Internal PSU - so space isn't the issue...
Re: Internal PSU - so space isn't the issue...
We're getting there with USB wall warts powering most tablets and smartphones. I still need 4 different cables mind you (Lightning, 30 pin, mini USB and micro USB). Roll on USB C becoming truly universal.
Sam Spoons wrote:We're getting there with USB wall warts powering most tablets and smartphones. I still need 4 different cables mind you (Lightning, 30 pin, mini USB and micro USB). Roll on USB C becoming truly universal.
I'm sure it will - right up until USB D comes out...
Since getting my first ever smart phone I have found you can pay £10.00 for a 1mtr USB A to C cable (more if you like!) or £1.00 at Pound Land and AFAICT there is no difference in performance. Might be at 3mtrs.
USB "D"? Bit cynical? A and B and 3.0 were with us a long time and the upgrade to C was I believe driven by the need for speed? How much faster can a cable connection of useful length get? Pete?
Cynical?
I have 4 different USB connectors for synths and other audio gear, not to mention 30-pin and lightning apple connections. It’s pitiful!!
Oh, and three different laptops with three completely different power supplies - with three completely different connectors...
And some have plugs and others have clover-leafs and another has fig8...
I have multiple spare power supplies for all my gear - and an accountant somewhere is laughing and rubbing his hands.
blinddrew wrote:I like Dave's hybrid suggestion though. 3 or 4 different power units that all comply to a set of standards and come in standard size boxes. Bolt on the back / bottom as final stage of manufacturing.
It can be even simpler - a standard 110-240V IEC connector!
Are you guys all so commonly experiencing power supply failures that they need to be always on the outside? The last PSU failure I had was about 5 years ago - and that was on an *external* PSU for a Novation Drumstation!
That is the whole point of the thread Elf. Internal mains supplies give problems with production lines. As I said, it is cheaper to make the whole thing run on 12 volts or so and buy in a PSU from another manfctr. Yes, SMPSUs ARE very reliable but only because the people that make them have had vast experience* doing it. For a relatively small company to design one in house is a major PITA.
The company can also be sure that the dangerous bit meets all the safety regulations around the world. In short, they hand the problem over to somebody else!
*I "grew up" with the gestation of switch mode supplies. First in tellies then in VCRs and let me tell you they were unreliable ****! And to add insult to injury, bloody hard to repair. They also did not like thunderstorms!
Post by BigRedX »
Rich Hanson wrote:Many years back, we were setting up for a gig, I had an SY22 at the time which had an external PSU. Some klutz(*) stood on the low voltage cable, ripping the wire out of the plug into the synth. On that occasion we were lucky that the landlord had a universal supply that we could use.
(*) i.e. me
The low-voltage side of most external PSUs is appalling and they are supplied with all sorts of cludges to make the standard non-latching plug not be a liability on stage.
Both guitarists in my band, have in the last 6 months, had external PSU failures for their multi-effects pedals; one at the device end where the wrap to stop the lead being pulled out caused the cable to wear out, and the other at the PSU end.
Even if you fit these PSUs inside a rack case or on a pedal board, it's yet another thing that has to be secured into place, and I have yet to see one that makes this easy or reliable. I won't look at any equipment for live use that requires a external PSU unless it is indispensable and there is no alternative.
BigRedX
BigRedX wrote:I won't look at any equipment for live use that requires a external PSU unless it is indispensable and there is no alternative.
Yep, that's pretty much my approach. Other than laptops (for which I have at least two PSUs with me at all times) I now have *nothing* on stage with me that requires an external PSU - and that's how it's going to stay.
I'm prepared to make exceptional compromises in the studio, but it would have to be a heck of a goodie. I'm sick of having to find plugboard space for the wide/tall warts that prevent use of adjacent sockets, and find space for the line lumps with their 'just too short' cables.
But, as I said, while ever we roll over and take it - and even make their excuses for them - then manufacturers will continue to take the easy/cheap way out and leave us to make the best of it.
I've used these for all sorts of things. Small, cheap (even from RS) and all compliance issues taken care of. All it takes is some enterprising company to stick this on an angle plate prewired with a couple of output tails and a fused IEC chassis plug.
If all the PC makers (except Apple) have been able to agree a standard PSU for years why can't the synth makers? Indeed, for the larger synths, they probably could use a PC PSU
Posts: 20887 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
I feel your pain Elf I really do! But manfctrs follow the public and the public WANTS cheap!
Now, if I was roadie'ing/techy'ing for a band (coz I can't play for **** now) and they had a gaggle of DC lumps I would put them all in case of some kind and tie all the mains cables to a common feed (they all draw bugger all) Then splice in some robust wire for the DC outs, carefully labelled for what goes where. Guitar pedals would run on rechargeable battery packs, no hum loops or twitterings!
Pickup from the Merc Sprinter, plonk on stage, find ONE 13A outlet, feed DC to kit. I am sure I could come up with some way to secure the cables to the synths? Solving **** like that was what I did for a living for ten years. Then a bit like that for 3 years at B's!
Post by Exalted Wombat »
Equipment that uses mains voltages requires safety certification for the territory it's sold in. Equipment than runs on 12 volts doesn't.
Rather than certifing 20 different models in each one of the territories, it makes sense to certify ONE external power supply for each territory. Or to buy it in from a specialist supplier.
And that's why we're going to continue to see wall-warts and power bricks.
Exalted Wombat
Posts: 5847 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Exalted Wombat wrote:Equipment that uses mains voltages requires safety certification for the territory it's sold in. Equipment than runs on 12 volts doesn't.
Then why does so much gear (much of it inexpensive) have internal PSUs?
Who knows Ee! The world of the equipment designer is a weird one.
Often they will be given a design brief (by people who don't actually USE your particular bit of kit!) telling them. "You must use THIS loudspeaker drive unit" (coz the buyer, who is the MDs nephew cocked up and ordered 10,000 crap ones) or, "the case can be THIS long, wide deep, no more. Or.."We can't afford to build another production line for this product so it will go on the one with the 12 yr olds on it. Best no mains voltages".
Ok so that last one was a bit naughty but believe me! The reason things get made the way they do and why rarely follows a linear path and often has little logic to it.
As Mr Jagger had it? YCAGWYW...but you can try!
Not the whole story.
If all the different bits of kit use a single unmodified, fully enclosed PSU module (and only that module has any high voltage parts), then only that module needs to be certified.
A company I worked for some years ago was in this situation, and the MD, rather than contacting certification companies (with a vested interest), instead talked to insurance companies.
An another thing!!
I have been banging a drum for AGES about the loss of MIDI ports on AIs. OT? you'd think but, bear with...
Much the same arguments re internal supplies i.e. cost, space. And yet some very low cost, sub £100 AIs have had DINs and some pretty expensive ones not. Again, little rhyme or reason.
Folderol wrote:I've used these for all sorts of things. Small, cheap (even from RS) and all compliance issues taken care of. All it takes is some enterprising company to stick this on an angle plate prewired with a couple of output tails and a fused IEC chassis plug.
I would have thought that something like the one at
https://uk.rs-online.com/web/p/embedded ... s/1812202/
would be more appropriate with all the high voltage parts encapsulated (though you'd still need a fused IEC inlet). Only a fiver plus the cost of the IEC connector and probably far cheaper than that from a distributor set up to deal in higher quantities.
James Perrett wrote:I would have thought that something like the one at
Which constituency are you standing for? I'll vote for you! :clap::thumbup:
You guys are great! :bouncy:
Yes, all very nice but you still have mains volts coming into the equipment and that is where the regulations and handling problems lie.
You need the PSU totally insulated with just IEC one end and DC the other and not part of the case or chassis. Like my ex printer, almost.
Post by johnny h »
In my discussions with gear manufacturers, its a lot simpler to gets certification around the world when using external PSUs. Also its very easy to change an external power supply at a late stage, or even in later revisions (like with the Waldorf 4-Pole moving from 9v to 12v when part shortages necessitated different filter chips).
johnny h
Posts: 4405 Joined: Mon Jul 24, 2006 12:00 am
If you're a company that sells 'professional' electrical devices around the world I EXPECT you to make the effort to get whatever internal PSU certification is required. You do this because you want to give me the best tools to do my job, and you want to make life easier *for me*.
Anything short of that means that you're taking the 'easier' route for yourself, and you obviously don't give a stuff what I think or need - so you don't deserve my money. Simple! :tongue:
P.S. This makes for interesting reading...
https://www.rane.com/rap.html
Here's a company that was prepared to admit they got it wrong by using an external PSU, and express their regret to their customers. That's a gold star to Rane in my book. :clap: Would that they all would come to this conclusion and had this humility.
(I actually swapped out my old Rane SM82 for a newer, internal PSU, version for this very reason, long before I saw this document.)
johnny h wrote:In my discussions with gear manufacturers, its a lot simpler to gets certification around the world when using external PSUs.
There are different rules and regulations around the world for boxes that have a low voltage DC power input as opposed those with a mains power inlet.
So it's typically much easier, quicker, and cheaper for manufacturers to design, build, and get approved status for products with DC power inlets and then ship them with a bought-in and already type-approved third-party wall-wart or line lump mains supply. It also allows the chassis to be smaller and lighter, which may be another key consideration in some cases.
Obviously, this approach is often not very convenient for the end-users, as the Elf has said very clearly, but that may not be a consideration that features high on the manufacturers' priority lists... at the moment... Time-to-market and retail price are probably much stronger motives for most, compared to the loss of a few potential sales to users who strongly object to external PSUs.
If more of us objected more vocally -- like the Elf -- then maybe the manufacturers would change their approach. It's already been pointed out that plenty can and do build universal mains supplies into their products, either with type-approved third-party units or their own in-house designs. So it can be done... but it does involve a real cost penalty which the end user will have to be prepared to pay for.
The Elf wrote:Anything short of that means that you're taking the 'easier' route for yourself, and you obviously don't give a stuff what I think or need - so you don't deserve my money. Simple! :tongue:
That seems an entirely reasonable and rational argument, and one I wholly support.
Erm... I think that's an interesting spin you've put on it!
In fact, Rane worked very hard to persuade the entire industry -- through the AES standards body -- to adopt a universal external power supply system, and made some very good arguments for the concept. It failed to gain international standards status simply because it was just too complicated to get widespread agreement on the most appropriate format to adopt.
The regret expressed in that specific document was not that they used an external supply for some of their products at all, but rather that a specific external supply they bought in from a third-party was no longer available because it couldn't comply with current international regulations...
However, the fact that they subsequently decided not to build mains supplies directly into their entire range of current products (presumably still using bought-in modules) is a happy outcome... but I'm not convinced it was directly as a result of the RS1 going obsolete....
Hugh Robjohns wrote:but it does involve a real cost penalty which the end user will have to be prepared to pay for.
Nail. Head. Hit.
Post by johnny h »
Hugh Robjohns wrote: In fact, Rane worked very hard to persuade the entire industry -- through the AES standards body -- to adopt a universal external power supply system, and made some very good arguments for the concept. It failed to gain international standards status simply because it was just too complicated to get widespread agreement on the most appropriate format to adopt.
It doesn't seem a very good idea to me. I mean, when you have something like a Moog One or a Jomox Alphabase (which needs 2amp @ 12v) vs Roland Boutiques on 5v or small monosynths requiring very little power, the whole system would be end up even more complicated than the problem it was supposed to solve.
Behringer managed to put an internal power supply on their economy DeepMind synth. Did they get enough credit for this? If not, manufacturers will continue to serve up more awful wall wart mess.
johnny h
