BBC Location Recording
Re: BBC Location Recording
hobbyist wrote: Because the real physical reconstruction of the analogue signal is not perfect.
It doesn't have to be. It only needs to be good enough to accurately capture enough of the waveform such that the reconstructed result is as subjectively good to the listener as the original anlogue signal was.
In the case of human hearing, 44.1Khz is more than sufficient in the vast majority of cases. At this point resolution is more important than frequency and 24-bit is more than enough for the task. Though I may be wrong here my understanding is that 24-bit resolution is effectively 20 to 21-bit due to the noise floor.
For some applications higher rates may be useful, but that's what oversampling is for and as per another recent thread about plugins this is a well understood mechanism which can be catered for within normal digital environments.
Posts: 9736 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
hobbyist wrote:Because the real physical reconstruction of the analogue signal is not perfect.
That's true... but then nothing is perfect. The reconstructed analogue signal from a tape recorder or vinyl disc player ain't perfect either. Noise and distortion will always manifest to some degree. The only question is how small do the errors need to be to be inaudible... and we know the answer to that.
There are errors in the timing due to clock jitter, and errors in the amplitude due to A/D/A errors.
Yes... but neither are magically solved by a higher system word-clock rate. Actually both are barely measurable these days, and they are definitely well within the acceptable limits such that they are far below audibility in any conventional application. Quantising amplitude errors were effectively eliminated with the introduction of delta-sigma converters, and system clock jitter was wrestled under control by improved clock generator and clock recovery designs long ago.
Added to which, if the jitter element is random it manifests as a (fractionally) increased HF noise floor, which is hardly going to upset anyone even if they could hear it! If it's not random (but instead related some some periodic function) then the circuit design needs to be reworked.
Either way, though, a higher system word-clock rate means that any inherent clock jitter becomes a significantly higher proportion of the sampling period, and this makes the problem much worse, not much better!
This changes what was a nice neat point to a smooshed blob so during the recreation that makes it harder to recreate perfectly.
Oops... there goes that alarm again... :lol:
Posts: 42816 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by CS70 »
hobbyist wrote:
CS70 wrote:
hobbyist wrote:Theory says that the higher rates are better.
No, the theory doesn't. :-)
Okay -- Theory , with a perfect recovery is perfect.
But there are always errors in real life ; and in real life higher sampling rates could benefit the accuracy of the result IF the A/D errors and clock jitter are small enough.
Yes, the math is clear: sampling at double the Nyquist rate maintains all the information in the sampled signal, so the theoretical reconstruction is perfect. There is no information loss. So you don't need anything more.
As of these bothersome engineers, yeah the poor fellows don't seem to be able to mach the beauty and perfection of the math. :D How annoying. But you gotta understand why and what!
For example, increased sample rate require a faster clock! And the faster the clock, the more small inaccuracies in timing become significant. So the higher the sample rate, the more accurate the clocking must be, which as the Romans found out, is quite a lot harder than making a less accurate one. So jitter is a bigger problem at higher sample rates: with the same components and tolerances, you're likely to have a more error in the reconstructed signal, not less - read: worse sound.
As Hugh can explain much better than I, the main issue is that real world lo-pass filtering (which is required to limit the signal to the 20-20K band) is not as perfect as it should be. This in turn may allow some ultrasonic content to alias back in the hearing band. Most mics roll off anyway pretty sharply after 20K, but of course there's some recorded signal that may have content there. 96KHz may help there. Lots of plugins do oversampling for that reason. Tough it helps only if you have ultrasonic content in the first place. I remember he mentioning drum cymbals as a typical source which can benefit (as it's more likely to produce significant ultrasonic energy, which survives the mic roll off attenuation, and may thus get aliased back in the hearing band).
On a practical view tough, I never heard anybody say "hey these cymbals sound odd, probably they've been recorded at 44.1Khz" :-D
Also, keep in mind that 96KHz may put the analogue part of your chain under more strain - and especially with lower end kit, most of the testing has probably been done at the "regular" sample rates. To go over 96Khz for normal musical applications is ... not well thought thru ;-)
Unless it's marketing of course - preying on the honest desire for quality of customers to sell them stuff and even worse, convincing them that the bs is real..
Post by Ariosto »
So would the experts at SoS recommend 96KHz rather than 44.1KHz (or 48K)? At present I record at 44.1KHz and 24 bit.
I just want to record with the best possible quality and not worry too much about the technicalities, and leave that sort of thing to the really clever people who do such a great job with such brilliant engineering and the data it produces.
Ariosto
Posts: 920 Joined: Sun May 04, 2008 12:00 am Location: LONDON, UK
Post by CS70 »
Ariosto wrote:So would the experts at SOS recommend 96KHz rather than 44.1KHz (or 48K)? At present I record at 44.1KHz and 24 bit.
Recording drums or anything with potential ultrasonic content (i.e. over 20Khz) yes. But just record, then you can still downsample in the DAW to 44.1 or 48 to keep file sizes manageable (as if there's an issue, it's the hardware filtering in the A/D converters).
But vocals or guitars, I wouldn't bother. A symphonic orchestra, yes.. That gong there..
I generally record everything at 96kHz....but mostly just because I can rather than because I am concerned about the 'quality' at lower rates -- although I do like the idea of my mics controlling the audio bandwidth, rather than a non-Nyquist filter in a converter chip. It pleases my engineering head that way... :ugeek:
However, I've recorded plenty of stuff at 44.1 and 48, and still do when appropriate, and I've never thought doing so had reduced the 'quality', so if 44.1k works for you, your clients and your workflow, stick with it. It avoids all that faffing about with down-sampling, reduces the archive storage demands, and makes file transfers quicker.
As always, let your ears be the final arbiter -- and trust them over all the Internet myths and BS! :lol:
Last edited by Hugh Robjohns on Fri Jul 12, 2019 11:06 am, edited 1 time in total.
CS70 wrote: Theory says that the higher rates are better.
For *practical* sample reconstruction, maths predicts a low pass filter effect on the source. The filter cut off is related to the sampling frequency, so the higher the sampling rate, the smaller the dropoff on a specific reconstructed waveform.
Because the [sampling theory] output sample stream pulses are moments in time [width tending to zero], they would have very little energy [amplitude x width] which is impractical for an electronic system to handle.
An easy work around is to hold the sample value from one sample instant to the next – a “zero order hold”. This is basically filling in the values between samples with a simple interpolation [drawing a horizontal line – which gives a “stepped waveform”]. The frequency response of the zero order hold is a sinc(x) function.
Better interpolations are available at the expense of more complex electronics -
1st order – linear interpolation, joining the sample points with a sloping line.
2nd, 3rd order and above.... increasingly complex curve fitting between samples.
Early DAC systems upped the sample rate by say holding the sample value for only ¼ period and adding 3 extra samples of zero value in the remaing ¾ period gap.
Todays 1 bit DACs use complex nth order filters. e.g. n=5
Posts: 4760 Joined: Sun Aug 12, 2018 2:40 pm Location: British Isles
N i g e l wrote:An easy work around is to hold the sample value from one sample instant to the next – a “zero order hold”.
I think you're talking about the non-return-to-zero (NRZ) approach where the sampling pulses are the same width as the sampling period -- and that does result in a windowing effect which cases a very small amount of roll-off at the high end of the amplitude response... but it's nothing that is going to cause anyone sleepless nights! -0.1dB at 20kHz is perfectly acceptable...
Yes, there are alternative sampling schemes, but I don't think anyone has successfully demonstrated a genuine requirement of benefit with them in audio applications... yet.
Last edited by Hugh Robjohns on Fri Jul 12, 2019 10:31 am, edited 1 time in total.
Post by Ariosto »
Thanks for the helpful reply Hugh. I will just experiment with 96KHz but probably go back to either 44.1KHz or 48KHz - unless I can actually hear a difference, which I probably won't!
Ariosto
Post by Kwackman »
I am NOT an expert (and this isn't false humility!) I record 24bit and 44.1 KHz. The 44.1 KHz choice is for a couple of reasons that may be incorrect, irrelevant or out of date or all of the above.
1. If I burn to CD I don't need SRC.
2. The main virtual instruments I use are recorded at 44.1 KHz, so I don't want to place more stress on my CPU making it do hard sums.
Kwackman
Posts: 3570 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Makes perfect sense to me! :thumbup:
Post by ConcertinaChap »
It all ends up at 44.1KHz anyway or it does for me, CDs still being the largest part of what I produce. I don't pretend to have golden ears so since I can't hear any difference I take comfort in the Nyquist argument and carry on contentedly.
Last edited by ConcertinaChap on Fri Jul 12, 2019 11:29 am, edited 1 time in total.
ConcertinaChap
Posts: 14720 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Mr Punch's Studio
If a tune's worth playing it's worth playing lots!
Post by CS70 »
ConcertinaChap wrote:It all ends up at 44.1KHz anyway or it does for me, CDs still being the largest part of what I produce. I don't pretend to have golden ears so since I can't hear any difference I take comfort in the Nyquist argument and carry on contentedly.
Just for clarity' sake, the main argument for 96Khz is about recording, not anything downstream (unless it's outboard).
During the physical A/D conversion (that happens just the once) and then less than perfect filters, ultrasonic energy of sufficient level could alias back in the 20-20k range and be imprinted in the recorded samples, so that when the signal is reconstructed, it's audible.
Once the samples are in the bag (or on the disk :)) you can convert to a lower rate in software and - if the conversion algorithm is good - you have no probs and smaller files.
The same might happen when an effect (a plugin) produces new frequencies, some of them potentially ultrasonic - hence internal oversampling in plugins.
For the same reason, a plugin which does not take care of this might introduce aliasing artifacts in its output. So there is a tiny argument for working at 96KHz, but in practice most modern reputable plugins do just fine. And you ears are the final judge anyway.
Hugh Robjohns wrote:
MOF wrote:I’ve just re-read that article Hugh and wondered if the ‘50 feet’ was a typo
Not sure. I've checked my original copy text from 2004 and it says 50 feet in that, so if it was a typo it was mine originally... but I can't believe I would have included a fact like that without having a reliable reference for it because 50 feet is obviously a lot!
I've removed that number from the online article for now, and will try to get some confirmation as to how thick the isolating pads actually are. :-)
I'm trying to find out, as my company (Arup) were the structural engineers and Arup Acoustics were also involved in some aspects of the design (not the concert hall design itself). I can remember reading a synopsis of the construction including the anti-vibration design at the time in an internal publication. But it was finished back in 1991, so almost certainly no viable digital copy will remain unless the hard copies have since been scanned.
Posts: 18707 Joined: Thu May 29, 2003 12:00 am Location: Reading, UK
Post by MOF »
Not sure. I've checked my original copy text from 2004 and it says 50 feet in that, so if it was a typo it was mine originally... but I can't believe I would have included a fact like that without having a reliable reference for it because 50 feet is obviously a lot!......H
by Wonks » Fri Jul 12, 2019 12:24 pm
Top
My understanding of this type of construction is heavy duty coiled springs with neoprene rubber on top (and bottom?) are used between the real floor and the floating floor. Maybe Hugh put a ‘ instead of a “ (plus springs) or maybe it was 50 cm or maybe it was just 5’.
MOF
Posts: 2509 Joined: Thu Mar 06, 2003 12:00 am Location: United Kingdom
Post by forumuser840717 »
Symphony Hall is structurally decoupled by 2000 specially engineered laminated rubber bearings (pads) (laminated in that they're made of sandwiched layers of rubber and steel). They're 300mm x 300mm x 125mm thick. Each bearing takes a load of up to 40,000kg with a primary resonance at 40Hz. They're mostly mounted in groups of eight on the tops of concrete column piles. On top of these is a concrete raft which supports and distributes the load of the building.
The hall was designed as part of the ICC by the Percy Thomas Partnership and Renton Howard Wood Levin with Artec founder Russell Johnson as the principle acoustic consultant. And a very nice job they made of it. IMO. But then Artec are probably my favourite halls generally. Those and halls by Nagata Acoustics.
Last edited by forumuser840717 on Fri Jul 12, 2019 11:07 pm, edited 2 times in total.
forumuser840717
Posts: 485 Joined: Thu Jun 16, 2016 5:20 pm
Thanks for that detail. I'm still awaiting a response from the hall office. I'm wondering if my 50 feet comment referred to the supporting pile depth?
Post by Bob Bickerton »
forumuser840717 wrote:Symphony Hall is structurally decoupled by 2000 specially engineered laminated rubber bearings (pads) (laminated in that they're made of sandwiched layers of rubber and steel). They're 300mm x 300mm x 125mm thick. Each bearing takes a load of up to 40,000kg with a primary resonance at 40Hz. They're mostly mounted in groups of eight on the tops of concrete column piles. On top of these is a concrete raft which supports and distributes the load of the building.
Isn’t wonderful what you can learn on thee forums!!
Bob Bickerton
Posts: 5526 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by awjoe »
We're equally inexpert, then, because I do the same, for similar reasons. I'm grateful in fact that I don't do any video work because that would require me to remember which of two sample rates I was operating in. :mrgreen: Life's difficult enough already. Most of my time's taken up with mic placement and performance. Attention to the weakest link, me.
awjoe
Posts: 5401 Joined: Tue Mar 08, 2011 12:00 am
He could be a morsel of his former self.
awjoe wrote:Most of my time's taken up with mic placement and performance. Attention to the weakest link, me.
So much this ^^^
I record in 24/44.1 because there are about a billion other things that i can screw up long before i get to worrying about sample rates.
By chance i struck it lucky on the video side as well as it turns out that Canon DSLRs and my phone all record their audio-for-video at 44.1 as well. :)
Posts: 28843 Joined: Sun Jul 05, 2015 12:00 am Location: York
The critical thing with digital video is that there are a whole number of audio samples within each video frame. That's the reason the digital audio wordclock has to be synchronised (in one way or another) with the video frame rate. It's also the reason we have the sample rates that we do.
Sony originally chose 44.1kHz because it was more than double 20kHz (to comply with Mr Nyquists requirements), and it worked very neatly with 30fps B&W NTSC video which was convenient for the video recorders MR Sony wanted to use. It provides 1470 audio samples per frame.
As it happens, it also works perfectly with European TV at 25fps (1764 samples), but not with film at 24fps (1837.5).
Consequently , when the standards were being drawn up for digital video recording, it was decided to use 48kHz as the standard audio sample rate, as that gave 1600 samples at 30fps, 1920 at 25fps, and 2000 at 24fps.
Inevitably, it didn't give an integer number for American colour NTSC with its slightly wacjy 29.97fps rate... but then nothing practical ever would. The solution was to allocate the audio over five video frames rather single frames, with 8008 samples across 5 frames.
So... digital cameras working at 25fps (or 50 field progressive) can work quite happily with either 44.1 or 48k audio -- as can most non-linear video editing software.
Post by awjoe »
blinddrew wrote: I record in 24/44.1 because there are about a billion other things that i can screw up long before i get to worrying about sample rates.
I just don't think sample rate's that important. I've tried to hear the difference between 44.1 and higher rates, and I can't. And so if I'm *trying* to hear a difference and can't then the sort of casual listeners who hear my stuff probably aren't going to hear it either, or if they do, it's going to be miniscule.
Digression: Actually, the fact that my ears are shot is a sort of advantage - if I *can* hear something, then by God it's significant. Again, priorities.
awjoe
Post by awjoe »
Mike Stranks wrote: 2) Here we sometimes agonise about whether a particular piece of kit is 'good enough'. Used sensibly, leaving sufficient headroom, these days even quite modest equipment is capable of 'broadcast quality' results.
Discuss...
The only way you can put that one to the test is to see if you can get something broadcast, right?
awjoe
Post by Mike Stranks »
Discuss...
Not these days. Unless its quality is so abysmal that even my 8-month-old grandson would raise an eyebrow they'll use it - especially if they don't have to pay for it!
Technical quality is now very low down the list in what will and won't be accepted.
Mike Stranks
Posts: 10586 Joined: Fri Jan 03, 2003 12:00 am
awjoe wrote: The only way you can put that one to the test is to see if you can get something broadcast, right?
The first thing that I had broadcast back in the early 70's was recorded on a basic Philips cassette recorder with the mic that came with it. I would have to say that its recording quality was much better than most of the competition though the AM radio system managed to lose any hint of high frequencies.
Posts: 16381 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
