Amp Sims and order of EQ and plug-ins
Post by Guest »
I know whatever sounds best is the best approach, but I'm curious do most people insert their amp sim then eq's after it or would you eq first?
Looking at my guitar pedal board I have EQs before my guitar goes into my tube amp.
But it sounds a bit un natural when I do this using Eleven for some reason.
and I always put flangers and crazy fx last in the chain.
Guest
Re: Amp Sims and order of EQ and plug-ins
The 'traditional' way would be to put 'pedals', including flangers, ahead of the amp, and that's the approach I'd take.
But I would leave delays and reverbs after the amp.
Posts: 21435 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Troll/Spammer
Ignore.
copied from http://duc.avid.com/showthread.php?t=239061
Good spot!
Wonks wrote:Troll/Spammer
:roll: Poster removed. I've left the post up as it might reflect genuine questions from others and the answers already given are constructive and useful.
Post by garrettendi »
Thanks Hugh.
Personally I'm of the opinion for EQ before the amp, and after, much in the same way as you'd EQ a mic coming from the amp speaker
garrettendi
Posts: 3584 Joined: Sat Dec 10, 2005 12:00 am
"The blues isn't about feeling better. It's about making other people feel WORSE, and making a few bucks while you're at it." - Bleeding Gums Murphy
