WIN10 - Audio Input Suddenly Distorted
Post by Doomofman »
Hoping someone may be able to point me in the right direction on this. I'm assuming it's likely to be a Windows 10 issue, maybe caused by a recent update due to what I've seemingly ruled out already.
Firstly, the issue. As of maybe a week/two weeks ago my audio input signal is distorted, it doesn't clip at any point I can see in the chain but the dry signal is still a bit distorted, once this is run through say an amp sim software, the problem gets magnified. Before this, I used to be able to just set the gain a bit below clipping and be able to record nice clean guitars etc but now, those clean guitars sound muddy/distorted especially on the low end.
I'll list what I've tried already and hopefully someone can point out something I've missed so far.
I've tried:
  • Multiple guitars (Passive and Active inputs)
  • Two audio interfaces (Scarlett 6i6 and POD HD 500X via usb)
  • Different USB 2.0 Ports
  • Different USB Cables
  • Different software (TH-U and EzMix, both inside Cubase and standalone and Audacity)
  • Checked signal direct on my POD HD 500X and it sounds fine, once you use the USB signal it's distorted
  • Two different computers, both with Windows 10 with the latest updates
  • Made sure the Sample Rate is the same through the signal chain
  • Used LatencyMon to make sure there was no issues there
Doomofman
Posts: 6 Joined: Thu Jul 11, 2019 11:20 am
Re: WIN10 - Audio Input Suddenly Distorted
Worth checking that the W10 update hasn't switched any manufacturer software back on. My work Dell, for example, has a bit of Dell software that 'optimises' the sound for playback on the laptop speakers - needless to say it sounds horrible through a set of headphones...
So have a look at hidden items in the task bar or any processes running in the task manager that look audio-related and not something you've deliberately activated.
Post by hobbyist »
Doomofman wrote:Hoping someone may be able to point me in the right direction on this. I'm assuming it's likely to be a Windows 10 issue, maybe caused by a recent update due to what I've seemingly ruled out already.
I've tried:
Win10 is a problem. Worse than win8. Far worse than XP.
For audio.
You must clean out all the crapware and tweak the box to run audio. Delete all the social media programs and anything else that could decide to run, and try to phone home, if it is not needed for the audio.
Then get off the internet and turn off the antivirus program.
I would suggest you consider ubuntu instead of windoze.
But at least make sure win 10 is fixed and then turn off updates!
Leave them off. Forever.
hobbyist
Posts: 285 Joined: Mon Jul 01, 2019 12:52 am
Post by Agharta »
hobbyist wrote: Then get off the internet and turn off the antivirus program.
Don't forget to wear a cape made of aluminium foil and to use a spell from a Harry Potter book to keep the demons at bay.
Agharta
Posts: 4350 Joined: Sat Oct 30, 2004 12:00 am
Post by CS70 »
If the audio appears distorted with two completely different machines, it's likely it's nothing to do with the computer or the software it's running.
Have u checked the guitar cable? A bad cable can often introduce noise and distortion.
CS70 wrote: If the audio appears distorted with two completely different machines, it's likely it's nothing to do with the computer or the software it's running.
Doh! Sorry, missed that bit. Ignore my comment above (if you haven't already). ;)
hobbyist wrote: Win10 is a problem. Worse than win8. Far worse than XP.
For audio.
That's a bold statement and one I strongly believe to be incorrect. Windows 10 has improvements on everything from memory management to device prioritisation and in many ways is a much superior operating system under the hood when compared with earlier versions (with the single exception of privacy issues, which is another conversation entirely).
Two questions:
  • Why do you think Windows 10 audio is a problem specifically?
  • Why do you think it's worse than Win8 or XP?
This is very bad advice unless there is a specific need to preserve a snapshot of a system intact forever. This may be necessary in some professional environments to support clients with legacy needs but even that can cause problems with some licensing as there is a need to periodically contact servers to ensure that licenses are still valid.
Disabling updates on any system (Windows or otherwise) that has to periodically connect to the Internet is irresponsible and dangerous for security reasons. 15 years ago tests were done that found unpatched PCs could be compromised within 20 minutes when connected to the Internet, a time which wasn't even long enough to patch them with the latest updates in some cases.
Furthermore, most software these days is updated frequently. Not only with bugfixes but also for feature and stability improvements. Projects and other saved data created by earlier versions of an application are only going to be supported for so long. This means that work done on a system that has not been updated for an extended period of time is increasingly unlikely to be readable by whatever the latest version of the software is.
Anybody disabling updates on a system without fully understanding the implications of that is asking for trouble at best, and being downright irresponsible at worst.
Some bloatware is a concern, but certainly not all of it. Most of it is simply a waste of storage and harmless in any other sense. Disabling start-up agents is a good idea in many cases and usually quite sufficient.
I regard antivirus software as largely unnecessary these days if one is careful about the sites one visits or email attachments one opens and takes sensible precautions such as ad-blockers in browsers and keeps the built in Windows protection up to date. Backups are essential, however.
Posts: 9985 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by hobbyist »
gratuitous insult noted
hobbyist
Post by hobbyist »
For audio.
I had them both. win 10 may be better now but early on it was a disaster. it is still a social media box that needs fixing for solid audio use.
Two questions:
I had them both. The results speak for themselves. They are both bad. Win 10 was worse. Cant say if they improved win10 or not as I dont use that box. It now being reserved to install a linux version.
That is very good advice unless you want problems. If you get it working then leave it alone. If it aint broke dont fix it. For audio you do not need all the crappy updates microslop will force into the box.
do'H! What part about not attaching to the internet dont you get.
AIR GAP! problem solved for audio use.
Boy, microcrap has really brainwashed you. You have no need for frequent updates. If your box is running right you have no need for updates. period.
I know the implications. That is why I disable all updates. Been screwed too many times with updates that were fixing a non problem and made things worse.
You are a sucker if you believe that about virus protection. If you are on the internet then do not use that pc for audio. And install MBAM which is far better for protection.
Never click on an attachment as that is more dangerous than visiting bad web sites.
You did get it right about backups.
I was a security consultant in a previous job. I stand by what I said.
YMMV so do whatever you want on your PC but I will protect mine the way I recommended.
hobbyist
Post by Rich Hanson »
It was just a gentle leg-pull, for heaven's sake. :roll:
Rich Hanson
Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
Eddy Deegan wrote: Two questions:
hobbyist wrote: I had them both. The results speak for themselves. They are both bad. Win 10 was worse. Cant say if they improved win10 or not as I dont use that box.
Your blanket assertion that Windows XP was bad and Windows 10 is worse is based on the fact that your PC didn't work with them well, and thus your recommended solution to any audio based problem is 'stop using Windows because its audio is bad'?
Really? :roll:
Post by Doomofman »
Wow! this thread took a turn haha
Ok, so yes I've tried different guitar cables..
It's only the input signal that's distorted, audio output is just fine (so for instance if I listen to Spotify through the audio interfaces, it sounds fine).
Again, just to emphasis, everything was just fine up until maybe two weeks ago. I didn't make any hardware changes in that time. That's why I'm leaning towards a software problem.
I've removed and reinstalled the specific drivers for the interfaces and the USB controllers and the chipset.
I've tried both the motherboard's USB ports and a PCI-E USB card I have as well. (though again I've also tried this on a Desktop and Laptop with the same results)
I've tried both USB 2.0 and 3 ports (though the interface is USB 2.0 so that's what should work).
I've no plans to change OS or anything like that, it worked fine before so should work fine again if I can identify the source of the problem.
I've disabled every other Playback and Recording device that Windows show as well.
I feel like I'm running out of things to try at this stage, last resort would be fresh install of Windows but if it's happening on two machines I'm not confident that will help
Doomofman
I've tried:
You've been pretty thorough there. I would not rule out a hardware problem, though it's more likely to be something in software.
Looking at the Focusrite website, I see that the 6i6 software download includes a USB driver for it (version 4.63.23).
On the line6 website there is a driver for the Pod as well. As both of these devices have manufacturer-supplied drivers I would consider this an area to double check. Have you re-installed the USB drivers for both? It is possible that a Windows update could have done something to upset the proprietary ones.
Eddy Deegan wrote: On the line6 website there is a driver for the Pod as well. As both of these devices have manufacturer-supplied drivers I would consider this an area to double check. Have you re-installed the USB drivers for both? It is possible that a Windows update could have done something to upset the proprietary ones.
Sorry, I just realised you posted while I was writing this earlier, and said you'd done that. Have you reached out to Focusrite or Line6 for support? I would imagine that if it's a wider problem they would have seen this before.
I've had no issues with any USB audio inputs from various USB devices on Windows 10 here, though I don't have any of the same hardware you do. Although it could be a Windows issue I'm more inclined to think it's an environmental problem somewhere.
I think a step-by-step process of elimination may be worth a try here.
You have 2 PCs, 2 USB devices and 2 guitars.
If you use the Focusrite on one of the PCs fed by one of the guitars, and on the other PC you use the Line6 Pod with a different guitar, do they both exhibit the same problem with the distorted input?
Post by hobbyist »
Really? :roll:
I said that XP was rock solid.
Win 8 was barely okay.
Win 10 had major problems early on and I gave up on that version.
And changing the user interface every version is not acceptable.
XP is easy to do everything.
win8 makes it hard to find what I need to do.
win10 requires me to have a dummies book handy to figure out what to do with it.
The assertion is because windoze did not work well. win 10 was full of bugs and problems when it was released.
And if you plan to use any windoze system for audio you must tailor it or expect problems. The current ones are bloatware loaded social media interfaces that must be fixed for reliable audio use.
hobbyist
You really do have a very negative outlook on almost all of life, don't you? It's not endearing....
For what it's worth, I've been using Win 10 on my laptop for a few years now with a variety of different audio interfaces (Zoom, Focusrite, SADiE). Haven't tweaked a thing. Never had an issue...
I'm not a big fan of the 'panels' on the touchscreen GUI, but I don't find it a problem at all. It's just a new and different way of controlling the thing... as is Mac OS, or iOS, or Android...
Last edited by Hugh Robjohns on Sat Jul 13, 2019 11:32 am, edited 2 times in total.
Post by CS70 »
hobbyist wrote: And if you plan to use any windoze system for audio you must tailor it or expect problems.
My man, I've been using W10 for two years now recording and mixing daily, and otherwise using it as a regular pc with internet browsing and Netflix watching, and I haven't had to tweak one single thing beyond the device power management settings. Same for the various laptops I've used for location recordings in these years. A blanket statement like yours seems at best an oversimplification.
For the OP - is it only when you use the guitar that the audio input is distorted? If you feed a line signal for example from the phone, do you still hear distortion?
What I find it puzzling is that you have the same issue with two different computers and interfaces. That seems to rule out both hardware and software - unless the computer are identicaly component by component? It seems odd that an update would disrupt two different computers in the same manner.
Post by Doomofman »
Yeah same thing happens with line input on the Scarlett...
Doomofman
Post by Agharta »
hobbyist wrote:
Agharta wrote:
hobbyist wrote:Then get off the internet and turn off the antivirus program.
If you act like a clown I might treat you like a clown.
This is a sub forum for Windows and Linux support for DAWs is so limited that's not an option in any sense for many people. How do I run my Kontakt libraries for starters?
So to respond by suggesting using Ubuntu and using the term windoze marks you down as a clown in my eyes hence my response.
I have nothing against Linux and hope it continues to grow and especially for DAW usage.
Agharta
Post by Flevo »
May be a strange question. Are the twe pc ‘s connecties via ethernet? Is there may be an other distortion source? Have you tried to turn the powerplug?
I can imaginaire that you have tryed iT on the laptop on batteries?
Is there in the program list a new program or update since then?
IT is an interesting problem, i must say that i do several thing on my pc and now and then there are Some issues i cant explain. After reinstal my music software all is back to normal. I am just trying things out.
I want to start more seriously so i bought a MacBook pro no issues at all ( for now)
R
Flevo
Posts: 6 Joined: Sat Apr 13, 2013 12:00 am
Doomofman wrote:Yeah same thing happens with line input on the Scarlett...
Just to be clear ... if you set up the two systems independently with the Pod on one, the Scarlett on the other, and using one guitar with one and the other guitar with the other, the problem exhibits itself on both systems?
Are the two PCs of the same make and model or are they different?
Do you have any other USB audio devices you can try for comparison?
In cases such as this where the obvious things have been tried, it really does make sense to go right back to basics and start over. Having 2 separate systems is a good start :)
Let us know!
Post by Doomofman »
Just an update on this... Been super demotivated by it so just letting it sit for a couple of days in the hopes something inspires me to figure it out...
The two computers I've tried so far are a customer built high-end desktop and a Microsoft Surface Book 2.
I am working towards getting a dedicated PC for my audio setup as the current one is also used for gaming so maybe something there is conflicting so in the next few days I'll have a dedicated DAW machine.
At the moment, if I make enough changes to the tones I can get some passible results but not nearly as pleasant as before and not nearly as easily (previously I could just use any preset without changes and it would sound fine)
So whenever I sort the dedicate machine, that will get a fresh Windows 10 install with only the software and peripherals I need for audio recording, maybe that will solve the issue
Doomofman
Post by CS70 »
Another puzzling thing is that ASIO drivers, which are normally used with DAWs and audio interfaces, entirely bypass Windows audio subsystem. So something software affecting them on two different completely machines with two completely different interfaces sounds very odd. If it were a widespread OS related issue, everybody else would have the same problem, and patently that's not the case.
I would bet hard that it's something related to the rest of the chain. What are the common elements in your trials? I mean guitar, cables, location in the room, power socket etc..
Post by Doomofman »
CS70 wrote:Another puzzling thing is that ASIO drivers, which are normally used with DAWs and audio interfaces, entirely bypass Windows audio subsystem. So something software affecting them on two different completely machines with two completely different interfaces sounds very odd. If it were a widespread OS related issue, everybody else would have the same problem, and patently that's not the case.
I have tried different instrument cables and guitars, I've tested the Scarlett interface on my laptop while it's running on battery and it still exhibited the same issue which should rule out the sockets.
I've tried guitars with passive and active pickups and they exhibit the same problem. The only thing that seems to still be fine is direct monitoring on the POD HD 500X.
I ran a mono line signal from my POD to the line in on the Scarlett interface and it exhibits the same issue too.
At this stage, I try one or two things, get fed up and then leave it a day and repeat that process
Doomofman
