My first post here but I am a longtime lurker. And I would like to sincerely thank the crew at SOS for the great reviews they put out to helps folks like me.
We are making a room around 30 sq. metres after treatments. Being designed professionally & and plan is to flush mount the monitors. Designer is happy to work the room around my choice (has sort of suggested ATC50s as a choice but they are beyond my budget). No sub-bass etc in our music, mainly acoustic. The budget is around 6-7K (GBP) but can try going higher but lower will be better. I know I will have to listen to them in my room finally to make decision.
What am I looking for: 'vibe' is most important, play them silly loud if needed, with good bass extension but clear bass with no muddiness creeping into rest of the frequency range & of course with good mix translation when all is said & done. Asking for too much I guess huh
I have been thinking:
KH420 - considered excellent by Hugh, they have amazing specs and great pedigree too. Big brothers of KH310 but of course a ported design. They do tick all the boxes but I need to hear them of course.
Boulders: Sealed design as the KH310, great specs, coax HF & MF drivers. Unity audio seem to have quite a following amongst professional crowd here in UK so that says a lot. The new ones go down to 30 HZ but will they be tracking monitors? They seem to excellent at mixing but as I said vibe is my first priority when composing etc. Will the spl be enough?
Eve audio SC3010 or 3012 - the bigger ones runs at higher range of budget but are whopping 138 ltrs (KHs 96 ltrs , Boulders 64) in volume so will definitely move some air. But will they be accurate enough.
ADAM S3H
PSI25M - Seem to be very balanced but will they have the spl.
Questeds 3110 or 3208s - they seem to be well regarded with vibe but looking at some tests, seem to have that descending frequency response at the extremes - guess that makes them pleasant to listen to but are they accurate....
Or maybe I am contradicting myself - I first want vibe, and then I want accuracy - but as someone said 'I want it all'
Please help - thanking you kindly.
FibCouple
