Audio Interface and Reaper
Post by David1954 »
Anyone using Reaper, what do you suggest as the best audio interface.
David1954
Posts: 6 Joined: Thu Feb 07, 2019 7:48 pm
Re: Audio Interface and Reaper
Reaper works with just about any audio interface. It would help to narrow things down if you could tell us a little more about what you want to do with it. How many things will you want to record at the same time and how many outputs will you need?
Post by David1954 »
I'm thinking 4 inputs will be enough. I work with another song writer and we are using two acoustic guitars and 1-2 vocals.
David1954
You haven't mentioned a budget, but interfaces with 4 mic inputs pretty much start here: https://www.gear4music.com/Recording-an ... rface/1WMY and then go up as high as you want to go. :)
Post by David1954 »
The Behringer is the one I was actually looking at. The reviews looked good and it does fit my budget. Thank you for your reply.
David1954
If you need 4 inputs now consider buying an interface with 6 (or maybe 8) if the budget allows. Four mic and a couple of line inputs allows a keyboard or drum machine which may be useful in the future.
Posts: 22900 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
Post by David1954 »
Thank you Sam. That's good advice.
David1954
Post by ConcertinaChap »
Have a shufty round this lot. You should find something that will meet your needs.
https://www.soundonsound.com/reviews/ha ... -interface
I agree with Sam, you won't have problems if you have too many inputs but you might if you have too few in the future. An easy way (though it does add to the cost) of ensuring future expandability is to get an interface with an ADAT input. This will allow you at a later date to add up to 8 input channels from an external preamp or similar.
ConcertinaChap
Posts: 15231 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Post by David1954 »
Thank you Concertina Chap. I appreciate your time.
David1954
Not a lot to say here, I'm using Reaper with a Motu 828 MK11, works fine.
As has been mentioned, get more inputs than you need, and check the channel count carefully, the way they market these things is even more misleading than a mixers channel count!
I have to say, as far as quallity goes, I'd always go for Focusrite, excellent units at a very reasonable price, there may be better, but they cost a lot more. I'm only using this Motu because I needed more inputs and someone gave it to me, but I'm going to get another Focusrite at some point.
Posts: 21920 Joined: Sat Jul 12, 2003 12:00 am
Nowt wrong with MOTU either TBF.
Sam Spoons wrote:Nowt wrong with MOTU either TBF.
You're right, but I thought I did notice a difference going from my Focusrite to the Motu, I'm 100% used to it now, don't think about it, works fine.
Post by David1954 »
Thank you Arpangel.
David1954
Post by studer58 »
An additional question regarding Reaper and audio interfaces... do you generally recommend using the interface's software for monitoring through...or using Reaper's own interface ?
I find if both are open I can strike problems with muting, latency etc...so I assume using one or the other, but not both, is recommended ? My particular experience is with the Echo Audiofire 8 interface
studer58
Posts: 74 Joined: Fri Nov 28, 2003 12:00 am
studer58 wrote:An additional question regarding Reaper and audio interfaces... do you generally recommend using the interface's software for monitoring through...or using Reaper's own interface ?
You'll find that you'll have to use any interfaces software at some point, audio has to pass though it. I never even look at my Motu mixer anymore after I set it up, but it's there in the background all the time to control the main outputs etc which I monitor from.
I never have Reaper and the Motu mixer open at the same time unless I want to reconfigure something, it doesn't make any difference to performance though, but I close it unless I need it.
