FrankF wrote:James Perrett wrote:I hope I don't confuse things by saying this but it appears that you can use the analogue inputs on your Alesis monitors at the same time as the USB input.
Hi James, a couple of other people said that this was the cause of my problems, which is why I tried the rewire (see above). But I'm still all ears.
You can, but best to start up simple and go a step at a time.
Since you have experience of connecting analog equipment, do realize there's nothing different with a PC - you still need "cables" and devices to move the audio from here to there - only some of them will be digital, i.e. moving data inside different software parts in the computer instead of having voltage differences over a physical cable.
Conceptually there's nothing different - a signal still has to go from A to B thru a series of devices - only some devices are software components running in Windows)
