Recommend sofware with high-precision FFT analysis with resolution to -384dB?
Post by Uncle Freddie »
Hi,
Can anyone recommend Mac and/or PC audio analysis software packages that -- and here's the tricky part -- offer high-precision FFT analysis with resolution all the way down to -384dB? That would be 64 bits of resolution.
Thanks,
Fred
Uncle Freddie
Posts: 56 Joined: Sat Apr 23, 2016 12:00 am Location: Detroit, USA
Re: Recommend sofware with high-precision FFT analysis with resolution to -384dB?
Good Lord!
What on earth for? :o
:D that was going to be my question, too!
I'm looking for this depth of resolution for test and measurement of truncation noise and other distortions.
In macOS, I have used Aurchitect's Spectre software for this, eventually switching to their Aura package. Both are considerably buggy. On top of that, in mid-May the company went out of business over ownership lawsuits. They even wiped their website (http://aurchitect.com) completely off the air.
I recently began using SPL Hawkeye, but it only goes down to -220dB (I have filed an enhancement request to increase that to -384dB)
Surely there must be software out there, Mac or PC, perhaps aimed at the test and measurement audience, that can do this?
Thanks,
Fred
Uncle Freddie
I must admit I'm still a bit in the dark - highly regarded plug-in developers have stated that in most cases for audio work you can declare anything further down than -125dB below the signal as inaudible :?
Last edited by Martin Walker on Sat Jul 20, 2019 8:53 am, edited 2 times in total.
Martin Walker wrote:I must admit I'm still a bit in the dark - highly regarded plug-in developers have stated that in most cases for audio work you can declare anything further down than -125dB below the signal as inaudible :?
Quite. Nothing is that quiet except perhaps liquid Helium?
Is there a theoretical measurement for 'absolute silence'? :D
I'm beginning to suspect that Uncle Freddie may be exploring mathematical concepts/algorithms, rather than real-world audio.
However, I'd still be surprised if any signal that low would be worth exploring, apart from in a cutting edge lab environment.
Fascinated to hear more though!
Sam Spoons wrote:Is there a theoretical measurement for 'absolute silence'? :D
Well, as per my "He" at absolute zero, by definition energy is zero* so that has to be zero noise?
*I understand there can still be electron spin but can you "hear" electrons? BTW "I understand" is just a turn of phrase. I don't!
Post by Logarhythm »
There is no absolute zero, Dave ;)
Well there is in terms of 0 Kelvin, but quantum mech prohibits this being a truly zero energy state and it's perhaps better viewed as the lowest energy state - thus there will still be "noise" of sorts, and indeed noise is perhaps an appropriate adjective for e.g. quantum vacuum fluctuations.
And I'm also really curious to know what Uncle Freddie is up to!
Logarhythm
Posts: 1093 Joined: Fri Mar 30, 2012 12:00 am Location: On an intergalactic voyage to collect fresh electrons
It's amazing the things you learn on here.
Post by ConcertinaChap »
Logarhythm wrote:There is no absolute zero, Dave ;)
That's true. Interestingly from a classical perspective as well you can't reach absolute zero because it's one of these boundary conditions, like the speed of light, that require greater and greater amounts of energy the closer you approach them and would require infinite energy to actually achieve.
Logarhythm wrote:And I'm also really curious to know what Uncle Freddie is up to!
Last edited by ConcertinaChap on Sat Jul 20, 2019 11:03 am, edited 1 time in total.
ConcertinaChap
Posts: 15234 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Can't be for audio, as the electronic noise of the input system will create a noise floor way above the lowest resolution of the analyser. That limits the resolution of a standard 24-bit A/D audio converter to maybe 21 bits, 22 at best. So even if you used a 64-bit A/D converter set up with it's upper limit at around 150dB, I'd guess you'd be wasting at least 30 of those bits as they'd be below the electronics noise floor.
I would be delighted to tell you all what I am up to, but I cannot at the moment. ;) Soon, though.
In case I was not clear earlier: Aurchitect's Aura indeed has FFT resolution down to -384dBFS. What I am asking for is not unheard of. :D
I still use it, or rather I try desperately to use it, because I am fed up with its bugs. Which by the way will never be fixed, now that the company has gone belly-up.
Aura is Mac software, but I am entirely open to a Windows utility for this.
Thanks,
Fred
Uncle Freddie
For serious analysis work most people would be thinking of Matlab or the free alternatives like Scilab or Gnu Octave.
Posts: 16988 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by DC-Choppah »
Mathematica supports data types with arbitrarily large precision. You can do an FFT on data with as high a precision as you want.
X:=N[{0,0,0,1,1,2,1,1,0,0},100]
Defines a waveform stored numerically with a data type having 100 significant digits.
Any process you apply will be done with that precision such as an FFT.
Fourier[X]
DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am Location: MD, USA
