LDC mic pickup patterns for home recording
Re: LDC mic pickup patterns for home recording
Post by Bob Bickerton »
forumuser840717 wrote: Which is one reason why, for example, using an omni at 90 degrees off axis to reduce brightness is only really a get out of a hole option, not something to be recommended as a standard practice.
Actually this is fairly standard practice for true omni SDCs of reasonable quality such as the Neumann KM183 and perfectly workable. The off-axis response is smooth with just HF attenuation.
Bob Bickerton
Posts: 5637 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by forumuser915213 »
Hugh Robjohns wrote:The M179 is a pretty decent mic for the money, but it is a little on the bright side when used up close. Rather than applying EQ, though, you can often tame that brightness at source by tilting the mic away from the source a little bit -- just lean it back so the wanted sound approaches the diaphragm at a shallower angle instead of 90 degrees.
Having spent a little more time with the CAD 179s (I did buy a second one), I'm inclined to agree Hugh. Thanks for the angling tip, which I generally do anyway to cut out nasal sounds.
I still felt I needed to do some eqing, but it's easy, mild eqing.
More, with mics set to supercardioid and with a drop of digital plate reverb, I've got a result where I couldn't tell it was recorded in a sketchily treated upstairs bedroom.
Gavin
forumuser915213
Posts: 143 Joined: Fri Jan 26, 2018 1:08 pm Location: Kent
