Searching for that dreamy creamy compressor?
OK, I've sold all of my cheap compressors, none of which did anything for me at all.
I'm a lover of that quite compressed 70's style creamy "hi-fi" type sound, it's difficult to describe, I get it on my music sometimes, but it's hit and miss, and I don't know how I do it most of the time, it just happens.
Creamy is the best way I can describe it, the top end is smooth, but not dull, and the bass is very tight, and compressed. The mid range has detail, but it's not overly pronounced. I had an old AR amp that used to sound exactly like this, whatever you put through it.
I'm thinking that a good valve comp/EQ may be what I need as a more reliable solution, I'd be happy to just put it across my main mix and leave it there. I have heard the Neve Buss Compressor, ad that sort of gets there, but any alternatives worth considering would be welcome.
This may sound a bit obsessive, but it's a sound that makes a lot of difference to me, and the enjoyment of music in general.
Re: Searching for that dreamy creamy compressor?
Post by Random Guitarist »
Are there any commercial recording you can reference, to help understand what you are hearing?
Random Guitarist
Posts: 1207 Joined: Tue Apr 01, 2008 12:00 am Location: West Sussex UK
Post by hobbyist »
Arpangel wrote:OK, I've sold all of my cheap compressors, none of which did anything for me at all.
What do you call creamy dreamy?
Have you tried compressing frequency bands separately?
I am so happy that I am not so fussy about such things that I can still enjoy good music without obsessing about chasing 'perfection' whatever that might be and is apparently different for many people.
hobbyist
Posts: 285 Joined: Mon Jul 01, 2019 12:52 am
Post by Bob Bickerton »
Whilst I tend to aspire to a clean sound in most of my work, there are occasions when I'm looking for some warmth, some subtle binding of elements in the mix. I work in-the-box and have the good fortune to work with UAD plug-in emulations.
The compressor I use for this work is the Fairchild 670 emulation.
Bob Bickerton
Posts: 5639 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by CS70 »
Now I'm just imagining a glowing $45000 Fairchild sitting right next of Arpangel's TV to compress the output :bouncy:
CS70 wrote:Now I'm just imagining a glowing $45000 Fairchild sitting right next of Arpangel's TV to compress the output :bouncy:
Would save on heating bills............ :bouncy:
Bob Bickerton
But would double the electric bill....
I'm not obsessing over anything, there's nothing wrong with trying to get the sound you like.
I'm cacapable of enjoying any music, reagardless of recording quallity.
Examples abound of the type of sound I'm trying to get at, Pink Floyd Dark Side Of The Moon, Caravan, some recordings by Gong, Steely Dan, David Sylvian, Fairport Convention, a lot of 70's stuff has this sound. And I've heard stuff put through the Neve Buss Compressor that comes pretty close. Fairchild, yes, a good choice, but totally unjustifiable.
Post by Kwackman »
I assume you're not interested in software plug-ins?
Slightly odd suggestion, but the SSL Six?
A whole mixer might be overkill, but using it as a 2 in 2 out, you'd get their buss compressor, and also some nice EQ etc?
https://www.soundonsound.com/reviews/so ... -logic-six
Kwackman
Posts: 3686 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Kwackman wrote:I assume you're not interested in software plug-ins?
Thanks, I think I'd rather stick with hardware though.
I'm not familiar with the SSL sound, but I always associate it with early 80's digital recordings, up front, hard and glassy. "So" by Peter Gabriel springs to mind, just awful
This Neve Buss Compressor seems alright, but it's a bit expensive, TBQH, I don't really know where else to look.
Arpangel wrote:I'm not familiar with the SSL sound, but I always associate it with early 80's digital recordings, up front, hard and glassy. "So" by Peter Gabriel springs to mind, just awful
:shock::shock::shock::headbang::shock::shock::shock:
Not his best material, but it sounds phenomenal!
Post by Zukan »
'So' is actually very well produced.
Zukan
1-2-1 Tuition
Post by CS70 »
Laughing.. this latter exchange should go directly into the "what sounds better" thread. :D
Post by MOF »
Judging by the documentary of the making of SO I would say you’re wrong about this, all I saw were 2” analogue multitracks.
He said he takes years to finish an album SO was released in 1986 one year after the first all digital Brothers In Arms so it’s most likely not digital.
MOF
Post by MOF »
Are we really talking about compression here and not tonal balance?
You refer to an amplifier’s sound which has nothing to do with compression (unless you’re driving it very hard and that will be more down to thermal compression of the speaker drivers).
I have a similar issue with trying to replace some old Sennheiser headphones which sound neutral to me but others I’ve tried sound hyped in the bass or upper mids.
Last edited by Hugh Robjohns on Wed Aug 21, 2019 5:14 pm, edited 3 times in total.
MOF
MOF wrote:Are we really talking about compression here and not tonal balance?
I'm thinking along similar lines.
I'm a bit of an SSL devotee, I'll admit, but by any standards there's nothing lacking in the sound of SSL's venerable mixers. And SSL's compression has been *the* sound of three decades of production.
Post by Sam Inglis »
Yes, oddly enough I'd say that the one constant among the list of albums you've quoted is that none of them sounds very compressed!
Sam Inglis
Interesting range of thoughts on So.
To me it's a difficult one, it is really well mixed and produced in that I can hear everything distinctly, but there is something 'off' about the sound to me when I compare it to recordings I really like. Given the comment about all analogue I googled a bit. . .
There is an interesting bit here https://forums.stevehoffman.tv/threads/ ... ly.187166/
One part that stands out to me is :
"The process of getting stuff back from slave reel number five to master reel number one involved sometimes lining up the 2-inches and flying between them manually, bit by bit. In July we got an AMS sampler with 14 seconds of sampling time, so we could actually sample four or five measures of music and fly it in that way, which helped. By September we had everything over to the 32-track machine."
To be fair my Cd is from the time the album was released so it will have the faults of early digital media, so maybe remasters sound better.
Random Guitarist
Post by DC-Choppah »
Tape?
I believe all the records listed used tape for multi-tracking and mixing down, etc.
A good tape emulator?
I always note that I like the sound of my old tapes played on a quality machine. Has a certain sound.
DC-Choppah
Posts: 2054 Joined: Fri Jul 20, 2012 12:00 am Location: MD, USA
Random Guitarist wrote: One part that stands out to me is :
If you read the whole article you will see that they ended up running the two analogue machines in sync with the digital machine for the mixdown as some instruments sounded better coming directly from the analogue tapes. I'm not sure whether they mentioned what it was mixed down to.
DC-Choppah wrote:Tape?
Yes, I'm thinking that too.
"So" is a great album, but the recording quallity makes me cringe, the worst track sonically is "Sledge Hammer" hard as glass, and compressed to hell. If it was recorded on analogue fine, it must be other things that make it sound bad.
A lot of what I like about the sound I'm trying to describe is in the bass, a very soft compressed sound. I don't want this thread to become too animated about this, I'm not doing a great job of describing what I'm hearing, I'll probably listen to a few things and stumble over it by accident.
James Perrett wrote: If you read the whole article you will see that they ended up running the two analogue machines in sync with the digital machine for the mixdown as some instruments sounded better coming directly from the analogue tapes. I'm not sure whether they mentioned what it was mixed down to.
Yes I got that, to me the point is that it clearly wasn't a purely tape endeavour and there were digital things going on in the background, even if they were not visible in the documentary.
Don't get me wrong, I am not anti-digital in any way. I have no desire to return to that format. But I would agree with Arpangel that there are some recordings that just have a wonderful sound to them, and So is not one of them. Great songs, great playing and arrangements, great production, but somehow the final sound is not to my taste.
Random Guitarist
Tony Levin describes the Sledgehammer bass track
https://www.youtube.com/watch?v=ZwVDIkC2NMw
Listen how highly compressed that sound is because of the Boss octaver OC-2 adds a synthesized sound that has a constant level.
And the pick! Now I hear it. Very unusual. Very distinctive part of the sound of that record.
DC-Choppah
DC-Choppah wrote:Tony Levin describes the Sledgehammer bass track
Nice sound! I agree about the pick, although I must admit I was expecting its sharp attack to perhaps throw the octaver.
Posts: 22577 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
