Home recording piano and flute advice please!
Re: Home recording piano and flute advice please!
Post by Siejen »
Thanks John, it's good to know this is merely tricky, and not impossible . I hope to do justice to all the help so far!
Anyway, I've been messing around with Mike Seniors piano recordings and my daughters flute, and have come up with this sort of sound that I think I like. This uses the cardioids outside the piano (as I'll be able to setup similar I hope)
https://drive.google.com/file/d/15d-mjy ... sp=sharing
Any comments ? (and please go easy on the flute playing comments, she has a Dad faffing around her with microphones while she plays!!)
Iain
Siejen
Posts: 32 Joined: Thu Sep 02, 2004 12:00 am Location: Coventry
Post by Sam Inglis »
If I'm right in thinking that your Line Audio mics are omnis, I think the first thing I'd try would be to have them arranged as a spaced pair between the piano and the flautist. In other words, to position them as you might for recording a solo piano piece and then place the flautist behind them. That way you should be able to get a reasonable balance between the two instruments without having to go very distant and thus bring in more room sound than you want.
Sam Inglis
Posts: 3229 Joined: Fri Dec 15, 2000 12:00 am
Post by Siejen »
Sorry Sam, I got the cm4 cardioids. I did read the piece on soprano and piano describing this technique after buying them and think about what I’d done, but longer term I think the cm4 will see more use.
Siejen
Post by John Willett »
Siejen wrote:Sorry Sam, I got the cm4 cardioids. I did read the piece on soprano and piano describing this technique after buying them and think about what I’d done, but longer term I think the cm4 will see more use.
As the Line Audio mics are such very good value, I would also recommend that you also get a pair of the OM1 omnis when you can. :thumbup:
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Post by Exalted Wombat »
Ariosto wrote:
Exalted Wombat wrote: Surely the opposite? Later works will have been conceived for an instrument pretty close to a modern piano. Earlier stuff may not have been conceived for piano at all, or for a piano with a much lighter tone than a modern one.
But the musicians will have addressed this issue. You shouldn't need 'remedial mixing' on this sort of session.
Fine if using a clavichord or a similar early instrument but if you read the earlier posts, this is being recorded on a modern piano. Modern works will have possible challenges. The early works may have too, but as you might know, early keyboard works are less thickly scored.
And how do you know the musicians have addressed the issue?
I think you miss my point. The later works will have been composed with modern flute and piano (or instruments very close to them) in mind. The composer will have scored them in a way that sounds good. That's part of his skill-set as a composer! We shouldn't have to double-guess his musical intentions in the way that we might need to when performing a 17th century piece on the 'wrong' instruments.
But this isn't like recording a bad rock group with players who don't know how to give way musically. I think (hope!) we can assume these guys are listening to each other and balancing as required.
Exalted Wombat
Posts: 5847 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Post by Siejen »
Hi again, photos are in from the house and I think we might just get away with this!!
It’s a very odd shaped room with few parallel walls but more importantly it has a balcony so is double height :D
It’s all hard surfaces, so plenty of duvets at the ready for flutter echos, but large low frequency standing waves may be less of an issue than I feared.
Poorer news is that we only have the day, so reduced track list it is. Until they want to try again after more practise!!!
Siejen
Shame about the time limit but the room sounds promising, good luck! :thumbup:
Siejen wrote:Poorer news is that we only have the day, so reduced track list it is.
What does that mean?
Exalted Wombat
I took it to mean recording fewer pieces. Seems like a sensible approach rather than trying to jam stuff in and compromise on the set up time.
Post by Siejen »
Yes, exactly that. I’ve been optimistic on track numbers before and it never really ends well for anyone. So as this is more ‘grown up’ than I’ve done before, i want to focus on the quality.
<dawning realisation I might actually have grown up, but just not noticed >
Siejen
Siejen wrote: <dawning realisation I might actually have grown up, but just not noticed >
Whoah, watch out for that. It's a slippery slope. Better sit around and watch cartoons for half an hour whilst you eat a tub of ice-cream. That should stave it off for a while.
Post by Siejen »
:mrgreen: Does riding my bike round the woods until I fall off count??
Siejen
That'll do it :thumbup: can I join you?
Siejen wrote::mrgreen: Does riding my bike round the woods until I fall off count??
Definitely! :)
blinddrew wrote:I took it to mean recording fewer pieces. Seems like a sensible approach rather than trying to jam stuff in and compromise on the set up time.
This isn't your decision. You're recording, not producing. You set up your equipment, they play. When THEY are happy with the performance of one piece, move on to the next one. YOU don't get two goes at anything.
Last edited by Exalted Wombat on Sat Aug 24, 2019 3:04 pm, edited 1 time in total.
Exalted Wombat
Post by Aural Reject »
I’ve not checked the thread but do you categorically know that?
I’ve often come across people who expect feedback from the ‘engineer’, including production decisions.
Aural Reject
Posts: 995 Joined: Fri May 02, 2003 12:00 am Location: Lancashire born, living in Yorkshire :s
Post by Mike Stranks »
Quite
Post by Siejen »
As we’re all pretty green at this, I’m looking to manage expectations on what we will achieve. I fully expect a second day to be requested (based on experienced feedback here), but everyone involved needs to see that for themselves.
A copy of the days recordings on the day is a genius idea to put in perspective what we achieved. If they’re happy with the playing, we’re good. If not, we go again. We’re only doing this for our own fun, after all!
Siejen
Quite
You could be right! Anyway, we'll know soon. Did you tell us when the session was?
Last edited by Exalted Wombat on Sun Aug 25, 2019 1:18 am, edited 1 time in total.
Exalted Wombat
Post by Siejen »
Session is Wednesday.
Timetable so far is arrive and setup PC, mics at 9.
Pianist coming at 9 as he knows the family we're borrowing the piano from.
Stereo mic positioning, duvet hanging and trial recordings until 11 when Flautist arrives.
Additional spot mics, trial runs, mugs of tea until Lunch.
Then record until family return to their home and we get thrown out!!
New news is there are some solo flute pieces to do, but those can be done later at my place. Getting the piano pieces will be the focus of Wednesday.
Siejen
You can't be a musician then. ;):D
Mummy, mummy, when I grow up I want to be a musician.
Sorry darling, you can't do both.
:bouncy:
John Willett
Post by Siejen »
Moving on... it’s the night before and all the gear is packed. Good news is I’m sold on the dominant pair of mics. Discussion here and lots of listening and playing with multiple tracks says you’re all right, so thanks. Nearly failed at the first hurdle!
Now I’m worried by how far away an ORTF pair needs to be to capture the pair. In the room I’m going to be lucky to get 2m from the piano. Is there a recommended distance from source for ORTF? Does NOS allow me closer? (Narrower recording angle; been reading and listening )!
Experiments here favour ORTF over xy (too clinical)
I’m guessing this is normal nerves. Thanks for all the help so far. More tomorrow!!
Siejen
Post by Siejen »
Question; does the ‘over’ cardioid response of the line Audio cm4 come into play here as well?
As they’re not strict cardioid, should I be closer to 27cm, 120degrees for a 96degree SRA?
Rabbit hole here I come :o
Siejen
Post by Bob Bickerton »
It sounds as though your research has been excellent but maybe, and others may disagree, my recommendation now will be to start with the CM4 ORTF pair and then focus your energy on listening.
Be aware of balance, width of the image and placement within the image. Be prepared to move musicians as well as mics. Assess the tonality of the elements and what impact the room is having on this.
And try to enjoy the experience!
Do report back and let us know how you got on.
Bob Bickerton
Posts: 5642 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Post by Siejen »
Thanks Bob.
The car is so full of duvets, clips and things to hang them from I lost a little perspective :beamup:
Musicians, instruments and room are all above angle of mic separation in my head now
Siejen
