Combining IRs
Combining IRs
Post by arkieboy »
For reasons I chose RedWirez IRs - which I'm very happy with. For more on how this came to be you can read all here https://www.soundonsound.com/forum/view ... ix#p564291
(AFAIR) A few hours later I got a mail from RedWirez noting that they had an addendum pack of impedance IRs for popular speakers which we could/should apply before the selected IR.
These can be used to reproduce the effect that a tube amp can have on the frequency response of the speaker. Compared to solid-state power amps, tube amps have a high output impedance. As a result the connected speaker's frequency response will change, causing it to look more like it's impendance curve than when driven by a solid-state power amp. You may appreciate the more scooped tone, added thump and sparkle.
Run these in a convolution plug-in before your cabinet IR. Or, use our mixIR tools to process one or more IRs using these impedance curves (available on your My Stuff page).
Added thump and sparkle - what's not to like ...
So being too cheap to fork out $50 on mixIR - which looks the biz TBF - I just included two 1024 IR blocks in my Helix presets. Anyway its about time I got around to permanently applying them with my favourite IRs and saving some processing power. Is this just a matter of playing a test tone through convolver plugins (space designer/ReaVerb) in series in my DAW?
arkieboy
Posts: 589 Joined: Thu Nov 07, 2002 12:00 am Location: Oxfordish
