Migrating from multitrack to PC: I can't get no (output) satisfaction
Re: Migrating from multitrack to PC: I can't get no (output) satisfaction
Post by CS70 »
FrankF wrote:
James Perrett wrote:I hope I don't confuse things by saying this but it appears that you can use the analogue inputs on your Alesis monitors at the same time as the USB input.
Hi James, a couple of other people said that this was the cause of my problems, which is why I tried the rewire (see above). But I'm still all ears.
You can, but best to start up simple and go a step at a time.
Since you have experience of connecting analog equipment, do realize there's nothing different with a PC - you still need "cables" and devices to move the audio from here to there - only some of them will be digital, i.e. moving data inside different software parts in the computer instead of having voltage differences over a physical cable.
Conceptually there's nothing different - a signal still has to go from A to B thru a series of devices - only some devices are software components running in Windows)
Probably best to ignore my suggestion for now until you've got things working.
I can't see your older posts but have you tried playing a CD player or MP3 player through the speakers to check that the analogue inputs are working?
If the speakers are working then you'll need to get to grips with the Focusrite software control panel and make sure that you are sending audio where you think you are. The control panel on my Focusrite interface is a triumph of style over function and the outputs sometimes stop working for no apparent reason but I would have hoped that things have improved with more recent interfaces. On mine you can either have separate headphone mixes on outputs 5 and 6 or send outputs 1 and 2 to the headphones and the only way to tell how this is set up is looking at a tiny little button.
Sometimes when I have real problems with routing I'll set up a project that sends the signal to all outputs - something that is fairly easy in Reaper.
Post by FrankF »
"The control panel on my Focusrite interface is a triumph of style over function..."
Well, I'm glad I'm not the only one who's less than impressed with Focusrite's s/w interface: my version of MixCtl won't even resize to full-screen, so there's no point in doing a screenshot.
FrankF
Posts: 596 Joined: Fri Sep 13, 2002 12:00 am Location: La Vendée, France
Post by FrankF »
Hi CS70, thanks. I've checked the h/w: it's the s/w that's driving me up the wall and across the ceiling.
FrankF
Would a couple of screenshots of my set-up help?
Also, what set of outputs have you got the speakers plugged into and are you getting headphones signal?
On the principle that I'm at home and have them open now, here's my set up for Reaper:
and MixControl:
Post by FrankF »
Thanks a lot for posting that, BD: I copied your MixCtrl Mix 1 and Mix 2 settings, in both Routing Preset and the bit below (the bit that's unlabelled!), but still no sound at all.
Re speakers: I've got 2 jack cables going from the Mon. 1 and 2 outs of the Scarlett into the jack inputs on the Alesis speakers.
So anyway, what's the config s/w on the Behringer XR boxes like? Is it more user-friendly than Focusrite? :protest:
FrankF
Post by FrankF »
Sorry, just to iterate: the keyboard signal is reaching the Reaper channel, no probs.
On the Scarlett, I also have headphones attached, but there's nowt cumming owt, as that coach from Loneliness of the Long-Distance Runner would say.
FrankF
Post by FrankF »
FrankF wrote: as that coach from Loneliness of the Long-Distance Runner would say.
Oh my, It was Kes, and the actor was Brian Glover! Still, 2 great films get a mention, why aye!
FrankF
Post by CS70 »
FrankF wrote:Sorry, just to iterate: the keyboard signal is reaching the Reaper channel, no probs.
That's an obvious sign of incorrect routing. Can you put in dropbox a screenshot of your software mixer and post it?
And if you look at the simpler windows Sound Settings, and try to test the levels, do you hear anything? (I guess not but just in case):
It's easier to have Windows set up right first, then look at Reaper.
FrankF wrote:Thanks a lot for posting that, BD: I copied your MixCtrl Mix 1 and Mix 2 settings, in both Routing Preset and the bit below (the bit that's unlabelled!), but still no sound at all.
What are your reaper settings set to?
Post by FrankF »
Almost identical to your screenshot: Focusrite is showing as device, then i/s and o/s are more or less the same.
FrankF
Are you getting any movement on the meters in MixControl at all? Either for inputs or any of the output channels?
And in Reaper, have you got the routing for the master fader set to send an output to your hardware? Nothing there's been accidentally muted or anything like that? This is tricky to do remotely without any screenshots.
Don't suppose you're a TeamViewer user? Or any other screensharing technology?
I had similar issues figuring out the Focusrite mixer, I just called Focusrite, they are very approachable, and in the UK! customer service is "just like it used to be" in the good old days.
They just talked me through the initial set-up, and it worked fine after that.
Maybe worth a go...
Posts: 21952 Joined: Sat Jul 12, 2003 12:00 am
Post by FrankF »
blinddrew wrote:Are you getting any movement on the meters in MixControl at all? Either for inputs or any of the output channels?
Yep, the meters are full of life in MixCtrl, the last 4 meters on the right.
Arpangel wrote:I had similar issues figuring out the Focusrite mixer, I just called Focusrite, they are very approachable, and in the UK! customer service is "just like it used to be" in the good old days.
Maybe worth a go...
I should've thought of that earlier! I'll give them a ring, and if anything interesting comes of it, I'll post it here.
FrankF
Hopefully focusrite will come through because I'm all out of ideas I'm afraid. :(
We're getting signal into reaper, and from reaper to mix control, but not from there to the hardware even though we've got the right outputs selected. :?:
Post by FrankF »
Well, it was embarrassingly simple: I needed to click on the H/W Ctrl button in MixControl, so that turning up the physical vol. knob on the Scarlett actually did something. For some reason, it wasn't activated by default, so we did a reset and took it from there.
And what an absolute PLEASURE, in this day and age, to call a corporate 'phone no. and immediately speak to real human beings, and this w/o pressing any options 1, 2, or 3, w/o entering any codes or pressing asterisk or giving the h/w serial no. etc. etc. - just bish bash bosh, and Scott Walker's yer uncle.
Massive respect and applause to Focusrite for this approach: I hope it continues.
Thanks for all your suggsies, especially the person who recommended the horse's mouth option. :D
FrankF
Excellent, glad you're sorted. I've always had really good support from Focusrite as well so it's good to hear about that too. :)
And in my defence, my version of mix control doesn't have that button... :?
Post by FrankF »
blinddrew wrote:And in my defence, my version of mix control doesn't have that button... :?
Oddsfish, you're right! I've just had another look at your screenshot. I wonder if they added it or took it away? I have v. 1 8 128.
FrankF
Post by Watchmaker »
Yay! :thumbup:
Watchmaker
Posts: 1319 Joined: Wed Apr 13, 2016 12:00 am Location: Upstate NY, USA
Where does sound exist?
Probably added, my interface is probably getting on for 12 years old now I'd guess.
