am scouring through the Windows Registry and it is literally festooned with references to devices/controllers I got rid of years ago
